How NOT to install a flywheel. Tim's failed clutch/flywheel/RMS install. - Page 9 - BMW M5 Forum and M6 Forums
 1Likes
post #81 of 84 Old 8th November 2010, 12:54 AM
Lardog888
Lardog888's Avatar
Originally Posted by tradin1 View Post
i said ive reused the same clutch, which would be the clutch disk, along with the same pressure plate. i haven't changed anything...just had to remove it for random reasons everytime.
I see. I misunderstood you. I thought you had used the same clutch (pressure plate) and replaced the clutch plate (disk) four times. I didn't realize you had to remove it for unrelated repairs.
Lardog888 is offline
post #82 of 84 Old 8th November 2010, 08:02 PM
Wildstar
Wildstar's Avatar
Tim, I'm am very glad you posted this up. I hope when it comes time for me to install a new clutch, that this keeps me from making the same mistake. This is in no way guaranteed, but if I do its my own fault...
Mistakes fixing things are only bad if we don't learn from them. Thanks to you we have all learned about this one, and we can now be free to screw something else up on our own.
I'm over 30, I can't trust myself!
2002 M5 LeMans Blue
2000 Z3 Roadster Topaz Blue
1990 Taurus SHO Oxford White
Wildstar is offline
post #83 of 84 Old 9th November 2010, 04:50 AM
Dr.Scholl
Well, I prob made that bonehead mistake with my car too. I replaced the clutch, pressure plate, bearing, and friction surface of the aluminum flywheel. I also broke the sensor when removing it from the bell housing. I would rather not tear the entire thing apart again, so does anyone know where the two missing teeth should be when rotated to top dead center? Is top dead center from cylinder 1 on the driver side (left)? How do I check to see if the computer is reading the crank sensor? The new sensor seems to be pretty far away from the timing ring teeth. I took a quick measurement with a metal ruler with a slide gauge on it. There were no shims on the previous sensor, but it broke so I don't know how long the "nose" was on it to match it up with the new one.
Any suggestions and tech procedures are greatly appreciated.
Dr.Scholl is offline
post #84 of 84 Old 12th February 2012, 06:02 PM
djazz
Thanks Tim! This saved my butt when I was re-installing my flywheel. I knew there was someway to align or I would have marked it during removal, but my mind was blank. So a quick search was needed.
When I saw the thread everything came back about the dowel ring.
Much appreciated,
dj
“Sometimes I’ve believed as many as six impossible things before breakfast.” – Lewis Carroll
djazz is offline
JB Racing Flywheel/Clutch install w/ pics mikenator5000 E39 M5 and E52 Z8 Discussion 38 16th September 2014 06:10 AM
Help! 2000 M5 Clutch, Flywheel install problem boylunching E39 M5 and E52 Z8 Discussion 13 28th April 2009 05:07 AM
Oil Leaking After RMS/Clucth/ and FlyWheel Changed mswartz E39 M5 and E52 Z8 Discussion 4 10th May 2007 02:25 PM
New Install UUC Stage III Clutch and Light Flywheel. QUESTIONS! Kings MotorSport E39 M5 and E52 Z8 Discussion 32 31st August 2005 06:49 AM
Dinan or RMS Flywheel? KZ_M5 E39 M5 and E52 Z8 Discussion 3 2nd February 2004 08:52 PM
