Old 11th May 2002, 01:07   #1
atomic80
M5 Extraordinare!
atomic80's Avatar
Garage: 2007 Cobalt Blue Porsche 997TT
Stoptech's are on! Impressions! (Writeup)
A little history to begin things off. In the past, I have had the opportunity to drive two world class sports cars, a corvette and a supra twin turbo. Both are very capable cars but they are ultimately sports cars. This was followed by the my quest for the perfect car which eventually led me to the M5! Many will argue that the M5 is one of the most perfect automotive piece of engineering ever to come out of fatherland Germany. No doubt I agree with this sentiment. However, there were a number of weakness in which I felt the M5 could be improved upon. They were the handling dynamics and its stopping capabilities. The M5 far from being lacking in either department could use some help. I found my answer for the handling issue with the use of Dinan's own suspension components. Next were the brakes. I explored a number of options available from Brembo, Movits and Stoptech. Thanks to the many folks on this board I was able to conclude that I did not want a big brake kit that made the use of spacers. I also wanted to retain the use of my stock wheels as well. The only solution presented itself in the form of Stoptech's. Stoptech is the only option for those of you that want to retain the stock wheels without using spacers.
Now that Stoptech's were what I wanted, I needed to find a source for those big brake kits. By dumb luck I happened to come across a tip which led me to find a set for a price that I just could not pass up! I managed to get the big brakes, the extra stainless steel lines for the rear brakes, paint my rear calipers and labor all for a good price. PM me if you want to know. A heckuva deal to say the very least!
This was last month. After I got back from the M5 DE I decided to go ahead with getting the big brakes! I contacted the shop and had them order the kit! It didn't take very long for them to arrive and so the date was set for May 7th. I would swing by the shop and watch them install the brakes. It would take about 2 days for them to finish the job since the paint on the rear calipers needed time to fully cure.
The day arrived...
Stopping by the shop, I found this. Big metallic and RED!
Time to put my M5 on jacks. She's all ready to go. One observation that I happened to make was how light the stock wheels were. They're amazingly light yet strong.
As you can clearly see in this picture, the stock calipers only have ONE piston! I don't care what the folks at BMW say, I don't think that a 4000 pound performance sedan deserves such a wimpy setup.
Time to fix that!
This is what it looks like with no rotors.
A note for those who are curious about the stock rotors. It's VERY heavy! I happened to check out the weight of the new Stoptech's. They're definitely lighter. The stock rotors are one piece, cast iron. The Stoptech rotors are two pieces, aluminum hat with cast iron rotors.
I won't go into details on the actual installation since that was covered extensively in great detail by DZeckhausen.
Such a lovely setup.
The new brake calipers and rotors were all in place and now it was time for them to remove the rear wheels and calipers. I didn't stay for this so no pictures from that.
The car remained in the shop for the next two days since it took them three tries before they managed to get the paint on the rear calipers to match the front calipers. This was finished up with some high heat clear coat! Looks great!
The M5 went to the dealership from the tuner shop to have a special ordered part installed. Apparently when the technician was installing the suspension parts, he happened to "break" a small clip.
The day finally came when everything was all finished. I picked my M5 up from the dealership and I sported the biggest grin ever upon seeing those massive new brakes! Not a bad job they've done! They still needed to break them in.
According to the shop, the proper break-in procedure was to drive at approximately 40-50 mph followed by hard braking down to about 5 mph before releasing the brakes. I was told NOT to hold the brake as the pads would stick to the rotors. Also, the hard braking would have to be done without activating the ABS. I would have to do this 8-10 times. Sounded simple enough I thought. When I tried doing it...making sure nobody was behind me, I found that I kept invoking the ABS! Those brakes are STRONG! The pedal also definitely felt firmer! I love it already! So, the next few times I made extra sure not to invoke ABS again. At stoplights I used the e-brake handle to keep the car in place. I was now one very happy man! The final note was that the true potential of those new brakes would not be felt for another 100 miles after they've been fully broken in. I can't wait! These brakes make the M5 literally stop on a dime!
The best part is that the brake dust have now been almost completely eliminated! There is very little dust coming out now.
A couple more pictures....
Big massive red calipers.
Ready for a drive?
Profile shot.
It was such a beautiful day that I just could not resist taking this last shot.
To conclude things, I'd like to say that those of you looking to improve the M5's stopping capabilities should consider taking a look at Stoptech's!
Jason
'05 Range Rover w/mods
'05 K1200S w/mods
'07 997TT w/mods
'08 Audi A3 w/mods
atomic80 is offline
Old 11th May 2002, 01:11   #2
Diamond Dave
Diamond Dave's Avatar
Garage: 2000 Ford Expedition
Jason,
Give me a break! Another great post and superlative pics my good man. I agree that those stock brakes are wimpy! Can't believe BMW engineering there!
