• Latest threads
    • Custom feed
      • Updates
        Old 23rd April 2002, 04:12   #1 (permalink)
        stever
        Track pad update
        a few weeks ago i described my trashing a set of StopTech rotors and Pagid orange pads from a- improper bedding? b-aggressive driving? c-something else?
        Greg ran the tt with Pagid Oranges and i the M5 with new front rotors and Oranges at Laguna Sat & Sun -- we both looked at the rotors before we went out, and i used about 6 laps on the first session bedding pads and brought it in to cool (the brakes had already been bedded when installed) -- on both our cars there was a clear difference between the clean metal rotor before and the kind of bright gray sheen of deposited pad material after (now that i know what to look for)
        one of the S4 guys there running Oranges with Brembos street and track (he does a lot of track events) confirmed that ABSOLUTELY the Oranges must be bedded before every event -- driving them cold on the street removes the pad material deposited during bedding which will result in uneven pad transfer if you go out and get them hot immediately -- even then he occasionally gets some uneven pad deposition which will often go away (as Greg and i both experienced to varying degrees over the two days)
        someone also gave Greg a trick that spraying the brakes with water, letting them develop rust film, and then using the brakes and re-bedding will some times take off the uneven pad deposition -- will try this as soon as the occasion arises
        the good news is that after bedding and hard running on track, they don's squeal -- i sort of infer that when the squeal comes back it will indicate the pad material has been removed from the rotors
        do other pads like the Carbotech Panther Plus behave the same?
        stever is offline
        Forum Jump
        10 Reasons why you should go to the track. greg E39 M5 and E52 Z8 Discussion 50 6th March 2004 00:21
        Alpina/BMWM5.com meeting at Nurburgring Oldtimer Grand Prix 2003 kees ALPINABoard.com | BMW Alpina Discussion 15 20th September 2003 02:46
        My visit to the Old Timer Grand Prix on the 10th of August raymondw Regional Forums and Events and group meetings for M5, M6 and Alpina owners 2 26th August 2003 01:05
        My visit to the Old Timer Grand Prix on the 10th of August raymondw Most Memorable Threads' 2 26th August 2003 01:05
        Page generated in 0.17308 seconds with 11 queries
