Originally Posted by Burden
Thanks for the update! Glad I read this before talking to my shop. We were considering cutting as well. Looks like we will hold off on that method for awhile. The car is still undergoing surgery and transplants from my wrecked e39 m5 (time consuming indeed!) so I may be able to get some pictures of the mounting while it is up on a lift. Would this be of any use??
If you have any doubt on the correct installation of your SS headers, take photos and post them.
We will make an evaluation of what can be wrong.
Here some photos of the entire R&L headers assembly, after they have been installed correctly.
This LHD car is at our factory shop, now.
Left side bank headers. Distance between frame and primary, approx 10mm.
Left side bank headers. Distance between collector and chassis 8 to 12mm.
Right side bank Headers.Distance between frame and primary, approx 10mm.
Right side bank headers. Distance between collector and chassis 8 to 12mm.
Right and Left side collectors sit at the same height. The stock downpipe bracket has been taken as reference.
Left side of the car, the collector is virtually flush with the chassis lower line.
Right side. Wheel arch 68.0cm. Collector ground clearance 13.2 cm (new style collector) / 13.5 cm (old style collector).
Left side. Wheel arch 68.3cm. Collector ground clearance 13.0 cm (new style collector) / 13.3 cm (old style collector).
At a visual check, both the right and the left SS headers sit at the same distance from the ground, and their lowest point is virtually flush with the chassis.
Alessandro Gilli
Supersprint
Italy
