Air conditioning troubleshooting - BMW M5 Forum and M6 Forums
post #1 of 5 Old 25th June 2011, 11:03 PM Thread Starter
kevin711
So I went to use my AC today and it wasn't blowing cold. I ran the AC once in awhile in the winter/spring when it was above 5 degrees C or so and I thought it worked since the compressor worked. I did a search and went through every thread here and on bimmerforums, and here's my findings so far:
- All hvac fan speeds work, and all vents blow the same temperature roughly -- likely not the fsu
- when I turn the center vent wheel from 3 blue dots into the red, I get heat... so the flaps seem to be working
- when I change the vent options (feet well, center, windshield) all of them work as well
- the AC light turns on when the snowflake is pressed
- the outdoor temperature sensor works ok, it reads the correct outdoor ambient temperature
- my front auxiliary fan is working, it spins up and down at idle (it spins pretty fast and loud sometimes)
- the AC compressor clutch engages -- I can see it spin with I turn on the AC and I can hear the compressor click in
- i used a low pressure AC gauge and with the AC off, it reads 45 psi ,with the AC running it reads 32-33 psi
- I checked the plug on the evap canister and it is getting power (approx 5v on two lines) and has ground
- water valve under the hood on the driver side is getting power
am I low on r134 or should I look at something else?
2001 BMW M5
kevin711 is offline
post #2 of 5 Old 25th June 2011, 11:05 PM
dan.
dan.'s Avatar
i had a similar issue but turned out to be the hedgehog was messing about for the second time.
dan. is offline
post #3 of 5 Old 27th June 2011, 01:29 AM Thread Starter
kevin711
alright, I'll order one of those FSU's... not sure when it was last replaced and it's cheap. Worth a shot.
2001 BMW M5
kevin711 is offline
post #4 of 5 Old 27th June 2011, 04:16 AM
AMP
AMP's Avatar
You're most likely low on charge as the high and low sides should equalize at a higher pressure with the compressor off. The weakest point of the system is the service port valves and we replace them on a very regular basis.
I'd recommend having the system evacuated, valves replaced, and then re-charged with some dye. From there you can start looking for other leaks.
The FSU only controls fan speed and if you are able to address multiple fan speeds and they are stable then the FSU likely isn't an issue here. There could be some issues with the controller or the mix door in the airbox, but at this point the pressures don't look right so I'd start there.
'12 Alpina B7 SWB Alpina Blue/Black (On Order)
'11 1M Coupe Alpine White/Black
'08 M6 Coupe Stratus/Black
'03 M5 Sedan Imola Red/Black (gone, but not forgotten)
'93 M5 Sedan (3.6) Sterling Silver/Black
'11 550i Dark Graphite/Oyster-Black (wife's car)
Past: '11 M3 Coupe | '08 M5 Sedan | '10 M3 Coupe | '07 M6 Coupe | '07 Z4 M Coupe | '04 M3 Coupe | '02 M5 Sedan | '95 M3 Coupe -- x2
AMP is offline
The Following 2 Users Say Thank You to AMP For This Useful Post:
chowdah (27th June 2011), kevin711 (30th June 2011)
post #5 of 5 Old 1st July 2011, 06:54 AM Thread Starter
kevin711
I brought the car to an AC shop, they tested for leaks and existing pressure, everything looked ok.
They evacuated the system and refilled it with fresh R134A, lube and UV dye and it works fine now. The tech said likely the old refrigerant was dirty (contaminated)...
2001 BMW M5
kevin711 is offline
E60 For Sale: BMC Air Filters w/conditioning kit RussRamz Parts / Other For Sale or Wanted 7 20th March 2010 06:07 PM
Air conditioning won't shut off bhemi E39 M5 and E52 Z8 Discussion 3 24th August 2009 08:47 AM
Air Conditioning Problem... 2003M5 E39 M5 and E52 Z8 Discussion 5 4th January 2008 05:24 AM
Air conditioning problems kaninja99 E60 M5 and E61 M5 Touring Discussion 1 11th March 2007 11:07 PM
Air Conditioning Observations MAH E39 M5 and E52 Z8 Discussion 10 3rd January 2001 01:37 AM
