12th April 2002, 03:29
#1 (permalink)
Throttle Response/Sport Mode Question
I was under the impression that the improved throttle response effect that we get from the sport mode is the result of compressing the full range of the accelerator pedal into a shorter range. In other words, if moving the accelerator pedal in 20% gives you 20% throttle in the regular mode, I would expect moving the accelerator pedal 20% to yield 25% (or something greater than 20%) throttle while in sport mode.
While driving in to work this morning, I decided to test my understanding of how the sport mode works using the following "experiment".
While in the regular (non-sport) mode, I put the car in neutral and steadied the engine at 3,000 rpm. I then pressed the sport button and expected to see the tach move up. Well to my surprise, nothing happened. While holding the accelerator pedal steady, the sport mode button had no impact on the engine speed.
What am I missing??? I obviously don't have a thorough understanding of how the sport mode button impacts throttle response. Was my "experiment" flawed or is the car programmed so the sport mode button is inactive when the car is in neutral?
reggie c.
Los Angeles, CA
Current = 2004 40th Anniversary Porsche 911
Past = 2000 M5
12th April 2002, 03:52
#2 (permalink)
My understanding is that non-sport mode is non-linear at the bottom of the throttle range and that the sport mode makes it almost linear. Therefore 20% pedal position == 20% is sports mode but only 15% in non-sport mode.
Try your experiment again at 1500 RPM and 2000 RPM -- I bet you'll see a different result.
I also understand that the Dinan chip mod brings the non-sport mode almost in line with the sport mode.
Phil
01 M5 Silverstone/Silverstone
04 Honda Pilot
02 Indi Blue Mini Cooper (sold  )
12th April 2002, 04:01
#3 (permalink)
I agree with Phil. My observation is that at low revs, switching Sport on will kick the revs up. Try it (on an empty stretch of road or parking lot) in 1st gear: hold steady throttle at ~1500 revs and put Sport on. You get a nice little kick.
Steve ///M
'03 Infiniti FX45 Silver/Tech
'01 Carbon Black/Black Sport (sold 31 Dec, 03)
1967 GTO Conv Red/White/White
12th April 2002, 04:35
#4 (permalink)
I'll try it on the way home tonight and see if it makes a difference.
reggie c.
Los Angeles, CA
Past = 2000 M5
12th April 2002, 04:47
#5 (permalink)
Carguy
The sport mode shorten the throttle response time by removing a built-in lowpass filter that makes the car more driveable in city traffic (Normal mode). It is actually more complex than that - we are talking about two different transfer functions, mathematically speaking.
Michael aka B8 Guru
2003 BMW M5
1995 BMW ALPINA B12 5.7 Coupe
1998 BMW ALPINA B8 4.6 Cabrio
1997 BMW ALPINA B8 4.6 Touring
12th April 2002, 07:58
#6 (permalink)
I turn it on all the time while holding about 1/8 throttle, accelerating in 1st or 2nd. You get a nice little kick in the back.
15th April 2002, 02:46
#7 (permalink)
Does the sport mode better the performance numbers???? or does it make the car "feel" faster????
2001 Z8 BLACK/RED K&N FILTERS POWERCHIP ECU UPGRADE (Thanks Apples)
365RWHP
350RWTQ
Sold, please take care of her
2001 X5 4.4 SPORT BLACK/BLACK K&N FILTER.
M3 Come.. M3 Go
15th April 2002, 03:55
#8 (permalink)
The car is not actually faster with Sport mode on, it just feels that way because of the more aggressive fuel application at a given accelerator pressure. Sport mode shortens the time needed (again at a given pressure from your right foot) to open the throttle butterflies and inject fuel into the cylinders... I think I read somewhere that it opens them at around 120 milliseconds (as opposed to around 250-300+ milliseconds with sport mode off).
Therefore, throttle reponse it better with Sport mode ON.
Andy
'00 Imola Red M5 - sold 4/02
'00 Mustang Cobra R - #155 of 300
'02 F-250 SD Powerstroke Crew Cab 4X4
'00 Honda Accord V6
15th April 2002, 06:37
#9 (permalink)
Sport Mode/Dinan Software
I recently had the Dinan software programmed into my M5 and I'm
wondering if there is any improved or different throttle response in
Sport mode. I do feel some difference in normal mode driving but I
usually put the car into sport mode all the time. Bottom line, is there any difference with the software in sport mode. Thanks
15th April 2002, 10:52
#10 (permalink)
Re: Throttle Response/Sport Mode Question
I did the same experiment a while ago and sport mode definitly brought up the revs while keeping a constant pressure on the gas pedal...I found it pretty interesting
PhilSeastrand's right though, keep it in the 1500's to 2000's rpm to really hear the difference
2006 Interlagos Blue M5 - My father's
2007 VW Golf GTI - My little rocket!
20th April 2002, 02:32
#11 (permalink)
OK, I'm really confused now. I steadied the engine at 2000 rpm and the revs actually DROPPED when I engaged the sport button. What gives?
reggie c.
Los Angeles, CA
Past = 2000 M5
