Looking for some help with engine noise. I originally thought the noise was VANOS related, see previous post
VANOS rattle continues after startup, no codes, but it is so loud that I'm thinking it may be something worse like a broken chain guide or rod knocking. Would a sticking valve be loud? this is more than a slight ticking.
It seems to be coming from the top end on bank 2 and there are no codes. When I first start up the engine it will idle without the noise until I give it some gas, then the noise is constant even when going back to idle. So far I've checked the following:
-drained oil and checked filter, no debris
-removed chain tensioner, spring was not broken although it was not tapered on both ends like the one here
Chain tensioner change DIY with pics
-removed bank2 valve cover, no scoring on the cam lobes, tensioner for the cam chain is tight. I did notice there is some play on the chain that runs back to bank1, right about where #4 is in this diagram - is this normal?
RealOEM.com BMW E39 M5 Timing - Timing Chain Lower P
Any other ideas while I have this opened up? I may just bring it to the dealer and see what they come up with
update: just noticed I can turn the little 10mm coupler on the vanos gear...dont think I should be able to? as I remember it connects to the vanos unit and should be tight? I can't get TIS to install on win7 which is unfortunately all I have right now. #2 in the diagram here for the exhaust cam, you can also just barely see in the pics below
RealOEM.com BMW E39 M5 timing gear timing chain top
