Please help me :-( - Page 3 - BMW M5 Forum and M6 Forums
Old 30th April 2011, 15:27   #21
Sailor24
Sailor24's Avatar
Garage: 2000 Anthracite,
Originally Posted by pyro225 View Post
Wow! Thanks for your support it's much appreciated ... Two of the post admittedly could be merger one was a completely separate query ! The propane conversion is 100% irrelevant as I have physically taken the propane Ecu out and restored the stock harness until its fixed so yes when it's not on there I do see it as being irrelevant!!!
You are wrong, the propane conversion is still a huge issue. In order to do that conversion a lot of things get changed. The big one is that they can reflash your computer back to OBDI instead of OBDII (at least in Canada). That is about the biggest issue you can have. There will be other things done too. Propane burns cleaner than gas and the by products are different (read what comes out the pipes).
If you want the right answer you have to give all the info, not little bits and pieces. Your problem will be the changed info in the ECM. If you don't tell people the car had propane then they would not even think about that possibility.
Your limp problem is more than likely as result of pulling the propane computer. The second computer would have tables for looking up values. So now when ECM 1 looks for a value the table it is looking for is not there, because the 2nd ECM is not.
Sailor24 is online now   Reply With Quote
The Following User Says Thank You to Sailor24 For This Useful Post:
ard (30th April 2011)
Old 30th April 2011, 20:25   #22
nightkrawler
nightkrawler's Avatar
Garage: 03' M5
Sales Feedback: (3)
yes, as i said he needs to get the dme reflashed back to stock.
nightkrawler is offline   Reply With Quote
Old 2nd May 2011, 18:14   #23
Sailor24
Sailor24's Avatar
Did not see yours till after I posted. Good call
Old 2nd May 2011, 21:04   #24
pyro225
Garage: E39 M5 No 3 | E63 M6 No ?
Ok checked my system - its only two years old and checked with the fitter its ecu is NOT reflashed - the system simply switchs the petrol injectors to gas injectors and thatgs pretty much it lets the stock ecu do the hard work... if you dont believe me google Romano RISN and you will see they have come on a hell of a long way...
The limp mode also happened as a result of trying to repair some broken lambda wirining, i pulled the propan system long after to check that it wasnt anything to do with... Whenever you mention propane people assume its that....
anyway slight progress......
Todays i have spent the day wiring the sensors as per the wiring diagram from WDS... The heating elements are still coming up as faults however i know these arent necessary to work , the signal is coming backi believe as the voltages are now fluctuating, but its still going into limp mode any ideas? below is the error history and some inpa screen grabs....:
Version:0.9 StartHtml: 105 EndHtml: 13804 StartFragment: 334 EndFragment: 13772
E R R O R M E M O R Y R E P O R T -------------------------------------
Date: 05/02/11 19:19:03 ECU: MSS52DS1 JobStatus: OKAY Variant: MSS52DS1-------------------------------------------------------------
RESULT: 6 errors in error memory !-------------------------------------------------------------
230 EGAS-Nominal/actual-comparison
Error frequency : 1 Logistic counter: 40
Condition of EGAS 4.00 - EDK actuator value 96.00 % Cooling water temp. 78.00 degrees C Supplier voltage HR 13.30 V aufgetreten vor (rel. BZ) 10.00 km
Nominal value not reached Error not present Sporadic error-------------------------------------------------------------
129 internal index 73
Error frequency : 2 Logistic counter: 40
Error occured 1. times at:
Engine speed 5640.00 rpm relative filling 44.80 % Cooling water temp. -11.00 degrees C Supplier voltage HR 25.10 V aufgetreten vor (rel. BZ) 10.00 km
Error occured 2. times at:
Engine speed 2400.00 rpm relative filling 100.00 % Cooling water temp. -29.00 degrees C Supplier voltage HR 25.40 V aufgetreten vor (rel. BZ) 10.00 km
1000 - Condition / value implausible / over-temperature Error not present Sporadic error-------------------------------------------------------------
37 Lambda sensor heating 1 before cat.
Engine speed 680.00 rpm relative filling 24.80 % Sensor heating resistor 1 before cat 25.50 Ohm Supplier voltage HR 13.70 V aufgetreten vor (rel. BZ) 10.00 km
0100 - Broken wire / Value missing OBD exhaust relevant error Error present
[IMG]file:///C:/Users/dan.wilderspin/AppData/LocalLow/Temp/Microsoft/OPC/DDT.oai8l8w8bfkjyzg30uctq7kxe.tmp[/IMG]
Static error-------------------------------------------------------------
38 Lambda sensor heating 2 before cat.
Engine speed 680.00 rpm relative filling 24.80 % Sensor heating resistor 2 before cat 25.50 Ohm Supplier voltage HR 13.70 V aufgetreten vor (rel. BZ) 10.00 km
0100 - Broken wire / Value missing OBD exhaust relevant error Error present Static error-------------------------------------------------------------
39 Lambda sensor heating 1 after cat.
Engine speed 680.00 rpm relative filling 20.00 % Sensor heating resistor 1 after cat 25.50 Ohm Supplier voltage HR 13.70 V aufgetreten vor (rel. BZ) 10.00 km
0100 - Broken wire / Value missing Error present Static error-------------------------------------------------------------
40 Lambda sensor heating 2 after cat.
Engine speed 680.00 rpm relative filling 20.00 % Sensor heating resistor 2 after cat 25.50 Ohm Supplier voltage HR 13.70 V aufgetreten vor (rel. BZ) 10.00 km
0100 - Broken wire / Value missing Error present Static error =======================================
Idling screen shot after a few mins they all settle down around the same area...
at 1500rpm...
Any ideas why id still be limping?
pyro225 is offline   Reply With Quote
Old 2nd May 2011, 21:19   #25
vantaam5
vantaam5's Avatar
Garage: 2003 M5 matte black
Looking at the coolant temps,they suddenly go negative....
Is your ECU flashed back to stock yet?
-rebuild in winter 2011/2012
"submarine edition",a bit boost and some M5 parts...
vantaam5 is offline   Reply With Quote
Old 2nd May 2011, 21:57   #26
pyro225
No and TBH i only posted that as an update really to see if anything stood out.. its booked in for this week for latest firmware to be flashed on and set back to stock ... that right yea?
Old 2nd May 2011, 23:30   #27
ard
Super Moderator
ard's Avatar
Any chance the fuse for the O2 sensor pre-heat has been blown? Fuse should be under the ebox as I recall.
Old 2nd May 2011, 23:47   #28
pyro225
Cheers ARD.. it was blown before i rewired it all in today...i switched it for a new one and its still reading like that and the fuse hasnt reblown...
Old 3rd May 2011, 00:54   #29
Sailor24
Sailor24's Avatar
Have you checked to see if you have volts for the heaters at the plugs? Have you checked for a ground?
Temps look strange even the hottest mentioned at 78 may not close the fuel loop status?
Old 3rd May 2011, 21:52   #30
pyro225
hmm... didnt realize they were minus figures on that obscure error... might disconnect the water temp sensor to test it when tht not in unless that sounds dumb?
