Control Arm Bushings removal??? - BMW M5 Forum and M6 Forums
post #1 of 26 Old 12th May 2011, 08:47 PM Thread Starter
jrhaile
jrhaile's Avatar
jrhaile is offline
post #2 of 26 Old 12th May 2011, 09:20 PM
mattmartindrift
mattmartindrift's Avatar
hydraulic press + proper OD mandrel (generally whatever sockets fit, or whatever scrap metal you have lying around that works ) + level surface to hold the control arm.
mattmartindrift is offline
post #3 of 26 Old 12th May 2011, 11:37 PM
"S62"
is the hydralic press a must? or are there ways you can get around it with other tools?
"S62" is offline
post #4 of 26 Old 13th May 2011, 12:59 AM
Tj Hunter
There is a different way, it involves making a puller with a metal c bracket, some nuts, washers, and a bolt. The biggest issue is setting the bushing back in at the proper depth. Or you can burn the rubber, sawzall the metal ring, and use the puller to pull the bushing in.
Personally, if your bushings are gone, your ball joint is too, easier to order the arm as a unit.
Tj Hunter is offline
The Following 2 Users Say Thank You to Tj Hunter For This Useful Post:
"S62" (13th May 2011), Terabass (13th May 2011)
post #5 of 26 Old 13th May 2011, 03:55 AM
dakine
dakine's Avatar
dakine is offline
post #6 of 26 Old 13th May 2011, 05:33 AM
jfoj
Not sure if you are talking about lower control arm bushings or thrust arm bushings?
Also are you trying to remove the bushings to install Powerflex or OEM.
If you want to put Powerflex bushings in, you must remove the bushing which is a bit trickier than pushing the old bushing out with the new OEM bushing.
If you want to install Powerflex bushings, there is a vendor that sells thrust arms without bushings.
jfoj is offline
post #7 of 26 Old 13th May 2011, 05:34 AM
kaiserben
Hydraulic press is the easiest way, if you were on the right coast, I'd volunteer mine :P
kaiserben is offline
post #8 of 26 Old 13th May 2011, 07:36 AM
Alin10123
Alin10123's Avatar
You could always remove the control arms yourself and then drive over to an independent shop that's wiling to press the bushings in and out for you.
Or... i think i saw somewhere on here when someone posted a home made bushing press that he made in his garage... i dont remember the thread title though. I'm sure it's on here somewhere...
-Carbon filter delete
-RPI scoops
-BMC filters
-ESS ECU tune (coming soon)
Alin10123 is offline
post #9 of 26 Old 13th May 2011, 08:27 AM
AMP
AMP's Avatar
As others have stated it's easiest and makes the most sense to replace the arm (with an OE Lemforder). Without a proper press, either hydraulic or manual, you're in for a lot of frustration. Furthermore, it's imperative that the bushing be square to the arm when pressing the new one in or it will never be right.
The arms are actually pretty cheap and the payback in lack of frustration is well worth the extra cost. Anymore we don't replace bushings in favor of the entire arm.
'12 Alpina B7 SWB Alpina Blue/Black (On Order)
'11 1M Coupe Alpine White/Black
'08 M6 Coupe Stratus/Black
'03 M5 Sedan Imola Red/Black (gone, but not forgotten)
'93 M5 Sedan (3.6) Sterling Silver/Black
'11 550i Dark Graphite/Oyster-Black (wife's car)
Past: '11 M3 Coupe | '08 M5 Sedan | '10 M3 Coupe | '07 M6 Coupe | '07 Z4 M Coupe | '04 M3 Coupe | '02 M5 Sedan | '95 M3 Coupe -- x2
AMP is offline
post #10 of 26 Old 13th May 2011, 12:12 PM
olly22n
olly22n is offline
Control arm bushings, OEM or A.M? ChrisM E39 M5 and E52 Z8 Discussion 19 2nd July 2010 06:35 AM
E39 For Sale: E39 M5 Control Arm Bushings FS russap5 Parts / Other For Sale or Wanted 2 20th April 2010 10:24 PM
Anyone need control arm bushings?? russap5 E39 M5 and E52 Z8 Discussion 4 30th May 2009 01:26 AM
Control and Thrust Arm Bushings fiftyfive E39 M5 and E52 Z8 Discussion 5 28th February 2007 10:54 PM
Squeaking front control arm bushings tranck E39 M5 and E52 Z8 Discussion 6 10th October 2006 01:18 PM