You have the SS lines at all four corners now, right? Also, tell us how the pedal feels, what brake fluid you used, etc...
Fabulous!
DWP
Diamond Dave is offline
Old 11th May 2002, 01:17   #3
atomic80
M5 Extraordinare!
atomic80's Avatar
Dave,
Yes, I do have SS lines on all four corners now! That definitely helped firm up the brake pedal although not to the point where it feels as stiff as pedals in a race car. The feel is improved also. I now feel confident when braking thanks to the improved braking performance complemented by the greater pedal feel.
From what I understand, I now have Motul DOT 5.1 brake fluids in the car and the Stoptech's uses Axxis semi-organic pads. I haven't noticed any squealing issues with these pads.
Jason
'05 K1200S w/mods
'07 997TT w/mods
'08 Audi A3 w/mods
atomic80 is offline
Old 11th May 2002, 01:17   #4
RAREM5
RAREM5's Avatar
Garage: 2001 DINAN M5
Send a message via AIM to RAREM5
WOW
Very Nice Jason!
Now I need to bump up brakes on my mod list. Perhaps make more money.
Sang
RARE ///M5
2001 LMB DINAN ///M5 Gone but never forgotten!
2005 Honda S2000 (Silverstone/Black)
2005 Ducati 749S (Red)
RAREM5 is offline
Old 11th May 2002, 01:22   #5
Diamond Dave
Sang
I want your frequent flier miles!!!
DWP
Old 11th May 2002, 04:55   #6
RAREM5
RAREM5's Avatar
Originally posted by Diamond Dave
Sang
DWP
Dave,
Hope to meet up again in June. Would you like to see the president?
Sang
RARE ///M5
RAREM5 is offline
Old 11th May 2002, 05:45   #7
ALX
ALX's Avatar
Garage: 2007 X3 Sterling Grey Metallic
Send a message via AIM to ALX Send a message via Yahoo to ALX
Fabulous post Jason! Congrats on the new brake setup. I look forward to reading your write up after the brakes have been broken in.
ALX
-e46 UUC Rasp-X pipe FOR SALE
-e46 Kelleners 83mm exhaust FOR SALE
2004 M3 Convertible- GONE!
2003 X5- GONE!
2000 M5 Good times, good times.
ALX is offline
Old 11th May 2002, 12:59   #8
Adam
Adam's Avatar
Garage: R32
Send a message via ICQ to Adam
Excellent impression as usual jason! Oh and the pics werent bad either!
Stop techs look seriously tempting..
all the best
Adam
1995 Alpina B8 4.6 #10-(engine blew up. sold)
2001 BMW ///M5(sold)
2003 RUF R turbo
1990 RUF CTR
2006 VW Golf R32 DSG
2005 e60 M5 (sold)
2007 997 GT3 RS Carrara White
2008 Renault Clio 197
"You know it is kinda ironic, these old people are being kept alive by the organs of the young people they ran over" - Chief Clancy Wiggum
Adam is offline
Old 11th May 2002, 19:47   #9
polvoronn
Garage: none
Send a message via ICQ to polvoronn
Awesome writeup Jason! Youre beast looks gorgeous with those Stoptech's. So what's next on your list of mods? Don't tell us that you're done already
Paolo Gaspar
"Aerodynamics ... is for people who can't build engines"
- Enzo Ferrari
polvoronn is offline
Old 11th May 2002, 20:12   #10
atomic80
M5 Extraordinare!
atomic80's Avatar
Next? What? Are you already thinking ahead for me. Actually I was considering getting cross drilled rotors for the rear brakes but we'll see what comes. Stay tuned!
Jason
'05 K1200S w/mods
'07 997TT w/mods
'08 Audi A3 w/mods
atomic80 is offline
Who's happy with stoptechs and who are interested in them? young-nyc For Sale or Wanted 3 19th September 2003 20:42
Bilstein PSS-9 First impressions msindi Porsche 911 Turbo and Porsche Panamera Forum | panameraboard.com 1 10th August 2003 03:58
DFC and Stoptechs installed TriflowM5+M3 E39 M5 and E52 Z8 Discussion 24 26th July 2003 16:47
Tech: StopTechs & AXXIS Pads BarryC E39 M5 and E52 Z8 Discussion 0 13th November 2002 04:51
Stop tech Big brakes or Brembo. Rave E55 E39 M5 and E52 Z8 Discussion 0 15th January 2002 04:32
Page generated in 0.18626 seconds with 11 queries
