I need e39 m5 oxygen sensors wiring diagrams please - BMW M5 Forum and M6 Forums
post #1 of 7 Old 30th January 2011, 06:46 PM Thread Starter
Schtozo
Hi, i registered just for this for now, please be gentle on me
A friend of mine has a 2000 (EURO) e39 m5 overseas and recently had an issue.
He was cruising around and the guibo failed and somehow it managed to rip all the oxygen sensors wiring harness. If i understood right, there is a big harness that comes from the ecu and it splits into four smaller ones each containing 4 cables that connect to each oxygen sensor, those all ripped apart leaving a spaghetti of wires and now he is lost with the wires and cannot find any diagrams to help him. So please if someone points me in the right direction i will appreciate it.
Cheers
Schtozo is offline
post #2 of 7 Old 30th January 2011, 06:59 PM
vantaam5
PM sent
If the connectors on the wiring loom are missing,the pre-cat sensor connector is the same as the post cat connector on the wiring loom and the post cat sensor side connector is the same as the pre cat connector on the wiring loom...
So buying a set of pre and post cat sensors and he has the new connectors he needs for the engine wiring loom
vantaam5 is offline
post #3 of 7 Old 30th January 2011, 08:08 PM Thread Starter
Schtozo
Originally Posted by vantaam5 View Post
PM sent
Thanks, let me see if i understood right, if he is missing the 8 plugs/ connectors then he will need 8 new sensors so he can rewire the loom that comes from the ecu and of course to the sensors? And then if he is missing only the connectors of the car side of the loom he only needs to buy 4 new sensors pre and post and then match the wiring loom with the plugs?
One more thing he told me is that each sensor has four wires, 2 black and 2 white but the car loom has different colours. Does that mean he has aftermarket sensors or they are supposed to be like that? Is there any difference between euro and us models?
Schtozo is offline
post #4 of 7 Old 6th October 2012, 05:28 PM
J.Khlok
J.Khlok's Avatar
J.Khlok is offline
post #5 of 7 Old 7th October 2012, 07:40 PM
sirtophamhat
sirtophamhat's Avatar
On a somewhat related note, my car has a third plug on the drivers side of the vehicle coming off this harness. It's little plastic cover mounts directly behind the oxygen sensor connectors, but I can't seem to remember what it plugs into. Where should I be looking?
sirtophamhat is offline
post #6 of 7 Old 7th October 2012, 08:24 PM
Sailor24
Sailor24's Avatar
EGT is on the left cat. They were recalled and deleted. If you have no extra wire coming from the cat then the plug is redundant.
Sailor24 is offline
post #7 of 7 Old 7th October 2012, 09:32 PM
sirtophamhat
Good to know, I probably should have asked before spending an hour removing heat shields and poking my fingers in small spaces looking for a missing plug.
MAF sensors and Oxygen Primary sensors KennyG E39 M5 and E52 Z8 Discussion 13 2nd February 2011 02:00 AM
e39 m5 complete wiring diagrams mishkinm5 E39 M5 and E52 Z8 Discussion 23 2nd August 2010 05:54 AM
E39 For Sale: Two E39 M5 Bosch Oxygen Sensors Easy E Parts / Other For Sale or Wanted 10 9th January 2010 01:08 AM
E39 M5 Oxygen sensors for sale 59$ shipped shoand03cobra Parts / Other For Sale or Wanted 3 5th November 2008 09:52 PM
FS: Brand new Bosch pre-cat oxygen O2 sensors 13477 for E39 M5 supratony Parts / Other For Sale or Wanted 4 19th August 2008 11:50 PM
