BMW M5 Forum and M6 Forums (http://www.m5board.com/vbulletin/)
-   E39 M5 and E52 Z8 Discussion (http://www.m5board.com/vbulletin/e39-m5-e52-z8-discussion/)
-   -   How can i check if i have plugged/blocked cats? (http://www.m5board.com/vbulletin/e39-m5-e52-z8-discussion/188993-how-can-i-check-if-i-have-plugged-blocked-cats.html)
rated ///M 25th May 2011 05:47 AM
Back pressure test, go to an exhaust shop.
AMP 25th May 2011 06:12 AM
We have a winner!!
Best way to check is to remove a pre-cat O2 sensor and install a backpressure gauge. The gauge isn't all that expensive, but likely a single-use item in most toolboxes. Any competent exhaust shop or indy should be able to test for you.
pyro225 25th May 2011 09:18 AM
pjfox23 25th May 2011 09:23 PM
If you are heading down the path of replacing the cats, I would also get an exhaust gas analysis after replacement. Obviously, there is a reason why they are failing...
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
