If you unplug your battery when working on your car, you need to read this thread. - BMW M5 Forum and M6 Forums
Old 29th October 2010, 10:15   #1
timmay77
timmay77's Avatar
Garage: 2001 M5 (M CINCO), 2001 525i Touring (FAM WAG)
Sales Feedback: (17)
Exclamation If you unplug your battery when working on your car, you need to read this thread.
This is probably the most embarrassing post I have ever made.
For those who do not want to read the whole post, scroll to the end of and read the last few sentences.
So a few of us gathered yesterday to put a new clutch/flywheel/RMS in DaytonDomer99's (Phil) 2002 M5. For those who don't know me, I am a machinery mechanic by trade, and I take GREAT pride in my work. The install couldn't have gone better. We had the transmission out in under 3 hours and the car completely back together and ready to go after 7 hours total work time. Problem was, it wouldn't start once we turned the key. It acted as if it wasn't getting gas. We checked EVERYTHING again and again. Checked for loos connections, pinched wires, among other things. We also swapped crank position sensors thinking it was bad. We even unplugged the CPS in my car to see if it sounded the same trying to start. It didn't. My car just cranked, never sent fuel, never even truly tried to start, just cranked. Phil's car was sending gas, trying to start, just wasn't getting spark. COMPLETELY different sounds when they each tried to start. The ONLY thing that happened, that was BAD, was when it came time to hook the battery back up, the ignition was left in the "on" or "2" position. I remember having to turn the wheel so I could install the support for the engine when pulling the transmission off. That required having the key turned on to unlock the steering wheel to do so. It must not have been put back to "off" and the key removed. We checked all of the fuses, relays, and any other electrical devices we could find. We unplugged the battery for 30 minutes and touched the positive and negative leads from the car together to totally discharge the capacitors in the ECU to do a full reset. Nothing worked. What we think (thanks Brian, aka WingsAA for researching this) that when the battery was hooked up with the key on, it went into a "safe" mode thinking it was being hot wired.
We exhausted all of our resources, calling all of the M5 gurus we had phone numbers for, and a few of their contacts as well. Thank you again, Peter, Steve, and Matt for your help. Even you Ray, without you knowing it, helped by being my friend. Mike at NE Motorsports is a true gentleman and was willing to help a complete stranger with just knowing I was friends with Ray and Peter. Mike, off the top of his head, had some GREAT suggestions and amazing knowledge of these cars. What a class act. Anyway, I ended up having to have the car towed to the local stealership where it now waits to be looked at. Tears filled my eyes, literally, as they pulled away with my friend's M5 on the back of a flatbed that I couldn't get running. Luckily Brian (WingsAA from Ohiobimmers.com) knows almost everyone at the dealership, and is going to work closely with them to diagnose the problem. Thank you again Brian.
Phil, again, I am SO SORRY. I will have your Beast repaired and back to you as soon as I can. I feel just as bad about having to put you in my Accord to drive until I do. It makes a great winter car, if you're me. LOL.
As of right now, we still don't know what it will take to get the car running, but I will update this thread once we do.
Cliff notes: When hooking your battery back up after finishing your work, make sure the key is NOT in the "on" or "2" position. BAD things happen. Make sure your key is off, or out of the ignition completely.
2001 Jet Black/Executive Black
M5 ("M CINCO") current mods and accessories:
RMS Stage 2 SC Kit, installed by Buckhead Imports, tuned by Tony Lawshee ~ 556rwhp 456lbs trq on 9lbs of boost
~ Complete aftermarket stereo system w/Alpine INA-W910/PXA-H701, Rear Camera,
Hybrid Audio Technologies L831 speakers
~ UUC V12 clutch kit with segmented kevlar clutch disc
~ Custom crank case ventilation system
~ Buckhead Imports Performance headers and decat pipes
~ Muffler delete with ///M5 - MCINCO etched "Timmay Tips" LOL
~ Dinan 3.45 rear differential
~ Remote oil thermostat/Setrab oil cooler
~ Fabtech-Performance Heat Exchanger
~ (4) Dinan 18x9.5" wheels
~ Stoptech slotted rotors and Centric Posi Quiet Pads
BC Racing coil overs (10k/8k) ~ Powerflex thrust arm and inner track control arm bushings ~ Dinan RSB ~ Beastpower sway bar brackets
Slimmbones finned rear diffuser, XL fog light covers, trunk spoiler, and front lip spoiler.
Tim ~ email: t.hallman77 @ yahoo (dot) com
timmay77 is offline   Reply With Quote
The Following 22 Users Say Thank You to timmay77 For This Useful Post:
2-Pugs (29th October 2010), 5PEEDY (1st November 2010), ard (30th October 2010), Chris_M5 (29th October 2010), CSBM5 (29th October 2010), Dr.K (2nd November 2010), drodgers007 (29th October 2010), ger (29th October 2010), gsfent (29th October 2010), havasusteve03Beast (30th October 2010), Hawkwind (2nd November 2010), Hdhntr23 (29th October 2010), herrubermensch (30th October 2010), Kelster (30th October 2010), M5 Fan (29th October 2010), M5 London (29th October 2010), M55555 (29th October 2010), Mike S. (1st November 2010), motoxris (2nd November 2010), Phil M5 (29th October 2010), sportmodeON (31st October 2010), Vector57 (30th October 2010)
Old 29th October 2010, 10:26   #2
mister2d
mister2d's Avatar
Garage: Silver E39 M5
What a nightmare! How can you guys sleep now.
Tell ya what, I'll stay up the rest of the night in hopes of sending some good vibes.
mister2d is offline   Reply With Quote
The Following 2 Users Say Thank You to mister2d For This Useful Post:
Hdhntr23 (29th October 2010), M55555 (29th October 2010)
Old 29th October 2010, 10:32   #3
M55555
M55555's Avatar
Garage: 2001 Carbon Black M5
Sales Feedback: (10)
Thanks for sharing, and sorry to hear Tim. Hope it gets resolved ASAP.
