How can i check if i have plugged/blocked cats? - BMW M5 Forum and M6 Forums
post #1 of 14 Old 24th May 2011, 01:23 AM Thread Starter
pyro225
pyro225's Avatar
whats the easiest way of doing this?
pyro225 is offline
post #2 of 14 Old 24th May 2011, 03:39 PM
mattmartindrift
mattmartindrift's Avatar
mattmartindrift is offline
post #3 of 14 Old 24th May 2011, 03:41 PM Thread Starter
pyro225
pyro225's Avatar
pyro225 is offline
post #4 of 14 Old 24th May 2011, 03:44 PM
mattmartindrift
post #5 of 14 Old 24th May 2011, 06:35 PM Thread Starter
pyro225
pyro225's Avatar
pyro225 is offline
post #6 of 14 Old 24th May 2011, 06:39 PM
mattmartindrift
a flashlight and your eyeballs?
The Following User Says Thank You to mattmartindrift For This Useful Post:
ard (25th May 2011)
post #7 of 14 Old 24th May 2011, 08:26 PM
Tj Hunter
Lost it at work, HAHAHAHAHA!
Tj Hunter is offline
post #8 of 14 Old 25th May 2011, 01:51 AM Thread Starter
pyro225
pyro225's Avatar
Obviously you've never taken off a
Stock exhaust as it's one piece with no joins all the way to the manifold... That's showing one
Cut and clamped together....
pyro225 is offline
post #9 of 14 Old 25th May 2011, 01:58 AM
wentouch
I believe Matt is saying remove the O2 sensors and peak inside.
Process of elimination: Are fumes exiting the mufflers? If so, remove 6? Fumes exiting hole? If so, remove 4.
wentouch is offline
post #10 of 14 Old 25th May 2011, 03:52 AM
mattmartindrift
I wasn't, but BMW sells the kit to "clamp" them back together.
but, if you can borrow/rent a borescope, you could do the O2 removal method.
Plugged Secondary Air Injection Ports jmccashin E39 M5 and E52 Z8 Discussion 67 23rd February 2016 10:05 PM
Sprint Booster- Plugged in Properly- Red Cog 20 min Later? NCM5Guy E60 M5 and E61 M5 Touring Discussion 8 4th May 2011 06:21 PM
Symptoms of a blocked cat? pyro225 E39 M5 and E52 Z8 Discussion 3 28th December 2010 12:53 AM
plugged ports M5 Rocks E39 M5 and E52 Z8 Discussion 8 22nd December 2009 03:19 PM
Plugged in Air Pump, O2 sensor showing? A.W.O.L E34 M5 Discussion 0 3rd July 2008 06:57 PM
