Appropriate times to reset adaptation values - BMW M5 Forum and M6 Forums
post #1 of 13 Old 15th November 2010, 12:34 AM Thread Starter
russap5
russap5's Avatar
When is it beneficial to reset adaptation values??
For example, any of these scenarios:
-change in driving style
-major mods like headers
-minor mods like air intake, new air filters, etc.
-after changing sensors, O2, CPS, MAF, etc.
-after changing engine components, rod bearings, chain guides, etc.
-new engine software
-or even just to reset them every year or so to keep things healthy?
This is a question for the gurus just for the overall education of the board.
2001 ///M5 Jet Black on Caramel / Alcantara
Dinan
CAI, Dinan Rear Sway Bar, Dinan Front Strut Bar, Dinan Exhaust, Dinan
Brembo GT BBK 355mm Front - 345mm Rear, Evolve Alpha-N Tuning, Walbro 255HP fuel pump,
Ground Control Coilovers, Evolve "Medusa" headers, Magnaflow Cats, SuperSprint X-pipe, Magnaflow 10416 resonators, Beastpower Rear Sway Brackets, Gulf Oil Filter Housing w/ Fluidyne Cooler,
Custom Fluidyne Power Steering Cooler,
Linea Corse Z2S 19" wheels w/ Continental DW tires, EVO U/D Pulleys, Reinforced Rear Subframe, Diff Viton O-rings,
RaceSkids Metal Underbody Panels, Custom Leather/Alcantara steering wheel door panels and front seats, 35% window tint, Valentine One Hardwired, ACS style splitters,
E60 SSK and ZHP Knob, "Shorty" clutch stop w/ start sensor mod, Carbon Fiber Wrapped Interior, BSW subwoofer kit, Competition 6.5" front speakers in custom baffles,
DICE/Intravee II iPod adapter, TEC Cupholder, E90 radio knobs, AC and USB powered plugs installed in center console, Full LED overhaul in cabin/footwells/trunk
DIY Accelerator Pedal Removal
My Custom covered steering wheel
My plug-n-play LED light upgrade
DIY adding AC and USB power outlets
DIY fix squeaking steering wheel adjustments
Shadow Chrome: A closer look
$6 DIY headrest in-car camera mount
M5 DIY for Dummies
russap5 is offline
post #2 of 13 Old 15th November 2010, 05:50 AM
AMP
AMP's Avatar
BMW typically recommends leaving the adaptation values in place for most repairs (including sensor replacement). The system will re-adjust very quickly. The exception would be any repair to the throttle system (hard parts or sensors) in which case you do need to re-set the adaptations.
I let them be unless I'm trying to track down an issue which has manifested itself as an adaptation going outside of the pre-defined threshold. These cases typically center around fuel trims and the best way to verify the repair is to reset back to zero and see how much and how fast it deviates.
'12 Alpina B7 SWB Alpina Blue/Black (On Order)
'11 1M Coupe Alpine White/Black
'08 M6 Coupe Stratus/Black
'03 M5 Sedan Imola Red/Black (gone, but not forgotten)
'93 M5 Sedan (3.6) Sterling Silver/Black
'11 550i Dark Graphite/Oyster-Black (wife's car)
Past: '11 M3 Coupe | '08 M5 Sedan | '10 M3 Coupe | '07 M6 Coupe | '07 Z4 M Coupe | '04 M3 Coupe | '02 M5 Sedan | '95 M3 Coupe -- x2
AMP is offline
post #3 of 13 Old 15th November 2010, 06:05 AM
churious
churious's Avatar
I believe its good to do this after a applying a new tune to your car. Although some tuners may do this in the process. GT1 is the only way to do it outside of this correct?
2001 Dinan S2
Imola Red on Black Lux with Titanium Trim
Dinan Carbon CAI
Dinan MAFs
Dinan Throttle Bodies / Velocity Stacks
Dinan 3.45
Dinan S3 Suspension / Brecus Racing Thrust Arms
Dinan Strut Tower Brace
Dinan Rear Sway / Beastpower Brackets
Evolve Alpha N Stage 4
Brembo 355
Headers
SS Race Cats/Xpipe
Eisenmann Race
Rogue SSK w WSR
Brecus Feramic Clutch
Dinan Wheels / NT05
Track Wheels / NT01
Daily Drivers -
08 E61 535xi Sport
11 Land Rover LR4 LUX
churious is offline
post #4 of 13 Old 15th November 2010, 06:15 AM Thread Starter
russap5
russap5's Avatar
I've had mine reset with an Autologic before.
