Old 10th May 2002, 19:55   #1
M5@ksa
Garage: M5 Silver
Send a message via Yahoo to M5@ksa
Angry Static Noise correspond to the revving of the engine
i am going nuts i cant figure it out ..
when i rev the engine i hear some static from the rear left side . i tried turning the stero off but still the noise is there . one other highlight here ............ the inner light goes brighter when i rev ang it kind of flake when it is in study i mean NO rev .
HELP HELP
Sports/Navi/PDC/E-Shades/Premium Sound/BMW MKIII NAV-TV Kit +Reverse Camera System, Head rest M power patches,rear wing, Motorola GSM v8088 with BMW software
Dinan Free Flow Exhaust , Dinan Final Drive Gearing, Dinan Cold Air Intake, Dinan Tower Braces, Kelleners ECU-tuning, KW Variant 2 Coilovers, G-POWER clutch,G-POWER antiroll bar kit, look alike Nowak Air Ducts, UCC short shifter, Clutch Stoper
M5@ksa is offline
Old 10th May 2002, 23:20   #2
lear
lear's Avatar
Garage: 2000 Tit. Silv.
Can't help you with the revving noise. However I have noticed that my interior lights also fluctuate. I guess it is an electronics problem in that the output of the alternator is not sufficient or maybe isn't regulated correctly. While my passengers think I am crazy as they say it is hardly noticeable I just go nuts at night! I have seen this problem on a Cadillac and man was it a PITA. The SA of course wanted to keep the caddy so they could drive it at night and see what I was talking about. I have not approached the BMW folks but if they think I would let them keep my car for a night to go out and find a problem I think I may try and figure something else out.
lear is offline
Old 11th May 2002, 00:10   #3
greg
greg's Avatar
Garage: 2000 Anthracite
the brightness thing is normal. The alternator can't keep up with the current draw of the headlights, taillights, interior lights, computers, radios, etc - at idle. So at that point you're drawing on the battery and the voltage drops, causing the dimming effect you see. As soon as you get into anything resembling cruising revs, the alternator is making its full output, which is more than enough to run the electricals AND charge the battery. When the battery is receiving a surplus of current as opposed to being drained, the voltage is significantly higher - as high as 14.2V - while at rest and with a big load it might drop to 12.5V or less.
greg is offline
Old 11th May 2002, 03:32   #4
Jim Dolan
Jim Dolan's Avatar
Garage: 2006 M5 Silver Grey Metallic
While we're on the subject, I have noise in the AM mode of the radio from engine revs and going over sharp bumps in the road. That sounds like a click. They have a fix for this, usually putting a filter in the line from the ground to the radio or in the pos line. Anyone have this happen to you?
Jim
2006 Silver Gray Metallic over Black
The "Wolf in Sheeps Clothing" is back in the USA again
1971 2002 Colorado(Light Orange)
1976 2002 Inka(Red orange, a classic)
1982 528e Blue metallic
1984 533i Burgandy
1987 325i Alpine white
1988 535is Salmon silver
1993 525iT Calypso red
1999 528iT Titanium silver
2000 M5 Titanium silver
2006 M5 Silvergray
Jim Dolan is offline
Old 11th May 2002, 04:12   #5
tonyo
tonyo's Avatar
Garage: 2008 Space Gray M5
My AM radio clicks when running over manhole covers, even when they seem to be perfectly smooth with the roadway. I've wondered if it's a static discharge or just a particular type of bump impulse that makes the radio click. It doesn't seem to do it on rough pavement, just manhole covers.
'08 E60 Space Gray M5
'01 E39 Le Mans Blue M5
'99 550 Maranello
'98 Supra
tonyo is offline
Old 11th May 2002, 15:05   #6
Jim Dolan
Jim Dolan's Avatar
tonyo, I'll have to check that.
Nowack Tuning Report, The Truth (Long Version) CharlesW E39 M5 and E52 Z8 Discussion 62 28th December 2009 22:44
Nowack Tuning Report, The Truth (Long Version) CharlesW Most Memorable Threads' 44 30th November 2002 05:49
Static Noise correspond to the revving of the engine M5@ksa E39 M5 and E52 Z8 Discussion 2 10th May 2002 21:36
SL 55 vs Z8 at the Nurburgring! mmunson E39 M5 and E52 Z8 Discussion 64 21st April 2002 02:42
Page generated in 0.16403 seconds with 11 queries
