Rear Diffuser DIY (PICS) - BMW M5 Forum and M6 Forums
post #1 of 29 Old 27th February 2011, 04:41 AM Thread Starter
D-RodM5
D-RodM5's Avatar
...cuz everything is better with pics! I ordered a rear diffuser from a fellow board member and thought I'd capture the change out procedure.
Disclaimer: Not responsible for anything dumb and dangerous you do or may happen...yada yada yada..
....I apologize for the dirty car pics - it was in pristine condition this morning until I had to drive out in the rain!
1. Back the car up on ramps or raise it up on jack stands.
2. Remove two screws from underneath that hold the diffuser in place.
3. Remove the two screws on each side that hold the diffuser tabs in place. Be careful 'cause the plastic is brittle. These were a bit difficult due to tight space. All I could think about was how much I wish I had a muffler delete mod
4. With some gentle force the diffuser will pop out from its tabs t that attach it to the bumper. I managed to break one but no big deal since my OEM was being replaced.
5. Install new diffuser. Depending on aftermarket manufacturer it may or may not have tabs that go into the bumper but it should have at least two holes for the underneath screws.
NOTES: Overall fitment for my aftermarket diffuser is good. There is a bit of a gap to the right only noticeable because some of the bumper plastic had broken off from previous owner from either running over something or backing up into some low-to-the ground hard concrete. The pictures below are in order for the DIY process. I plan on doing some cosmetic work on the rear bumper soon so I'm hoping the shop can fix the gap somehow. I'm also planning on painting it the same color as the car. Any comments and questions are welcome!
BIG UPS TO SLIMM!!
/// M5
Umnitza VXX
BeastPower Brackets
Schmiedmann Blck Chrm Grills
AFE Power Air Filters
XPEL Protection Film
StopTech ST-40
SlimmBones Finned Diffuser
CarbFib ACS-style Front Splitters
TimmayTips
Bilstein PSS
Evolve Alpha-N
D-RodM5 is offline
The Following 3 Users Say Thank You to D-RodM5 For This Useful Post:
chowdah (5th March 2013), CPI (28th February 2011), M55555 (27th February 2011)
post #2 of 29 Old 27th February 2011, 04:48 AM
Hdhntr23
Hdhntr23's Avatar
Well done.
Air Jordans for sale!! Size 13 << Click the link!!!
Current Interior Mods:
MKIV, Sirius Retrofit, BlueTooth Retro-Fit, E60 SSK, ACS Aluminum Pedals, 30% Window Tint, TEC CupHolder, 2X's Ultimate Cup Holders, Full LED upgrade (Thanks Timmay77), "M" Stitched Alcantara Shiftboot and E-Brake boot, CF Steering wheel trim (Thanks CGRM5), Euro-Dash (Thanks Raz and Timmay77), Hella TC-400 TPMS, Scosche BlueTooth 2.0 A2DP Adapter (Thanks btmlinedan) Euro "Safety kit" Fire Extinguisher and First Aid box (Thanks Slimmbones)
Current Exterior Mods:
"Always-On" DRL Predator ICE LED 6000K AE's (Thanks Timmay77 and NavCoder), C-Fiber Kidney Grills (Thanks Havasusteve03Beast), ACS C-Fiber Roof Spoiler, ACS Flipper style C-Fiber Front Splitters, C-Fiber OEM Trunk Spoiler, C-Fiber Eye-Lids (Thanks CGRM5), Custom "vented" C-Fiber Rear Diffuser (Thanks Timmay77, ATLANTAM5 and Diny), Euro Headlights, (Thanks CGRM5), C-Fiber 6 piece window sills, 7 Piece C-Fiber Blue/Grey Roundels, Stainless vented custom Fog-Light frames, Hamann style sideskirts w/ CFiber Inserts
Current Performance Mods:
Dinan Exhaust cans (Thanks Timmay77 and btmlinedan), Brake duct mod with "Black Chrome" custom rings (Thanks Timmay77 and Diny), Dinan RSB with BeastPower brackets (Thanks Firehire, MFreakin5 and btmlinedan), Stoptech slotted rotors with StopTech Street Performance Brake Pads (Thanks Zeckhausen Racing Timmay77 and Lunker325)
Hdhntr23 is offline
The Following User Says Thank You to Hdhntr23 For This Useful Post:
D-RodM5 (27th February 2011)
post #3 of 29 Old 27th February 2011, 04:51 AM
M55555
M55555's Avatar
Thanks for posting the DIY and pics. Looks fantastic on your car
2001 Carbon Black ///M5
ESS VT1-560 Supercharger System 92mm Pulley
Supersprint 4-1 Headers
Magnaflow 10416 Resonators
Timmay77 Signature Muffler Delete V1
Bilstein PSS9 Coilovers + Ground Control Camber Plates
BBS CH 19x8.5F, 19x10.0R
Michelin Pilot Super Sport 245/35F, 275/35R
Wheel Stud-Conversion Kit F/R
15mm Front + 5mm Rear Spacers
OEM Mud Flaps
E60 545i SSK + UUC DSSR + ZHP Knob
SLIMM C63 AMG Style Diffuser
SLIMM Front Lip Spoiler
SLIMM OEM Euro Armrest
Audiovox Mediabridge BT Integration
M55555 is offline
The Following User Says Thank You to M55555 For This Useful Post:
D-RodM5 (28th February 2011)
post #4 of 29 Old 27th February 2011, 12:38 PM
ECB
ECB's Avatar
How about a pic in daylight? Thanks for the writeup.
