Those with SS Headers: Ground Clearance - Page 18 - BMW M5 Forum and M6 Forums
Like Tree2Likes
Old 10th August 2011, 23:40   #171
Michael William
Garage: 00 M5 Imola, 93 M5 Black, 91 M3 Black, 96 328 Black, 85 745i White, 02 325Xi Dark Blue, 02 325Xi Blue, 96 540 Touring
Folks:
In preparation for my installation, I really did not like the “step down” in the Supersprint connecting pipes between the header collector and the stock cats. After making the cut in the OEM cat pipe, I was able to see the reason that Supersprint added this restriction. The restriction makes it easier to install the connector pipe into the cat pipe given some freedom of placement along the cat pipe. This issue is illustrated by the following pictures which depict the cat inner and “shield” bores and the step down bore of the connecting pipe.
http://www.m5board.com/vbulletin/mem...t-bore-cut.jpg
Depicts the cat bore as cut
http://www.m5board.com/vbulletin/mem...ting-bores.jpg
Depicts the cat bore as cut with the connecting pipe restriction as delivered
To facilitate better flow, I had my shop expand the cat inner bore until it touched the outer shield bore. This is illustrated by the following picture.
http://www.m5board.com/vbulletin/mem...ore-expand.jpg
Depicts the cat during bore expansion
http://www.m5board.com/vbulletin/mem...final-bore.jpg
Depicts the cat bore post expansion
This allowed me to expand the connector pipe bore as depicted in the following picture.
http://www.m5board.com/vbulletin/mem...ector-pipe.jpg
Depicts expansion of the connector pipe restriction
The final step was installation of the connector pipe into the expanded cat bore and the application of a single weld fusing the three ends of the inner and outer cat bores and the connector pipe bore. Note that I did not use the collar pieces shipped with the connector pipes. I believe that this set up flows better.
A great deal has been said about the application of the springs on the collector pipes. I found a real easy way to get this done using a simple cotter pin removing tool (looks like a bent pick with a screw driver handle. Simply insert the pick end into the spring end which goes on the collector welded tabs and rotate the pick. The spring snaps neatly into place in the welded tubes – 5 seconds for each spring and you are done…
Cheers,
Michael William is offline   Reply With Quote
Old 27th January 2012, 00:51   #172
M55555
M55555's Avatar
Garage: 2001 Carbon Black M5
Sales Feedback: (10)
Originally Posted by M55555 View Post
Just emailed info@ss to seek an update. Hopefully they can come up something that helps us who have low ground clearance.
I'm thinking if SS can't help for some reason, I may explore cutting sections off of the end of the primaries so the collector can be slid in a higher fashion than it's current configuration, or whatever my exhaust shop may suggest.
I have not heard a single response from SS, via PM and email. Not going to comment on their customer service...
Looks like I'm going to have to take matters into my own hands...
2001 Carbon Black ///M5
Supersprint 4-1 Headers
Magnaflow 10416 Resonators
Timmay77 Signature Muffler Delete
Custom Software Tune
Bilstein PSS9 Coilovers
Ground Control Camber Plates
BBS CH in Custom Satin Black
Hankook Ventus V12 255/35/19, 275/30/19
Wheel Stud-Conversion Kit F/R
15mm Front + 5mm Rear Spacers
E60 545i SSK + UUC DSSR + ZHP Knob
SLIMM C63 AMG Style Diffuser V1
SLIMM Front Splitters
SLIMM 3.5" Fog Light Air Ducts
SLIMM OEM Euro Armrest
M55555 is offline   Reply With Quote
Another Valve clearance question - no special tool just to check clearance? Oversteer E34 M5 Discussion 17 31st August 2010 03:39
ground clearance on a stock m5 99540auto E39 M5 and E52 Z8 Discussion 2 27th November 2007 00:46
Ground Clearance compared with 5-series? nlk10010 E39 M5 and E52 Z8 Discussion 3 9th January 2004 14:38
Ground Clearance? celler E39 M5 and E52 Z8 Discussion 10 5th April 2002 22:19
Ground Clearance Bob R E39 M5 and E52 Z8 Discussion 4 5th August 2000 00:55
