Idler pulley failure? - BMW M5 Forum and M6 Forums
post #1 of 5 Old 18th April 2011, 05:18 PM Thread Starter
bono
bono's Avatar
Has anyone ever experienced failure of the belt pulleys? Or indeed changed them.
It has been suggested some new engine noises I have could be a pulley on the way out and I'd be interested to know if anyone knows the symptoms of a pulley failure.
Matt
E61 M5
E39 M5
MV F4 1000R
bono is offline
post #2 of 5 Old 18th April 2011, 05:22 PM
feeblebob
feeblebob's Avatar
Examples of the noise you're getting, perhaps a vid? Or am I missing that you've posted this elsewhere.
I've had a pulley bearing collapse before, straight after a 300 mile drive, so they can fail over time. On my list.
I think when I priced these up, they're not too much, good to do them while doing the belts
2001 E39 M5 : Silverstone Blue, 19" Breyton Spirits (horribly rashed...Genuine BBS LM's to go on), Philips Silverline Indicator Bulbs, Intravee II and Alpine KCA-420i (in a box in the house) and 160GB iPod Classic , Evolve headers and race cats to go on, otherwise standard at the mo...
"I look at it like this. Owning an M5 is kind of like dating a slamming hot big-t...ed blonde, who is a pain in the *****, drains your cash, but screws like there's no tomorrow. Owning a Honda Civic or the like, is akin to dating a girl who is fat, ugly, smells a bit where she shouldn't, is a cheap date and doesn't screw at all (you don't mind). So yeah, I'll take the blonde." (Courtsey of Jetpilot718)
The thread of my car and it's progression to mechanical perfection... : http://www.m5board.com/vbulletin/e39...ry-thread.html if I ever get around to anything...
Cabin Filters 6/3/11, Bosch wipers 21/5/11, OEM air filters 24/5/11 (110,920), Oil Change, Oil Seperators and Thermostat 07/08/11 (112,699), Final Stage Resistor, Coolant Temp Sensor, Silvered Indicator Bulbs 21/08/11 (114,110), Private Plate 23/10/11, Came home from storage 13/02/13
feeblebob is offline
post #3 of 5 Old 18th April 2011, 05:55 PM Thread Starter
bono
bono's Avatar
I will see about sorting a video, the noise is a rattle at certain rpm which then turns into a metallic screech if left.
I was thinking the worst -> timing chain, but it was suggested it could be a pulley failing.
Matt
E61 M5
E39 M5
MV F4 1000R
bono is offline
post #4 of 5 Old 19th April 2011, 12:51 AM
mgdmb
mgdmb's Avatar
They fail... sometimes at 85 or 90 miles an hour, throwing the serpentine belt into the radiator fan in the process, destroying it. And taking the the water pump out at the same time, just for good measure. Bonus points for a fan blade happening to hit just right such that it cuts through the fire blanket and leaves a 3/8" dent in the hood. Spared the radiator.
That was fun.
mgdmb is offline
post #5 of 5 Old 19th April 2011, 12:57 AM
trbo930
trbo930's Avatar
It is probably best to replaced all the idler & tensioner pulleys when doing the belts. I see these type of failures all the time.
Real easy way to check is to get an inexpensive stethoscope & listen on the area the pulleys are bolted to. Just be careful not to hit the fan with the engine running!
trbo930 is offline
How to change steering idler arm bushing vantaam5 E39 M5 and E52 Z8 Discussion 29 29th September 2014 02:28 PM
Supercharger Belts and Tensioner/Idler Pulleys herrubermensch E39 M5 and E52 Z8 Discussion 7 10th August 2010 09:14 PM
Evosport Pulley Installed....First Impressions. +Headlight Failure! polar993 E60 M5 and E61 M5 Touring Discussion 10 26th August 2007 11:32 AM
Noisy Idler Pulley Replacement AustralianM5 E39 M5 and E52 Z8 Discussion 3 21st August 2006 03:20 AM
Air con drive belt idler AliveM5 E34 M5 Discussion 1 28th October 2005 12:25 AM
