• Latest threads
    • Custom feed
      • Updates
        Old 17th June 2002, 03:37   #1 (permalink)
        Rallistas
        Rallistas's Avatar
        Question regarding track wheels & tires
        Can you use 17" wheels? Whats the up and downs if you could? what size tires gould you use?
        I have some 17" wheels from my old 850. Just wondering if you could.
        Rallistas
        2000 M5 Lemans Blue w/ Silverstone Interior
        KELLENERS - Racing Cats & Exhaust, Full Racing Suspension, Sport Pedals.
        HAMANN - Custom Headers, Rear Diffuser, Front splitters
        DINAN - Front & Rear Strut Braces, Camber Plates, Cold Air Intake, MAF Sencors, Stage 5 Software
        QUAFEI DIFF - Custom 3:73 differential 100% LSD
        UUC - Short Shifter, Lightweight Flyweel, 280mm Clutch.
        VORSTEINER - GTR hood
        STOPTECH - 4-Wheel Brake Kit
        WHEELS & TIRES - 19" BBS LM w/ Michelin Pilot Sport (255-35/19 Fronts 275-30/19 Rears)
        EVO SPORT - Power Pulley Kit
        ROQUE ENGINEERING - Tranny Mounts
        MISC. - Custom Engine Oil cooler, NavTV w/ DVD, Custom Brake Ducts, K-40 Radar, Z8 Start Button, Intake relocation sensor kit, Nowack Style Air Box Plenum, Custom Clutch Stop.
        Rallistas is offline
        Old 17th June 2002, 03:48   #2 (permalink)
        Teutonaddict
        Teutonaddict's Avatar
        You CAN run some 17" wheels...
        I run Borbet Type E's in 17x8.5 and 17x9.5 for my track set-up. I've had NO brake clearance problems with these wheels, although there ain't much space to spare!
        There really are no downsides. If you're running track tires, the sidewalls are pretty stiff to begin with, so an additional inch in rim diameter doesn't buy you much.
        On the other hand, you now have access to a MUCH wider range of track rubber (245/45-17 and 275/40-17). I happen to run Yokohama A032R road racing tires with rain grooves, b/c they allow me to drive to a local track on my track tires, should I choose (and I often do). I may go with Hoosiers when it's time for new track treads, however, as a trackside tire swap is no big deal.
        Hope that helps!
        BOTH SOLD!!
        '00 Carbon Black/Black All-Leather/Sportive
        #101421
        Teutonaddict is offline
        Old 17th June 2002, 03:55   #3 (permalink)
        Rallistas
        Rallistas's Avatar
        Re: You CAN run some 17" wheels...
        Hope that helps!
        Its sure does.
        Isn't this board awsome?
        Old 17th June 2002, 04:00   #4 (permalink)
        Rallistas
        Rallistas's Avatar
        I just went in to my garage and measured the rims.
        They are 17x9 and 17x10.5. Will these sizes fit? and what size tires will I use?
        Thanks in advance.
        Rallistas
        Old 17th June 2002, 04:05   #5 (permalink)
        Teutonaddict
        Looks like it COULD work....
        ....if and only if the offset measurements are compatible.
        On that topic, I'm going to have to defer to someone with more direct experience.
        Dave Z, are you 'listening'?
        BOTH SOLD!!
        #101421
        Old 17th June 2002, 04:35   #6 (permalink)
        Stealthne
        Send a message via AIM to Stealthne
        Be Careful!
        If you have never driven on the track with R-compound tires, go slowly. You won't get any feedback that the tires are about to break until it's too late.
        Don't rush it.
        Stealthne is offline
        Old 17th June 2002, 16:18   #7 (permalink)
        Teutonaddict
        Re: Be Careful!
        Don't rush it.
        You are absolutely correct! I definitely would advise against starting off your track experiences on anything other than street tires. [Rallistas, if you're new to tracking, I'd advise you install some inexpensive street rubber (Kumho Ecstas, for example) on your 17" 8er wheels--presuming they fit.]
        That being said, the Yoko A032R's are pretty progressive near the edge, and do let you know (both audibly and through feel) you're approaching their limit of adhesion.
        I am certain that a switch to Hoosiers or Kumho slicks will require another level of attentiveness, for the very reason efontana states.
        BOTH SOLD!!
        #101421
        Old 17th June 2002, 18:59   #8 (permalink)
        stever
        do a search on previous posts for wheel dims and offsets -- i don't think 10.5 wheels will fit
        i agree that you shouldn't put on sticky tires until you have some track experience with the car
        stever is offline
        Forum Jump
        I ordered new tires and am selling 4 stock wheels with track Kumho tires BeastPower For Sale or Wanted 3 10th January 2003 17:19
        Tire decision time - track tires or not? Richard in NC E39 M5 and E52 Z8 Discussion 4 7th January 2003 05:44
