Question for the guys with SS headers. - BMW M5 Forum and M6 Forums
post #1 of 22 Old 25th September 2010, 03:59 PM Thread Starter
rated ///M
rated ///M's Avatar
Did you also purchase the connecting pipes or just have an exhaust shop make a custom piece for you? The connecting pipes are around $300, a little ridiculous. Also, who did your tuning afterwards?
rated ///M is offline
post #2 of 22 Old 25th September 2010, 05:12 PM
gsfent
gsfent's Avatar
I did buy the connecting pipes. My installer said mine were not particularly well made in that it took some work to line everything up anyway. I think a good fabricator will not have much trouble making up the pipes.
Powerchip did my tuning before and after. Couldn't have been happier.
Dinan Stage 3 suspension, SS jet coated headers, ESS SC kit w/ 1 range colder NGK's, 92mm pulley, 440 Big Greens, TTFS alpha N tune for meth, RK plenum plates, Sachs high performance PP and CCC proprietary clutch disc, stock DMFW, open brake ducts, Hamann front splitters, TEC cupholder, U.S.(Euro style) tilt/slide armrest, 6k HID fogs, 6k super white low beams, V1/Stealth1, dual head LI, 2.65 diff w/40% lockup/2x dynamic, compact spare, Euro trailer hitch, Mocal oil cooler, ACS type rear spoiler, Rogue custom SSK and tranny mounts, ST 355 BBK (fronts), BP sway bar brackets, Bluetooth retrofit, Speedhut boost gauge, Dinan TB's and VS, KB BAP, Howerton/HFS-3 Aquamist WI trunk setup.......
gsfent is online now
The Following User Says Thank You to gsfent For This Useful Post:
M55555 (25th September 2010)
post #3 of 22 Old 25th September 2010, 05:45 PM
Tyson1868
Tyson1868's Avatar
The connecting pipes were purchased along with xpipe, race cats, and mufflers.
Not sure about tuning??
For Sale see classified thread
Tyson1868 is offline
post #4 of 22 Old 25th September 2010, 08:14 PM
Brecus.com
Company Representative for Brecus Motorsport
Brecus.com's Avatar
rated ///M,
Keep in mind that if you go with the SS Connecting pipes or Race Cats its a bolt together system. If you have them fab'd up they will most likely be welded together requiring a cut whenever you go to remove the exhaust. Welding is the best seal but the bolt up system is nice when you want to easily access the car for mods or maintenance.
PLEASE EMAIL US FOR PRODUCT INQUIRES
WE NOW OFFER FREE SHIPPING ON EVERYTHING!
Brecus.com is offline
The Following User Says Thank You to Brecus.com For This Useful Post:
post #5 of 22 Old 25th September 2010, 09:33 PM
M55555
M55555's Avatar
I ordered the connecting pipes but it was unnecessary as my shop noted the pipes could not be aligned with the stock cats. They ended up fabricating connector pipes out of stainless steel instead. The connector pipes do require that you make a cut before the cat to remove the stock headers, so either way (connector pipes or not), you'll need a cut + weld. If you opt for SS race cats, well that all bolts and slips on IIRC.
I have an ESS NA tune, however, most tunes would ensure you run proper AFR with the new headers.
2001 Carbon Black ///M5
ESS VT1-560 Supercharger System 92mm Pulley
Supersprint 4-1 Headers
Magnaflow 10416 Resonators
Timmay77 Signature Muffler Delete V1
Bilstein PSS9 Coilovers + Ground Control Camber Plates
BBS CH 19x8.5F, 19x10.0R
Michelin Pilot Super Sport 245/35F, 275/35R
Wheel Stud-Conversion Kit F/R
15mm Front + 5mm Rear Spacers
OEM Mud Flaps
E60 545i SSK + UUC DSSR + ZHP Knob
SLIMM C63 AMG Style Diffuser
SLIMM Front Lip Spoiler
SLIMM OEM Euro Armrest
Audiovox Mediabridge BT Integration
M55555 is offline
post #6 of 22 Old 25th September 2010, 09:45 PM
Brecus.com
Brecus.com's Avatar
I just want to clarify what I said earlier.
The SS Connecting pipes do still require a bit of welding but are not welded directly to the headers. With the SS Connecting pipes you are still required to cut your OEM cats and then weld them to the connecting pipe. The connection pipe does not weld directly to the header but rather bolts up to insure you can remove the newly revised OEM cat if needed without cutting a weld.
post #7 of 22 Old 26th September 2010, 04:50 AM
Jacob_Seattle
Jacob_Seattle's Avatar
I also am about to undertake this project. Would you guys be so kind as to post up some pictures of your completed systems? Thank you very much in advance.
Power, Styling and Sophistication. ///M5
Jacob_Seattle is offline
post #8 of 22 Old 26th September 2010, 04:53 AM
Brecus.com
Brecus.com's Avatar
I have a set of OEM cats with the connection pipes already welded on. Ill snap a couple pics for your guys reference.
post #9 of 22 Old 26th September 2010, 05:06 AM
GBPackerfan1963
GBPackerfan1963's Avatar
Bought the connecting pipes. Conforti Shark Tune before and after. Very happy for now. Big surprise coming in February.
2015 Yas Marina Blue M4~Black full Merino leather~Executive Package~Drivers Assistance Plus~Lighting Package~Adaptive M Suspension~19" Black Light-Alloy Style 437 wheels~Carbon Fiber trim~HK audio systems~6MT
2013 Alpine White Convertible M6~DINAN Stage 1~Black full Merino Leather~Executive Package~20" Wheels~Comfort Access~Rear view camera~Bang & Olufsen Stereo
GBPackerfan1963 is offline
post #10 of 22 Old 26th September 2010, 05:17 AM
havasusteve03Beast
havasusteve03Beast's Avatar
Tease
03 TiAg Biest; 565 RWHP via Dynojet - SOLD
03 CB Biest; 549 RWHP via Dynojet - SOLD
havasusteve03Beast is offline
The Following User Says Thank You to havasusteve03Beast For This Useful Post:
M55555 (26th September 2010)
QUESTION ABOUT HEADERS > jester5675 E39 M5 and E52 Z8 Discussion 5 20th June 2008 01:27 PM
Any of you guys have videos of just Eisenmann race. No headers, x-pipe or sections.. AlpineMsix E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 4 21st March 2008 01:11 AM
California Guys with SuperSprint Headers: Smog OK? E39 ///M Power E60 M5 and E61 M5 Touring Discussion 36 13th December 2007 12:40 AM
Question for those with SS headers... 6speed E60 M5 and E61 M5 Touring Discussion 5 23rd December 2006 01:54 AM
To do Headers or not to do Headers that is the question? TOFAST E39 M5 and E52 Z8 Discussion 6 8th June 2003 09:18 PM