03 M5 Titanium Silver/Black Luxury/Burl Walnut
ESS VT 550 S/C 92mm pulley, Supersprint headers and Race cats, Eisenmann Sport Exhaust, RK Autowerks/Evolve tune,
Aquamist HFS-3 water methanol injection, Rogue SSK w/ RP Synchromax fluid, fog light delete,
H&R Springs, Dinan 17mm rear sway bar, TCD sway bar brackets, Ultimate Pedals, Euro Armrest,
Hardwired V1, Angel iBrights v.2, 6000K Low beams, 70W High beams,BSW Speaker Upgrade & 10" Sub
04 M3 Jet Black/Black Nappa/6 spd
Max PSI Turbo, Supersprint Resonated Sect. 2, Eisenmann Race Muffler
Rogue SSK, H&R springs, Koni Yellows, Squared 18's
ECB is offline
post #5 of 29 Old 27th February 2011, 05:34 PM
slimmbones
Company Representative for Euro Parts Direct
Yes great write up looks great here is a trick make sure you clean area with a wax and grease remover or goof off before installing diffuser once you have removed backing on 3m tape and bolts are tight take a heat gun or hair dryer along top area where 3m tape is and apply pressure to diffuser this activates the tape for a tighter stronger bond to rear bumper
slimmbones is offline
post #6 of 29 Old 27th February 2011, 11:38 PM Thread Starter
D-RodM5
D-RodM5's Avatar
slimm...i did just that - i wiped it down clean and took a blow dryer on high to get a good seal..i don't think it's going anywhere unless you really sit there to pry it off- thanks again!
also attached are some day light pics....darn rain wont go away
/// M5
Umnitza VXX
BeastPower Brackets
StopTech ST-40
TimmayTips
Bilstein PSS
Evolve Alpha-N
D-RodM5 is offline
CPI (28th February 2011), Hdhntr23 (28th February 2011), M55555 (28th February 2011)
post #7 of 29 Old 28th February 2011, 01:03 AM
slimmbones
Glad your happy maybe you can edit your instructions and put the information I added (trick) for adhesion
post #8 of 29 Old 28th February 2011, 01:19 AM
CPI
CPI's Avatar
CPI is offline
The Following User Says Thank You to CPI For This Useful Post:
post #9 of 29 Old 28th February 2011, 05:31 AM
"S62"
"S62" is offline
post #10 of 29 Old 28th February 2011, 05:45 AM
m5 deamon
m5 deamon's Avatar
look mine looked the same way when i first installed it then i removed it shaved the tabs down a little so it would not boe out and glued it with windsheild pollyurithane to the bumper will take some pics and post
2003 M5 Carbon Black, Black sport interior.
Evolve Alpha N tune, headers,race cats,heads
Rakkiu modified throttle bodies
Schrick cams
Kw v3 with ground control camber plates , Dinan rear sway bar, Beast power brakets
Stop tech st 40 and st22
UUC light weight flywheel 850csi clutch, Evo3 shifter and dssr
Rouge wheel studs and blue control arm bushing kit
Vorstiner front splitters
Exotics tuning finned diffuser
Euro headlights and taillights with rear fogs
Euro arm rest
40% Lock lsd
m5 deamon is offline
Pics: Vorsteiner front splitter and rear diffuser bugzy E39 M5 and E52 Z8 Discussion 50 13th April 2007 08:49 AM
Pics: Vorsteiner splitter and rear diffuser bugzy E39 M5 and E52 Z8 Discussion 59 31st March 2007 01:06 AM
Latest pics of C.F. Rear diffuser howler M5 E39 Group Buy Forum and Sponsor Discussion and Offerings 41 7th January 2006 05:06 AM
Pics of BBS LM's and G-Power Rear Diffuser Black Beast Owners Gallery 9 14th October 2004 05:07 AM
Pics of BBS LM's and G-Power Rear Diffuser Black Beast E39 M5 and E52 Z8 Discussion 19 12th October 2004 03:31 AM
