Originally posted by steve adams
there was an earlier metnion of Eiro spec M5's using floating rotors ...
what are "floating rotors" and how are they different than US spec M5 brakes...?
I've had problems with vibration in my brakes (cementite buildup or warp-age according to previous posts) ... I dont track the car, but do not baby it either ...
Korman (tuner in Greensboro NC) suggested "aluminum" core rotors that have remedied problems in the M3 series ...
I have requested the dealer to determine if the aluminum rotors are an option for the M5 ... how does this tie into "Floating rotors"?
Thanks for your help,
Korman is probably referring to the European M5 "floating" rotors which use steel pins
sticking out of an aluminum center hat to hold the iron rotor in place. The pins allow radial
expansion of the rotor relative to the hat (since aluminum and iron expand and contract
with temperature at different rates). They also reduce the amount of heat transferred to
the wheel bearings.
Photos courtesy StopTech, LLC
In the real world, the Euro rotors have had problems with pins seizing up in the iron rotor,
causing uneven stress, cracking of hats, or warping of rotors. European M5s have been
known to suffer from vibration problems following high speed driving on the Autobahn,
let alone the race track. Recently, BMW AG recommended that European drivers with rotor
problems switch to the American 1-piece rotor design.
In other words, the Euro rotor may not be an "upgrade" for you at all. If you are interested
in increasing the capacity of your braking system, you should consider an aftermarket kit
such as StopTech.
Harold Chang's brakes
RaveM5's brakes prior to the StopTech caliper bridge being bolted in. Note stock caliper on floor below
