What do you think about this engine oil~ 4Liter for $240 - Page 2 - BMW M5 Forum and M6 Forums
Like Tree2Likes
Old 14th February 2011, 20:43   #11
vantaam5
vantaam5's Avatar
Garage: 2003 M5 matte black
Originally Posted by nysid2007 View Post
HI ~ vantaam ~ thank you for your thoughts ~ Could you explain just a bit more ~~ ???
Ester oils have the habit to make the rubber seals swell,depending if it is a true ester oil or a so called "ester-hybrid"(I know,this is not the correct chemistry term,but easier to explain...).An "ester-hybrid" oil has about 20% synthetic PAO oil in it,to prevent the seals from swell...
So if it is pure ester oil,do not use it.If it is a "hybrid",it is similar to what Redline offers for way less money...
-rebuild in winter 2011/2012
"submarine edition",a bit boost and some M5 parts...
vantaam5 is offline   Reply With Quote
Old 18th February 2011, 03:54   #12
nysid2007
Garage: E39 M5 / sliver(GONE) E60M5/E63AMG
WOW ~~!!! What a knowledge!!.. Thanks for the explanation.!!
nysid2007 is offline   Reply With Quote
engine oil shows minimum level at 0.2l? but new oil in 2000km ago haivle E60 M5 and E61 M5 Touring Discussion 9 28th April 2010 22:01
Engine B11 240 ps vs 256 ps Mop ALPINABoard.com | BMW Alpina Discussion 1 1st November 2007 22:39
Volvo 240 with Turbo M5 engine Video. Fortytwo5 E39 M5 and E52 Z8 Discussion 11 13th September 2007 02:13
Engine Oil Leak Suspected - Non-Linear Oil Usage 507bhp E60 M5 and E61 M5 Touring Discussion 12 10th December 2005 21:05
Volvo 240 with M5 engine... Gustav E34 M5 Discussion 28 12th February 2004 04:35
