Old 28th September 2010, 19:10   #11
ag21197
Garage: e39 M5
Thanks for all your advice Alan. About the fuel pump, is it possible to determine whether it's a power supply issue to the fuel pump or the fuel regulator rather than the actual fuel pump failing.
Thanks,
Art
By the way, my indy quoted my nearly $1000.00 for the fuel pump job.
ag21197 is offline   Reply With Quote
Old 28th September 2010, 21:59   #12
acury
acury's Avatar
Garage: 1997 523i E39
While your at it, remember new fuel filter
Edit: Silly me, you already done that.
Best of luck
Men are superior to women, for one thing they can urinate from a speeding car.
acury is offline   Reply With Quote
Old 28th September 2010, 23:21   #13
Vector57
Vector57's Avatar
Garage: 2001 M5 Anthracite
Do it yourself and save some serious $$$
Thanks,
Art
Hi Art,
$1000 is obscene for this job! Fuel pump (Part # 16146752369) is $342, relay (Part # 61357892976) is $39 and the regulator
(Part # 13531404089) is $63 at Tischer (getBMWparts.com). Be sure to also order the sealing washer (Part # 07119963129)
that goes between the regulator body and fuel filter. With only 20 PSI, the fuel pump is gone, don't even hesitate about
replacing it. The fuel pump relay is the taller, black relay located in right side of trunk.
These are fairly simple DIY replacements and you'll save over $550.
Alan
Vector57 is offline   Reply With Quote
Old 28th September 2010, 23:58   #14
ag21197
Garage: e39 M5
Thanks again Alan and everyone else for your valuable input.
Bogging with initial throttle tip in getbent E39 M5 and E52 Z8 Discussion 20 27th September 2010 00:40
5500RPM = Misfires & Rough Running - ABS Module Related? VetteRacer E39 M5 and E52 Z8 Discussion 2 14th May 2009 14:59
Bogging engine after installing K&N cones...? kirbanana E39 M5 and E52 Z8 Discussion 21 28th May 2007 01:44
My car bogging with ses on kirbanana E39 M5 and E52 Z8 Discussion 6 20th May 2007 05:19
Q: M5 cold start bogging. emiliowu E39 M5 and E52 Z8 Discussion 15 22nd February 2006 19:02
