SatNav Screen has gone black! - BMW M5 Forum and M6 Forums
Old 26th February 2011, 18:50   #1
hoop
hoop's Avatar
Garage: No Car
Hi there. Yesterday my sat nav`s screen has gone black during normal driving and never went back to normal! The back light seems to be on I can still use radio etc. It has happened before but it fix itself after a few hours. What I noticed is that when I was driving across pot holes etc it was flickering but only for a few secs. I have tried to disconnect baterry, sat nav and leave it for a bit but it won`t work! Has anyone got any ideas what happened?
hoop is offline   Reply With Quote
Old 26th February 2011, 20:17   #2
mertonbmw
mertonbmw's Avatar
Garage: lots of e30s & buying an M5
My MKIII nav in my 2001 540i/6 did the same thing when it was cold (below 20F). It would work fine once the car would warm up (only after restarting). I did some research and what I found was the consensus said that the nav computer itself was going bad. I sold the car (not because of this problem) but had I kept it, I would have used the issue as a reason to upgrade to a MKIV nav computer.
Dig around on bimmerforums and you'll find some info.
Good luck!
current garage:
2008 Volkswagen Passat Wagon (for sale)
2007 Honda Odyssey Touring
1999 Audi A4 Avant
1992 BMW 325ic m-technicII
1991 BMW 318i 4dr slicktop (receiving s52 swap)
1988 BMW 325ic with factory hardtop
working on buying an e39M5, just sold an 2001 540i/6.
mertonbmw is offline   Reply With Quote
Old 26th February 2011, 20:36   #3
hoop
hoop's Avatar
Garage: No Car
Just went for evening spin and sat nav screen is working again! haven`t got a clue what is going on but still while driving it goes off on pot holes etc.
Old 26th February 2011, 22:13   #4
mertonbmw
mertonbmw's Avatar
Sounds like a loose connection or something.
Old 27th February 2011, 12:07   #5
RichardP
RichardP's Avatar
Garage: E39 M5, Carbon Black
Bypass the Traffic Master system if you still have it installed.
RichardP is offline   Reply With Quote
Old 27th February 2011, 14:13   #6
Dearny
Dearny's Avatar
Garage: Alpina B10 V8S in Blue
Another reason could be that your battery isn't receiving full charge, it has happened on my E39 (screen started up fine then used to flicker and go dim). Either your battery could be on the way out or possibly alternator, even a slipping fan belt can cause this, as it won't give the alternator what it wants. Get your battery tested to see if it's giving 12V or is dropping off.
Dearny is offline   Reply With Quote
Old 27th February 2011, 17:57   #7
dan.
dan.'s Avatar
Garage: m5 e39 le mans blue 2001
as richard mentioned the traffic master can interupt the screen and go black
i disconnected mine and sorted..never got to the bottom of it though.
dan. is offline   Reply With Quote
Old 27th February 2011, 18:35   #8
hoop
hoop's Avatar
Garage: No Car
Yes, I think TM is still plugged in. I don`t really know how to bypass TM yet but will look for info. Is it on the board maybe? Or should I just disconnect all the wires from TM unit?
Old 27th February 2011, 18:45   #9
dan.
dan.'s Avatar
unplug the blue connector on the tm,then near it is a male & female blue connector unplug that
with the remaining male blue plug put that into your tv module the plugs are all inline and connect the 2 units.
Permanent brightness adjustment for satnav screen? m5knp E39 M5 and E52 Z8 Discussion 9 17th March 2013 23:31
Is my navi dead? (black screen) deeno35 E39 M5 and E52 Z8 Discussion 4 13th July 2010 20:48
Idrive screen goes black! Stewart W E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 2 9th April 2007 22:53
New fault [radio & satnav screen dying intermittently] M5DAL E39 M5 and E52 Z8 Discussion 2 10th February 2007 08:57
Fitting X5 16:9 satnav screen in E39? minted_aye E39 M5 and E52 Z8 Discussion 1 14th August 2006 20:07
