This is a brief report on my favorite M5 upgrade thus far. Today, I installed the M Audio enhanced bass subwoofers in my 2000 M5. You may know, the 2000 M5 did not have the enhanced bass option. However, the subwoofers that are available as an option on 2001+ are available now as OEM parts, and are a plug and play retrofit.
I have to say, the results are phenomal.
Here is my disclaimer. While I am a trained musician, who arguably has an educated ear for sound, my concept of what sounds good and yours could be quite different. I know for a fact, my high end has been impaired so I tend to prefer what some would say are exaggerated, extra-sparkling highs. And, as a drummer, I need to hear a real kick drum sound, not the sound of a thwack on a cardboard box. This was my primary complaint with the stock bass sound on the 2000 M5.
As an aside - some recordings that have incredible, accurate bass drum sounds are Rush - Moving Pictures (tracks 1, 2, and 4), Pete Townshend "Give Blood", Deftones "My Own Summer, Filter "Welcome to the Fold", Van Halen "Finish What You Started", and Motley Crue "Power to the Music". But I digress.....
I will also point out that this is NOT the best car stereo I have ever heard, by any means. But, with the DSP system in the M5 you have precious little choice on upgrades. You have to pretty much tear out the whole system and start over again, if you want a substantial difference.
In this case, for $380 and ~5 hours of time, I have dramatically changed the low end response in my car. On a bass heavy track, with 30-80 Hz vibration, my back and hindquarters vibrate. And you get a tighter, punchier sound in the 100-150Hz range as well. I also found, I had to re-equalize and turn down the bass on the DSP EQ. This means (I think) more power to the mids and highs from the amplifier. Or, more headroom, at the same output volume. Anyway, I cant say enough good things about it.
A few details. I got the subs from
www.pacificbmw.com. I worked with Lui. I recommend him and them. The cost was $189 per sub, and the BMW OEM P/N is 65-13-7-894-047 (you need 2). This is a 10 subwoofer and comes with wire harness and connector. You need to get screws at the hardware store. God bless German engineering. The speakers are tapped for 5mm metric screws, and everything fits together perfectly. Should I be surprised?
There are great FAQs at
www.bmwtips.com on how to remove the rear deck and how to install the subwoofer. Thanks to Chris Totten for the step by step instructions - they are perfect I followed them to the letter and they were exactly correct. Now, I must say, after removing the stock subwoofer, I admit I was tempted to try to screw the new subs in from the trunk side, as opposed to removing the back seat and rear deck. Take my advice the latter is the only way to do it right. It is intimidating thinking of tearing up your $72,000 car but if you follow the directions, it is pretty easy and it came back together perfectly. I am pretty sure that screwing in the subs from the top of the rear deck - right to the sheet metal, is the only way to get a good air seal.
Take your time allocate about 3.5 hours for the removal of the stock sub, the rear seats, and the rear deck and 1.5 hours for the the installation of the speakers and the wiring.
Note, I DID NOT cut larger holes in the sheet metal under the rear deck. My car was already pre-drilled to accept the new subs, and there was a template for cutting out the 10 hole. If you choose not to enlarge the hole, you end up having a 4 diameter hole (from the stock sub) over the new sub. I believe this might make a difference in the volume of air the speakers would move, but as I said, I am thrilled with the result, and I did not take a hack saw to my car. The thought of that was... well, let's just say, there are limits to my confidence...
There are no vibrations or rattles after the install, that I can detect thus far.
Now, I can give one piece of information that to my knowledge was heretofore undisclosed. The wiring pin-outs for the subs. Your connector that plugs into the standard 2000 M5 subwoofer is NOT compatible with the connectors that come on the new subs. So, I took everything apart and figured it out. In the end, I cut off the connectors and spliced the eight wires. My learning in this process, I pass on to any of you. Here it is:
The 12 pin female connector that plugs into the stock sub has pin-outs (the numbers are on the connector) as follows:
Pin 1 not used
Pin 2 blue with white stripe (S1 +) connects to positive blue/black wire on new L sub
Pin 3 blue with brown stripe (S1 -) connects to negative blue/brown wire on new L sub
Pin 4 yellow with black stripe (S2 +) connects to positive blue/black wire on new R sub
Pin 5 yellow with grey stripe (S2 -) connects to negative blue/brown wire on new R sub
Pin 6 not used
Pin 7 not used
Pin 8 yellow with red stripe (S3 +) connects to positive yellow/black wire on new L sub
Pin 9 grey with brown stripe (S3 -) connects to negative yellow/brown wire on new L sub
Pin 10 yellow with white stripe (S4 +) connects to positive yellow/black wire on new R sub
Pin 11 yellow with brown stripe (S4 -) connects to negative yellow/brown wire on new R sub
Pin 12 not used
This set-up tests out to be in-phase and works well. I cant speak for other E39s but I read on the board once, that you can do the same thing with any E39 that has the DSP sound system. Not sure if those would be all pre-drilled like my August 2000 M5 was (which really made the job easier) but subject to confirming the parts will fit, you might want to give it a try.
Again, in summary, I highly recommend this modification. The value per dollar spent is in my opinion quite high, and the install, while taking a bit of time, is really simple if you follow directions.
Good Luck and PM me if you have other questions.
Mofo
