Dyno, drag, track - in search of my E39 Trifecta - BMW M5 Forum and M6 Forums
Like Tree25Likes
Old 8th July 2011, 18:58   #1
bimmerule
bimmerule's Avatar
Garage: Carbon Black E39 M5
Sales Feedback: (8)
In keeping with the philosophy "learn to crawl before try to walk", I have focused primarily on restoring stock performance and resisted jumping to go fast goodies. For the first time, I have quantitative data that confirms my Beast is putting down descent numbers (319lb/ft, 341whp).
The next step is to clock the almight ET. It will be the first time for both me and the Beast (PO was a doctor, doubt he ever dragged it). I plan to visit the Englishtown drag strip (only place within reasonable driving distance), and I'm hoping for a 13.5 around 105, leaving 0.1 sec slack for rookie driver If all goes well, will then enroll in a couple of road course school days and let her loose on Limerock Park, and eventually Watkins Glen.
Here's the dyno adjusted to DJ. It was 85F, a bit humid, near sea level. Before hitting the track, I will have Dinan rear roll bar installed, running E60 SSK now. Slowly, but surely paving the way for what will eventually be a reliable, intercooled FI setup with performance headers, and a tune. Appreciate any comments and suggestions on the journey.
bimmerule is offline   Reply With Quote
Old 22nd March 2012, 06:42   #2
bimmerule
bimmerule's Avatar
Sales Feedback: (8)
Finally had a chance for the second installment of this series. I stopped by Northeast Motorsports in NJ to have a few things looked at, and swang by Englishtown Raceway on the way home (ok, it was a 100 mile detour). The car put down 13.75 @ a hair under 104. The clutch slips in the higher RPM, and the car weighted in at 4206 lbs with driver. I may have left a couple tenths on the table slipping through the clutch, but I'm happy with the power it is putting down.
The clutch/flywheel/rms/giubo will all be replaced before the track event in April, here're a couple shots leaving NEM in the morning and the timing slip. Got myself a new camera so no more grainy pictures!
The Following 4 Users Say Thank You to bimmerule For This Useful Post:
DRM (22nd March 2012), herrubermensch (22nd March 2012), M5 London (22nd March 2012), sor118 (22nd March 2012)
Old 22nd March 2012, 11:23   #3
M5 London
M5 London's Avatar
Garage: M5 E39 Supercharged
Nice one Richard !!
Your car looks great, nice photo :
E39 M5 - ESS Supercharger Kit, Uprated and MONSTER Remapped to 640HP, Van Manen Race Manifolds, Van Manen DeCats, Aeromotive Stealth 340 F/Pump, Bosch Green Giant Injectors, Aquamist HFS-3 with 3 Jets, MONSTER CCV setup with Cobra Pump (2PSI boost switch), Bilstein Sprint Dampers, Intrax Springs, Dinan Adjustable Rear ARB, Stoptech ST40 Big Brake Kit, EBC Yellows, 550i SSK
www.WhatAboutCars.com
M5 London is offline   Reply With Quote
The Following User Says Thank You to M5 London For This Useful Post:
bimmerule (22nd March 2012)
Old 22nd March 2012, 15:04   #4
rao
Garage: Silver 540i
Nice results for a real car. You can get that 60' time down to around 1.9-2.0 with street tires and that will have a pretty large impact on your ET.
Rob
Current - 98 540i with Chevy 6.6 LS2/T-56 power - Build Thread
Old - 92 325i with Chevy 6.6 LS2/T-56 Power
Older - 95 M3 with Chevy 6.6 LS2/T-56 Power
Please read the important REVISED DISCLAIMER that applies to this post.
rao is offline   Reply With Quote
The Following User Says Thank You to rao For This Useful Post:
Old 22nd March 2012, 20:14   #5
OsinO
Garage: 03 M5 LeMans Blue
Sales Feedback: (4)
Nice! What kind of dyno? On the roller or the the dynajet type
OsinO is offline   Reply With Quote
Old 23rd March 2012, 00:18   #6
gsfent
gsfent's Avatar
Garage: 01 M5 Black/caramel
Sales Feedback: (3)
Easier said than done, but a little better reaction time will help too.
