I've performed a search on this, but no other posts seem to answer this question:
Has anyone tried using 255/35-18 front tires on the std BMS M5 front wheels? If so, has it helped understeer?
According to my calculations the OD should be nearly the same as the 245/40-18s. I'm not prone to want to replace 2 rims, etc etc to reduce the understeer and since I'm approaching front tire replacement time(and rears as well,) I was looking into my options.
Experience or advice will be appreciated.
JesseM
[b]2006 M5 Sapphire Black,Indi red, HUD, rear bags, fold seats, comfort access, BBS RG-Rs,265/35 -285/35, Dinan front & rear roll control 45K Miles
2003 Silver 325XiT
2003 Black Infiniti G35 Coupe
2005 BMW K12S(<8min N'ring)
Vintage Triumph m/c's(110 rwhp/liter -w/pushrods)
Take a look at the recommended rim width for each tire size. If I recall correctly, the recommended width for the stock 245-40 tire is 8.5 inches. Thus the factory tire selection for the M5 is already a little oversized for the wheel, and IMHO contributes to the understeer issue on the M5.
Dick is correct. A wider tire on the same rim would not perform as well. It would tend to roll under more when cornering and it would be harder to keep the tread flat when varying the tire pressures.
If you want to keep the same rims, you would be better off adding some negative camber to the front to decrease understeer.
-Bart
2002 Bluewater/caramel
Any other car is a compromise
I was looking at the Rim Width Range column as opposed to the measured rim width on Michelins tire sizing table. I always wondered how they could make a very low profile tire that would fit a range of rim widths and work as designed. Since I'm not looking to reduce tire wear, I think I'll stay with what I've got and not add any - camber either. Oh well, just looking for a cheaper solution.
JesseM
2003 Silver 325XiT
