Coolant capacity - BMW M5 Forum and M6 Forums
 2Likes
  • 1 Post By ger
  • 1 Post By Burnout_187
post #1 of 4 Old 6th April 2011, 10:53 PM Thread Starter
ger
ger's Avatar
Coolant capacity
I want to get some fresh antifreeze and I was wondering how much I should get.
Naturally, I searched the forum for a quick answer.
I found plenty of threads about changing, flushing and bleeding the coolant and changing the thermostat but I couldn't quickly find one that said how much coolant the e39 M5 takes.
In the end I had to dig out my handbook and found the answer, so here it is:
The M5 takes 12 litres of coolant. This is for all e39 M5 models, early and facelift. By coolant, I mean the mix of water and antifreeze (50/50 usually).
I take it that 12l will fill an empty system. If you don't drain the block, less will be required.
I hope this post will prove useful to someone who turns to the forum for the information. I apologise if it duplicates anything, but I did search for some time with little luck!
Coolant flush next up
11/2000 M5 Le Mans Blue
My car's thread
ger is offline
post #2 of 4 Old 6th April 2011, 11:16 PM
Burnout_187
Burnout_187's Avatar
Additional Information for Vehicle code DE91
ProductionFROM : 1998/09/01 TO : 2003/05/31
EngineS62
Engine Oil6.50 Liter
TransmissionManual
Transmission ModelS6S 420G
Transmission Oil1.75 Liter
Rear Axle Oil1.60 Liter
Coolant(w/o Air Conditioner)0.00 Liter
Coolant(with Air Conditioner)12.75 Liter
Brake fluid1.00 Liter
Burnout_187 is offline
The Following User Says Thank You to Burnout_187 For This Useful Post:
JDMM5 (30th June 2014)
post #3 of 4 Old 7th April 2011, 12:17 AM
/// M5
/// M5's Avatar
I've replaced my coolant twice since taking ownership and both times have got out exactly 10 litres.
This is by opening up at the radiator drain and both engine block drains.
The extra few remaining litres must be in pipework and probably the heater matrix...
/// M5 is offline
post #4 of 4 Old 7th April 2011, 01:05 AM
vantaam5
Get about 11.5l in the coolant system when engine is dry and removed.
And about 9-9.5l oil...
vantaam5 is offline
Oil capacity on E39 m5 richardspeed E39 M5 and E52 Z8 Discussion 46 29th June 2013 09:08 PM
b36 engine oil capacity Fordkoppie E34 M5 Discussion 7 10th August 2010 08:59 PM
Towing capacity of M5 daytonaM5 E34 M5 Discussion 10 15th October 2008 01:48 PM
Oil Capacity Mark E39 M5 and E52 Z8 Discussion 6 15th December 2001 07:03 AM
Fuel Capacity BAHNBOMB E39 M5 and E52 Z8 Discussion 5 29th September 2001 12:46 PM
