Service engine soon light - BMW M5 Forum and M6 Forums
Old 28th May 2002, 00:50   #1
Jim Dolan
Jim Dolan's Avatar
Garage: 2006 M5 Silver Grey Metallic
Service light is on and the car was serviced two thousand miles ago and has only 11,800 miles on it. Surprised me..
Has it happened to you?
Jim
2006 Silver Gray Metallic over Black
The "Wolf in Sheeps Clothing" is back in the USA again
1971 2002 Colorado(Light Orange)
1976 2002 Inka(Red orange, a classic)
1982 528e Blue metallic
1984 533i Burgandy
1987 325i Alpine white
1988 535is Salmon silver
1993 525iT Calypso red
1999 528iT Titanium silver
2000 M5 Titanium silver
2006 M5 Silvergray Metallic
2011 Toy Land Cruiser Classic Silver
2013 BMW X3 2.8i Sparkling Bronze/Chestnut: Premium, Tech and Sat
Jim Dolan is offline   Reply With Quote
Old 28th May 2002, 14:19   #2
AdAgent
AdAgent's Avatar
Garage: Sterling Grey E39 M5
Jim,
It happened to me the other day while driving home. It since has turned off, turned on, turned off and finally back on as of yesterday. I have an appointment with my dealer this morning hopefully fix the problem. I'll keep you posted. Good luck
PS. Mine was serviced about 2k miles ago as well (9200 mi on her now).
Alex
2002 Sterling Grey M5
320HP 2000 Audi S4
1997 Land Rover Discovery
AdAgent is offline   Reply With Quote
Old 28th May 2002, 16:53   #3
brutus
brutus's Avatar
Garage: '06 E60 M5 Black Sapphire Metallic / Inianapolis Red Full Leather
I recently had my "service engine soon" light go on, check the fuel cap and/or fill up with fuel and the light would go out after 1 ro 2 restarts. This happened 5 or 6 times before I called for a service appointment.
Turned out to be an Oxygen Sensor, looks like it's fixed it as I've gone through a tank of fuel without a repeat.
Brutus.
brutus is online now   Reply With Quote
Old 28th May 2002, 17:24   #4
PhilSeastrand
PhilSeastrand's Avatar
Garage: 2001 M5 Silverstone/Silverstone
Keep in mind that the SES light is really only reporting emissions problems. It does not necessarily mean there is something wrong with the engine itself.
Phil
2010 Toyota Prius
2004 Honda Pilot
PhilSeastrand is offline   Reply With Quote
Old 28th May 2002, 18:08   #5
brad
brad's Avatar
Garage: 2000 M5, Anthracite, Black int.
could be O2 sensor
I just had my 2000 in for an oil change at 18K miles and the SES light was on. They replaced a bad O2 sensor and said that was the cause of the SES light.
-Brad
brad is offline   Reply With Quote
Old 28th May 2002, 19:22   #6
AdAgent
AdAgent's Avatar
I just got back from my dealership after they checked the SES light. Apparently it is a bad VANOS that needs to be replaced . I know this is a common problem so hopefully the fix will go well tomorrow morning. I'll keep you all posted.
Alex
Old 28th May 2002, 20:23   #7
Silverstreak
Silverstreak's Avatar
Garage: 2007 M5, Silverstone Metallic
Mine is a 12/99. At 12k the SES light went on - dealer claimed they had to reprogram the computer - I was running to lean.
Silverstreak is offline   Reply With Quote
Old 28th May 2002, 20:56   #8
Aussie2U
Aussie2U's Avatar
Garage: 2000 Avus Blue M5
Jim,
Can you tell a difference in performance? When mine went on, you could instantly hear a different exhaust sound and there was lack of power in the upper end. The exhaust sound was like the car had nasal congestion. It would go off 3-4 days later and be back to normal for a week or so, then pop back on. (It's at the dealer now, so say hi to mine if yours is going in. )
The dealer always says check the gas cap for venting and call him back a week later, but I think I can count on one hand how many cases have actually turned out to be that.
Aussie2U is offline   Reply With Quote
Old 28th May 2002, 21:41   #9
Jim Dolan
Jim Dolan's Avatar
Called for an appointment this am and the dealer said to take off the gas cap and restart it a couple of times and give it a couple of days. Rick I saw no change like you discribe. I had just filled up the tank before I recall it coming on. Hopefully that is all it is.
Old 28th May 2002, 23:16   #10
JFB
JFB's Avatar
Garage: 2001 M5 Royal Red / Caramel / Burl
Jim
My SES came on at around 13K miles. Tightening the cap worked once, but the problem kept recurring. The light was intermittent, with no discernable pattern.
The dealership diagnosed a fuel (vapor recovery) system problem and replaced a breather valve. They had the car 3 days, because the part had to be shipped in, but that seems to have solved the problem.
Jim
2001 ///M5 Royal Red / Caramel
JFB is offline   Reply With Quote
Nowack Tuning Report, The Truth (Long Version) CharlesW E39 M5 and E52 Z8 Discussion 90 2nd September 2011 09:49
Nowack Tuning Report, The Truth (Long Version) CharlesW Most Memorable Threads' 44 30th November 2002 04:49
Engine Service Soon Light HighM5 E39 M5 and E52 Z8 Discussion 4 11th July 2002 16:54
just got 'service engine soon light' beanboy E39 M5 and E52 Z8 Discussion 7 21st March 2002 05:05
Reason for 'service engine soon' light BostonRocket E39 M5 and E52 Z8 Discussion 6 9th November 2001 05:13
