• Latest threads
    • Custom feed
      • Updates
        Old 9th May 2002, 23:01   #1 (permalink)
        MichaelJP
        Any way of turning off headlamp wash?
        This is a pretty minor thing, but it does irritate me that every so often when you're washing the windscreen (windshield for the US guys!) the auto headlamp wash squirts out. This is bad when you've just had the car washed and waxed as it can leave spotting all over the paint when it dries!
        Anyone else have this problem and did you do anything about it? I've considered disabling headlamp wash as they never get dirty enough to need it.
        - Michael
        MichaelJP is offline
        Old 9th May 2002, 23:46   #2 (permalink)
        tfung
        tfung's Avatar
        If you jab at the windshield washer stick quickly instead of holding it down, it would just activate the windscreen washers and not the headlamp ones...
        US Spec 2001 E39 M5 - LHD
        AC Schnitzer
        Dinan
        3.45 differential
        Others
        Euro Spec 1999 E39 M5 - RHD
        2007 Mercedes E63
        2007 Corvette Z06
        2008 Nissan GTR
        tfung is offline
        Old 9th May 2002, 23:48   #3 (permalink)
        PhilSeastrand
        PhilSeastrand's Avatar
        Send a message via MSN to PhilSeastrand Send a message via Yahoo to PhilSeastrand
        1) empty the reservoir for the high-pressure washer
        2) pull the wire connected to the pump (have no idea where it is)
        Phil
        01 M5 Silverstone/Silverstone
        04 Honda Pilot
        02 Indi Blue Mini Cooper (sold )
        PhilSeastrand is offline
        Old 9th May 2002, 23:55   #4 (permalink)
        Diamond Dave
        Diamond Dave's Avatar
        When I installed the Dinan cold air intake (CAI) I had to pull off the entire front bumper. Had to disconnect the tubes that take the fluid to the headlamp washers. You could always pull those off and insert a golf tee to keep them from dripping fluid.
        Having said that, I think Tfung is correct. His recommendation is a lot less invasive! In either event take care of that windscreen! I can't stand it when mine is dirty...
        DWP
        Diamond Dave is offline
        Old 10th May 2002, 03:50   #5 (permalink)
        thompsw
        thompsw's Avatar
        Don't they only squirt when the lights are turned on ? or is that the only time that I notice them !
        thompsw is offline
        Old 10th May 2002, 06:00   #6 (permalink)
        BostonRocket
        BostonRocket's Avatar
        Send a message via ICQ to BostonRocket
        I do what Tfung does, just pull back in little spurts and then I turn on the wiper to clear it.
        Does the headlamp washer spray if the headlights are off?
        'Rocket
        H&R Springs
        GONE - 2003 TiAg/Black E39 M5
        GONE - 2001 TiAg/Black E39 M5
        BostonRocket is offline
        Old 10th May 2002, 07:04   #7 (permalink)
        Chris Foote
        Chris Foote's Avatar
        You have two options to activate the headlamp washers
        1) Every 5th time you press the Windshield wiper stalk towards you, the headlight washers activate (at least thats what the X5 does)
        2) If you press the button on the side of the stalk IN (towards the steering column), a enhanced washing system will activate, and the headlight washers will do their thing.
        I agree, the headlight washers are a PITA....nice gimmick BMW
        -Chris
        '00 M5 Anthracite - Imola Red/Black, bone stock, 11,000 miles (Yep she's a garage queen)
        Chris Foote is offline
        Old 10th May 2002, 07:30   #8 (permalink)
        foreman
        spray
        I do believe there is a fuse just for the headlight washers.
        foreman
        foreman is offline
        Old 10th May 2002, 11:11   #9 (permalink)
        MichaelJP
        Originally posted by Chris Foote
        Every 5th time you press the Windshield wiper stalk towards you, the headlight washers activate (at least thats what the X5 does)-Chris
        Yep, that's what my M5 does
        I think I'll look for that fuse, or empty the reservoir (unless that leads to the display pinging at me everytime I switch on!)
        - Michael
        Old 10th May 2002, 12:07   #10 (permalink)
        DZeckhausen
        DZeckhausen's Avatar
        Send a message via AIM to DZeckhausen
        The headlight washer uses the same reservoir (located behind the fender liner just aft of the right front wheel) as the windshield washer system. Same tank, different pumps. The "intensive wash" system is independant of this tank.
        Running your resevoir down will result in a low reservoir warning.
        The operation of the headlight washer is controlled by the general module (located in the passenger footwell area) which sends a ground signal down the blue/black wire to pin 9 on the headlamp washer module every 5th time you use your windshield washer with headlights on.
        If you want to convert your headlamp washer to manual-only operation, you can cut the blue/black wire and then attach a momentary contact switch between the brown ground wire going to pin 8 and the blue/black wire you just cut leading into pin 9.
        Jim Cash, on the E39 board, purchased an extra "ASC" button for this purpose and calls it his "Auxiliary Squirt Control!"
        Dave Zeckhausen
        Owner, Zeckhausen Racing
        2001 540i 6-Speed
        StopTech 4-wheel big brake upgrade (ST40 front/ST22 rear)
        M5 Front Swaybar
        Dinan Stage 3 Suspension
        Dinan Front Strut Tower Brace
        European Dash Conversion
        CDV Deleted (of course!)
        Bluetooth, NAV-TV, DVD Player
        2006 Chrysler 300C SRT8
        2007 Corvette Z51 Coupe 6-Speed
        2009 Honda Fit Sport w/NAV
        DZeckhausen is offline
        Old 10th May 2002, 17:59   #11 (permalink)
        atomic80
        M5 Extraordinare!
        atomic80's Avatar
        Ok, correct me if I'm wrong. For me if I were to pull back the stalk towards myself, it activates the washer but only for the windshield. But if I were to push the "S" button on the stalk, it automatically starts up a brief wash/wiping by the windshield washer and the headlamp washers. I should try this out but I'm pretty sure that if you just pull back on the stalk, you'd only get washer fluids coming out for the windshield.
        Jason
        '05 Range Rover w/mods
        '05 K1200S w/mods
        '07 997TT w/mods
        atomic80 is offline
