Last week as I was bending down to check the tire pressure (in my driveway) when I noticed a nail sticking out of a rear tire. My initial thought was, "damn," followed quickly by other words.
Knowing that by removing the nail I could potentially produce a flat tire, I grabbed a pair of pliers and slowly extracted it to determine whether I would be faced with a small, medium or large tire crisis.
The nail had pierced the tread at about a 45 degree angle and had then been bent against the tread surface by the act of driving. It showed little road wear so I guess it may have been about a day old. Fortunately, there wasn't a big rush of air from the hole when I removed the nail.
I dribbled some soapy water over the hole and confirmed it was (now) leaking air and could not be ignored. At first I thought of using the Mobility sealant or some Fix-a-flat equivalent, but that would have been too obvious. Plus, if I went this route I was just signing up for more work, i.e. geting the tire un-mounted, patched, re-mounted and balanced -- big hassle.
Instead, I took a hypodermic needle and syringe and prepared a very small dose of Superglue. (I can't comment about any of the generic brands.) I inserted the needle into the nail hole -- being careful to keep my face out of the line of fire of the plunger in the event of a syringe blow-out -- and slowly injected the glue into the nail hole while gradually withdrawing the needle. My goal was to glue the hole shut, not to squirt glue into the wheel.
I immediately stuck a piece of aluminum foil over the hole to prevent air loss while the glue was setting. Residual Superglue around the hole opening held the foil in place after a few seconds of thumb pressure.
After about one beer, I peeled off the aluminum foil and repeated the soapy water leak test -- no air leak was detectible. For the next three days, I carefully re-checked my tire pressure twice each day. It has now been one week and this repair is still holding. Who thinks this fix will last the life of the tire?
