As I suspected, the coefficient of drag for AMG variants is greater than that of the base production car. For the SL55, it is .30 not .29 as in the standard SL. Therefore, it has worse aerodynamics than a standard coupe Corvette which has .29. It also has greater surface area than the 'Vette, so it has more drag. The Z06 Corvette with the blunt rear window have .31, I believe. The E39 M5 has a coefficient of .31 but less surface area than the SL55. I have to double check the surface area information. In any case, the SL55 has no aerodynamic advantage in terms of drag over the E39 M5. (The E46 M3 with .33 has a worse coefficient than the M5.)
Since the SL55 is an automatic and weights 400 lbs. more than the E39 M5, it is making up the handicap with horsepower in large doses. Again, the SL55 is handicapped versus the E39 M5 in efficiency terms. I have guessed about 530 h.p. for it in the past.