So a reset after changing TPS then. Is it true that you can reset individual values? or is it an all or nothing kind of thing?
Dinan
M5 DIY for Dummies
russap5 is offline
post #5 of 13 Old 15th November 2010, 06:42 AM
M55555
M55555's Avatar
Since you asked the question, how does one reset adaptation values?
2001 Carbon Black ///M5
ESS VT1-560 Supercharger System 92mm Pulley
Supersprint 4-1 Headers
Magnaflow 10416 Resonators
Timmay77 Signature Muffler Delete V1
Bilstein PSS9 Coilovers + Ground Control Camber Plates
BBS CH 19x8.5F, 19x10.0R
Michelin Pilot Super Sport 245/35F, 275/35R
Wheel Stud-Conversion Kit F/R
15mm Front + 5mm Rear Spacers
OEM Mud Flaps
E60 545i SSK + UUC DSSR + ZHP Knob
SLIMM C63 AMG Style Diffuser
SLIMM Front Lip Spoiler
SLIMM OEM Euro Armrest
Audiovox Mediabridge BT Integration
M55555 is offline
post #6 of 13 Old 15th November 2010, 07:12 AM
AMP
AMP's Avatar
You can reset groups of values, but off the top of my head I can't remember the specific groups. I know that you can reset throttle separately from everything else and the same with fuel.
With most cars clearing codes will reset adaptations, but this is not the case with BMW. Doing a battery disconnect for a period of time (overnight) should reset them. I just use the GT1
On the GT1 it's under service functions -> drive -> DME. You can accomplish the same with any BMW-specific scanner (Autologic, Auto Enginuity, Bavarian Technic, etc)
AMP is offline
The Following User Says Thank You to AMP For This Useful Post:
M55555 (15th November 2010)
post #7 of 13 Old 15th November 2010, 09:06 AM
Hasan Shaikh
Hasan Shaikh's Avatar
+ 1
Hasan Shaikh is offline
post #8 of 13 Old 15th November 2010, 03:33 PM
nightkrawler
nightkrawler's Avatar
you cannot reset individual adaptation values on an m5. the service function in dis clears all values.
nightkrawler is offline
The Following User Says Thank You to nightkrawler For This Useful Post:
russap5 (15th November 2010)
post #9 of 13 Old 15th November 2010, 04:08 PM Thread Starter
russap5
russap5's Avatar
I'm sure you know a lot more about it than I do, but I swear when I got mine reset they asked which values I wanted reset (ie. exhaust, intake, fuel, etc.) or if I wanted them all reset. I just said all..
Are you 100% sure you cannot reset individual adaptations? Even with all the different tools, GT1, Autologic, etc.?
Dinan
M5 DIY for Dummies
russap5 is offline
post #10 of 13 Old 15th November 2010, 04:42 PM
Mike S.
Mike S.'s Avatar
I know that INPA can reset adaptations, but just "all" and not a subset.
Rolling Heroin - 2003 M5 TiAg / Tuning by Evolve / Exhaust by Timmay77 / ECM by Valentine / Fast by Nature - "She's fast enough for you old man." Nickname courtesy of Mike Miller (yes, that one.)
What I do in my spare time: Aura Caelestis, Metal Band From Texas. Check us out! Comments welcomed!
Mike S. is offline
The Following User Says Thank You to Mike S. For This Useful Post:
M3 Euro LTW (13th November 2013)
clean tranny adaptation values ? champaign777 E39 M5 and E52 Z8 Discussion 12 25th March 2010 11:32 PM
Does CarSoft 6.5 show adaptation values? I.e. Long-term fuel-trim thomas.hood E39 M5 and E52 Z8 Discussion 0 4th October 2009 11:12 PM
Resetting adaptation values? teropa E39 M5 and E52 Z8 Discussion 1 5th September 2009 09:56 PM
ECU Adaptation ECB E39 M5 and E52 Z8 Discussion 3 27th October 2006 08:59 PM
Resetting the adaptation memory rigsby E39 M5 and E52 Z8 Discussion 3 14th December 2005 09:08 PM
