9th November 2010, 04:50
#83
2001 M5 Imola Red
Well, I prob made that bonehead mistake with my car too. I replaced the clutch, pressure plate, bearing, and friction surface of the aluminum flywheel. I also broke the sensor when removing it from the bell housing. I would rather not tear the entire thing apart again, so does anyone know where the two missing teeth should be when rotated to top dead center? Is top dead center from cylinder 1 on the driver side (left)? How do I check to see if the computer is reading the crank sensor? The new sensor seems to be pretty far away from the timing ring teeth. I took a quick measurement with a metal ruler with a slide gauge on it. There were no shims on the previous sensor, but it broke so I don't know how long the "nose" was on it to match it up with the new one.
Any suggestions and tech procedures are greatly appreciated.