+1 All nighter...
2001 Carbon Black ///M5
Supersprint 4-1 Headers
Magnaflow 10416 Resonators
Timmay77 Signature Muffler Delete
Custom Software Tune
Bilstein PSS9 Coilovers
Ground Control Camber Plates
BBS CH in Custom Satin Black
Hankook Ventus V12 255/35/19, 275/30/19
Wheel Stud-Conversion Kit F/R
15mm Front + 5mm Rear Spacers
E60 545i SSK + UUC DSSR + ZHP Knob
SLIMM C63 AMG Style Diffuser V1
SLIMM Front Splitters
SLIMM 3.5" Fog Light Air Ducts
SLIMM OEM Euro Armrest
M55555 is offline   Reply With Quote
The Following User Says Thank You to M55555 For This Useful Post:
Old 29th October 2010, 10:32   #4
timmay77
timmay77's Avatar
I haven't hardly slept at all, I am literally sick over this whole mess. I will gladly except the good vibes my friend......
Old 29th October 2010, 10:39   #5
M5 London
M5 London's Avatar
Garage: M5 E39 Supercharged
Tim,
Sorry to hear this.
These things happen, and perhaps even for good reason (someone up there made sure this car was not being driven (exposed to danger perhaps) on the road that day)
Did you check any of the fuses/relays in the E BOX ?
Good Luck and I am sure its going to be something minor !
Cheers
Kumaran
E39 M5 - ESS Supercharger Kit, Uprated and MONSTER Remapped to 640HP, Van Manen Race Manifolds, Van Manen DeCats, Aeromotive Stealth 340 F/Pump, Bosch Green Giant Injectors, Aquamist HFS-3 with 3 Jets, MONSTER CCV setup with Cobra Pump (2PSI boost switch), Bilstein Sprint Dampers, Intrax Springs, Dinan Adjustable Rear ARB, Stoptech ST40 Big Brake Kit, EBC Yellows, 550i SSK
www.WhatAboutCars.com
M5 London is offline   Reply With Quote
The Following User Says Thank You to M5 London For This Useful Post:
Old 29th October 2010, 10:51   #6
timmay77
timmay77's Avatar
Thank you Sir.
We did check the (5) 30amp fuses in the E box thanks to the knowledge of Mike at NE Motorsports. I had NO CLUE they were there until he pointed it out.
The Following User Says Thank You to timmay77 For This Useful Post:
Old 29th October 2010, 12:04   #7
djazz
Garage: Jet Black E39 M5
Best vibes possible from here too.
Sounds like an honorable response to an honest mistake.
dj
"I look upon an increase in the power of the State with the greatest fear, because, though apparently doing good by minimizing exploitation, it does the greatest harm to mankind by destroying individuality, which lies at the root of all progress." — Mahatma Gandhi
djazz is offline   Reply With Quote
The Following User Says Thank You to djazz For This Useful Post:
Old 29th October 2010, 14:43   #8
TurboCarrera
Garage: 00 M5 Silver
Before disconnecting a battery from a modern vehicle - car, boat, or motorcycle - hook a 12v source to the two battery cables and leave it on while the cables are off the battery. More often than not I use a $10 battery charger from a discount store, but anything that will give you 12 volts will be fine. I do this even if I am just doing a quick battery swap. It saves a lot of hassle with the computer and saved radio buttons and a host of other things, and adds about 30 seconds to your workflow.
Better luck next time,
Steve
00 M5
05 X3
10 S1000RR
84 911
TurboCarrera is offline   Reply With Quote
Old 29th October 2010, 15:02   #9
timmay77
timmay77's Avatar
Originally Posted by TurboCarrera View Post
Before I disconnect a battery from a modern vehicle - car, boat, or motorcycle - I hook a 12v source to the two battery cables and leave it on while the cables are off the battery. More often than not I use a $10 battery charger from a discount store, but anything that will give you 12 volts will be fine. I do this even if I am just doing a quick battery swap. It saves a lot of hassle with the computer and saved radio buttons and a host of other things, and adds about 30 seconds to your workflow.
Steve
00 M5
05 X3
10 S1000RR
84 911
Dude, we disconnected the battery cables on purpose so the car didn't have power. The way you are SUPPOSE to do it before doing any serious work to keep from frying something. Your advice is appreciated, but does not apply at all to this topic.
Old 29th October 2010, 15:18   #10
Randy Ray
Garage: 2000 Black M5
May sound dumb but did you try another KEY????
When i bought a dup key from the dealer.....the new key would not work until they recoded it again, and again..........
(I miss the old days when you just hot wired it to help in the diagnosis)
Good luck...it will all work out.
Randy
Randy Ray is offline   Reply With Quote
The Following 3 Users Say Thank You to Randy Ray For This Useful Post:
Hdhntr23 (29th October 2010), mkaehly (29th October 2010), timmay77 (29th October 2010)
Remote key not working,battery and fuse ok vantaam5 E39 M5 and E52 Z8 Discussion 7 19th February 2010 14:48
TPMS reset not working, pls help, have read every article. JohnnyP420 E39 M5 and E52 Z8 Discussion 16 23rd August 2009 18:10
Battery Jumpstarted,now Blower not working! Stamper1 E39 M5 and E52 Z8 Discussion 1 30th August 2008 12:03
Non-working door locks after battery change? HOVO E39 M5 and E52 Z8 Discussion 19 26th July 2008 21:55
Battery lamp not working? M5Micke E34 M5 Discussion 4 7th June 2006 18:25
