Out of ideas - knock sensor code - BMW M5 Forum and M6 Forums
Old 8th March 2011, 00:47   #1
russap5
russap5's Avatar
Garage: 2001 M5 Jet Black
After my extensive troubles with injectors I now have a knock sensor code that won't go away. I'm pretty sure both sensors are in fine working condition, as these things rarely ever fail. After a lot of investigation, we found a pin that had been pushed out on the connection for the injector and knock sensor harness. Got that all taken care of and thought the problem was solved.
Nope the code is still there.. 46. Car still drives 100%. Not sure what else to do..
Thoughts?
2001 ///M5 Jet Black on Caramel / Alcantara
Dinan
CAI, Dinan Rear Sway Bar, Dinan Front Strut Bar, Dinan Exhaust, Dinan
Brembo GT BBK 355mm Front - 345mm Rear, Evolve Alpha-N Tuning, Walbro 255HP fuel pump,
Ground Control Coilovers, Evolve "Medusa" headers, Magnaflow Cats, SuperSprint X-pipe, Magnaflow 10416 resonators, Beastpower Rear Sway Brackets, Gulf Oil Filter Housing w/ Fluidyne Cooler,
Custom Fluidyne Power Steering Cooler,
Linea Corse Z2S 19" wheels w/ Continental DW tires, EVO U/D Pulleys, Reinforced Rear Subframe, Diff Viton O-rings,
RaceSkids Metal Underbody Panels, Custom Leather/Alcantara steering wheel door panels and front seats, 35% window tint, Valentine One Hardwired, ACS style splitters,
E60 SSK and ZHP Knob, "Shorty" clutch stop w/ start sensor mod, Carbon Fiber Wrapped Interior, BSW subwoofer kit, Competition 6.5" front speakers in custom baffles,
DICE/Intravee II iPod adapter, TEC Cupholder, E90 radio knobs, AC and USB powered plugs installed in center console, Full LED overhaul in cabin/footwells/trunk
DIY Accelerator Pedal Removal
My Custom covered steering wheel
My plug-n-play LED light upgrade
DIY adding AC and USB power outlets
DIY fix squeaking steering wheel adjustments
Shadow Chrome: A closer look
$6 DIY headrest in-car camera mount
M5 DIY for Dummies
russap5 is offline   Reply With Quote
Old 8th March 2011, 01:31   #2
Valley Motorwerks
Company Representative for Valley Motorwerks
Garage: 2001 AW M5
The plastic housing will sometimes crack. Overtorquing will also cause an issue, have they been removed recently?
Valley Motorwerks is offline   Reply With Quote
Old 8th March 2011, 01:39   #3
DesiOC
DesiOC's Avatar
Garage: Anthracite/ Full Extended Caramel M5
I just had the same problem, I had a code on my left bank of cylinders for the knock sensor. I just replaced the sensor and the code has not come back again. I got it done at my Indi for about $700.
Cheers,
DesiOC
(oOO\(llll)(llll)/OOo)
2001 BMW M5
2007 Honda S2000
2013 Lexus RX 350 AWD
"If you are not happy with what you have, you will never be happy with what you want"
DesiOC is offline   Reply With Quote
Old 8th March 2011, 02:08   #4
mattmartindrift
mattmartindrift's Avatar
Garage: 540i
Thoughts?
considering you've ruled out everything else, it's probably the sensor.
Have you done any continuity testing to confirm there isn't a break in the circuit?
mattmartindrift is online now   Reply With Quote
Old 8th March 2011, 03:23   #5
russap5
russap5's Avatar
Thanks for the input guys. Plenum will be torn back off when I can drop the car off again and have it looked at. This better be the last time.
I will make sure it is checked for continuity in the circuit and last resort will probably be replacing the sensor.
DesiOC, they charged you $700 to replace the sensor!? How did they manage to justify that to you?
Old 8th March 2011, 05:53   #6
ard
Super Moderator
ard's Avatar
On another car I had the KS was extraordinarily susceptible to overheat. Once the car was over 8-10 years old, one trip up to near overheat would cause the sensor housing to crack and it was gone. Same deal, pull the plenum, dig it out.
It became part of the standard "pull the plenum and replace all you can" procedure. KSs, vacuum and primary and secondary air lines, plus fuel.
Seems that the E39 M5s will get there too eventually.
A
Old 8th March 2011, 07:10   #7
DesiOC
DesiOC's Avatar
The $700 included parts/labor and a temperature sensor that they replaced as well. My Indi is excellent and the entire bill was taken care of by my warranty company [no deductible]
Old 8th March 2011, 08:09   #8
Valley Motorwerks
Garage: 2001 AW M5
Why do people automatically assume that any posted cost for repair is somehow unfair? Nit Picking, I know...
Walter Ford
President
Valley Motorwerks
916.636.9526
Old 8th March 2011, 15:11   #9
M5 London
M5 London's Avatar
Garage: M5 E39 Supercharged
Thoughts?
Russ,
Originally Posted by M5 London View Post
I think there is a wiring connector for the knock sensors with the main loom towards the back of the cylinder head. It has most like come lose when the injector wiring loom was being manipulated, I reckon.
When there is a knock sensor code, I am sure the DME assumes there is knock and pull timing etc to keep you running safe. But I am surprised you say the car doesn't feel more lethargic....
As I mentioned in your other thread, the Knock Sensor code is almost 100% probable only from the recent work around the injector wiring loom towards the back of your block. There may still be an issue in that area.
On a side note when I got a knock sensor code 45 on a few occasions, I never saw it again after changing all 4 CPS, but I am sure you have done that already.
Good Luck
Kumaran
E39 M5 - ESS Supercharger Kit, Uprated and MONSTER Remapped to 640HP, Van Manen Race Manifolds, Van Manen DeCats, Aeromotive Stealth 340 F/Pump, Bosch Green Giant Injectors, Aquamist HFS-3 with 3 Jets, MONSTER CCV setup with Cobra Pump (2PSI boost switch), Bilstein Sprint Dampers, Intrax Springs, Dinan Adjustable Rear ARB, Stoptech ST40 Big Brake Kit, EBC Yellows, 550i SSK
www.WhatAboutCars.com
M5 London is offline   Reply With Quote
Old 8th March 2011, 16:28   #10
russap5
russap5's Avatar
Yea, I've replaced pretty much every single thing under the plenum. The wiring loom has been very carefully inspected and repaired. Troubleshooting will continue and we will get it figured out.
The Following User Says Thank You to russap5 For This Useful Post:
M5 London (8th March 2011)
Peake code 45 - “Knock sensor, Cyl #5-6” porboy44 E39 M5 and E52 Z8 Discussion 3 2nd September 2009 10:04
Knock Sensor? Norm E39 M5 and E52 Z8 Discussion 4 2nd May 2008 07:15
Reputable Indy in Houston Area(Knock Sensor)? Beasty5 E39 M5 and E52 Z8 Discussion 3 14th September 2007 05:35
Ping (knock) sensor location? Snogard E39 M5 and E52 Z8 Discussion 2 30th May 2006 18:15
Vanos problems--knock sensor Parkerfe E39 M5 and E52 Z8 Discussion 0 29th September 2000 16:16