Talk to some of our resident drag racers, (Clemster among others) about how to stage, shallow or deep, that will help a little bit also.
The Following User Says Thank You to gsfent For This Useful Post:
bimmerule (23rd March 2012)
Old 24th March 2012, 00:24   #7
sor118
sor118's Avatar
Garage: 2002 Carbonic Blackalicious M5
Sales Feedback: (4)
Reaction time really just helps when actually racing another car to get a jump on them as opposed to getting a really great ET where the time begins when your trigger the sensor that starts the time. Shallow staging is good for better ET's and better trap speed.
2002 Carbon Black BMW ///M5 (Black Extended Leather, Anthracite Alcantara, Titanium Trim, M-Audio with Enhanced Bass, PDC)
Conforti Shark Injected with M5Board Tune, CMS Custom Muffler Delete with OE Tips, AFE Pro Dry S air Filters, ACS rep CF Front Splitters, Flat Black Kidneys, Open brake ducts with Flat Black Brake Duct Rings, StopTech Stainless Steel Braided Lines, Shorty Clutch Stop, Lighted ZHP Knob, Custom Pure White Angel Eyes (Predator Ice housing and Rebel Tri-Star LED's driven by PowerPucks), Umnitza V4 ION License Plate Lights, Fogs color matched to HID's, Oil Pan Pad Heater for winter, 3M Clear bra on hood, Flat Black Style 65's on Nitto NT555's, Style 66's on Conti Extreme WinterContact's for the other 6 months, Interstate MTP-H9 Battery, Sybesmas remaned rearview mirror, Boomerang Espion Alert LoJack, MKIV Nav with 2010 maps.
http://www.cardomain.com/ride/2964057/1
http://www.bmwmregistry.com/detail.php?id=7570
sor118 is offline   Reply With Quote
The Following User Says Thank You to sor118 For This Useful Post:
bimmerule (24th March 2012)
Old 24th March 2012, 00:26   #8
rao
Garage: Silver 540i
+1 on the reaction time.
Actually shallow staging will result in a slightly higher trap speed because the car covers more distance. Whether to shallow or deep stage depends on lots of variables, but it is not going to make a huge difference in most case, especially with anything that can actually be driven to the track.
For a car like a M5 it won't make any material difference.
Old 24th March 2012, 00:35   #9
sor118
sor118's Avatar
Sales Feedback: (4)
True lots of variables but they do add up. After all, we are talking tenths and hundreths here.
The launch is the most important. Modulating the throttle and clutch- not spinning the tires too much is key and not missing any shifts and definitely not hitting the rev limiter. Keeping the car straight.
I usually rev up to 1800-2000 rpm and drop clutch for a good hard launch and modulate the throttle until the tires grip.
fun times!
Old 15th April 2012, 21:28   #10
bimmerule
bimmerule's Avatar
Sales Feedback: (8)
Had the inaugural shake down at Lime Rock Park yesterday, weather was perfect. I learned a great deal about the racing line, roll on throttle and braking from my instructor, who placed 2nd in ST2 class TT. I had an unofficial time of just under 1'10", but there's leaps to learn about smooth turn in, transition and track out. It was an intense but rewarding day, here's a quick pic, video to follow.
Dyno and Track in NYC/Tri-State Area bimmerule USA Northeast Forum 2 21st June 2011 18:17
Looking to get baseline dyno pre-SS header/xipe/chip..will my first ever SES light affect dyno results? M5Gator E39 M5 and E52 Z8 Discussion 0 14th May 2010 02:17
Video: New Magnaflow Mufflers, Drag Racing, and a Dyno jrhaile E39 M5 and E52 Z8 Discussion 6 29th July 2007 08:40
Track Pipe Dyno Results ajw45 E28 M5 Discussion 2 11th May 2006 14:15
Went To The Drag Strip And Dyno On The Weekend.... RobC E39 M5 and E52 Z8 Discussion 4 5th April 2000 19:37
