• Latest threads
    • Custom feed
      • Updates
        Old 6th April 2002, 17:33   #1 (permalink)
        CM5GO
        CM5GO's Avatar
        Nowack question.
        Does the Nowack suspension setup include any camber adjustment?
        With the suspension as low as it isI would imagine that some negative camber would benefit the car tremendously.
        I think I am about to go with the H&R coilover setup and I am considering going with adjustable camber plates as well.
        I think I am going to lower the car to Nowack specs of about 25mm in the rear and 35mm in the front. I may not go quite as low in the rear if I have rubbing issuess but we'll see.
        Any thoughts?
        Thanks in advance
        Chris Z
        2003 Porsche C4S
        Jet Black on Grey
        6spd
        B&B Tri Flo's, K&N's
        Dinan Stage II Software,
        UUC Short Shift, ACS Pedals
        Euro angel eyes
        StageII Xenon, Amber Fogs
        19 inch BBS LM's
        KW Variant 2 Coilovers
        Nowack / HD Ducts
        Mintex Pads (red box)
        Euro arm rest
        (press www button for pics)
        SOLD! (boohoo)
        2001 X5 4.4i sport (Sold!)
        Audi All-Road 2.7t (Wifey)
        CM5GO is offline
        Old 7th April 2002, 04:03   #2 (permalink)
        Apples
        Apples's Avatar
        CM5GO...l just re sent the same email to Nowack that l sent after your PM about getting their suspension set up for your M5. I will let you know ASAP on the answer. I will be calling them in the next few weeks about some other stuff, so if you can hold till then about getting another suspension set up l will let ya know.
        As far as l know there was no camber change from the norm....but l don't know enough about suspension to be exactly sure if it changes because of the height???. All l know is that l got anti roll bars, springs and shocks to Nowacks specs/settings and thats it. And it's bloody awsome....very tight and responsive but not rock hard at all, you still will keep your teeth....l would call it sporty and firm and thats it. I have it set at the mid way point fro front and rear right now.
        APPLES
        2000 M5 LeMans blue
        Headers/cats/exhaust/KW suspension/sway bars/UUC shifter/UUC clutch/BBS LM 19's.
        2003 M5...actually MIB's (master yoda)
        2004 Lamborghini Gallardo Pearl Yellow. HRE 840r 19's front 20's rear
        2006 Ford GT Heritage blue
        www.m5ute.com
        Apples is offline
        Old 7th April 2002, 06:25   #3 (permalink)
        CM5GO
        CM5GO's Avatar
        Thanks for checking that out for me Apples. I think I will likely go with the H&R setup because it is less than half the price with similar benefits.
        H&R makes a great suspension. Of course this does not include sway bars , just springs and shocks.
        I would still be interested in the final word from Nowack to find out how much.
        P.S. - What do you mean you have it set midway. Is the rebound / compression / height adjustable? Is it a coilover system?
        Chris Z
        2003 Porsche C4S
        Jet Black on Grey
        6spd
        Euro angel eyes
        19 inch BBS LM's
        Nowack / HD Ducts
        Euro arm rest
        SOLD! (boohoo)
        CM5GO is offline
        Old 7th April 2002, 23:11   #4 (permalink)
        tfung
        tfung's Avatar
        If a suspension is well made and all set up properly, you shouldn't really need camber plates to make the car neutral in handling... the only reason why you would want camber plates is the dial in more or less understeer.....
        US Spec 2001 E39 M5 - LHD
        AC Schnitzer
        Dinan
        3.45 differential
        Others
        Euro Spec 1999 E39 M5 - RHD
        2007 Mercedes E63
        2007 Corvette Z06
        2008 Nissan GTR
        tfung is offline
        Forum Jump
        Nowack Tuning Report, The Truth (Long Version) CharlesW E39 M5 and E52 Z8 Discussion 60 28th June 2006 21:46
        Nowack Tuning Report, The Truth (Long Version) CharlesW Most Memorable Threads' 44 30th November 2002 05:49
        New member! (and a question about the Nowack front grill) lee2375 E39 M5 and E52 Z8 Discussion 7 1st October 2002 19:02
        Ongoing Nowack Nightmare - Update CharlesW E39 M5 and E52 Z8 Discussion 41 6th June 2002 03:25
        Question regarding the Nowack N500.. roee E39 M5 and E52 Z8 Discussion 5 4th September 2001 19:32
        Page generated in 0.25700 seconds with 11 queries
