E39 LS1 Swap Completed - Page 23 - BMW M5 Forum and M6 Forums
Like Tree105Likes
LinkBack Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Old 13th June 2012, 15:57   #221
rao
Garage: Silver 540i
I can read between the lines
Rob
Current - 98 540i with Chevy 6.6 LS2/T-56 power - Build Thread
Old - 92 325i with Chevy 6.6 LS2/T-56 Power
Older - 95 M3 with Chevy 6.6 LS2/T-56 Power
Please read the important REVISED DISCLAIMER that applies to this post.
rao is offline   Reply With Quote
Old 13th June 2012, 16:54   #222
mattmartindrift
mattmartindrift's Avatar
Garage: 540i
Originally Posted by VacMan View Post
Actually if you reread his post I think its just your wheels that suck...
Sent from my DROID BIONIC using Tapatalk 2
I don't really. Not my taste, however I am not against them in any way, and they match the rest of the car's aesthetic theme of clean, stockish, non-m E39; and, they do so quite perfectly.
mattmartindrift is online now   Reply With Quote
Old 13th June 2012, 17:17   #223
bmwMcrzy
bmwMcrzy's Avatar
Garage: 02 Le Mans Blue / Caramel DINAN S2
No one was going to set their personal best @ that drag strip.
As I mentioned in my post with the video is was basically NOT prepped and it was 85F.
Rao wanted to take it easy on the launch to make it back to Chicago and didn't have the stickiest tires.
Rao was the fastest E39 last year, the only BMW who got into the 12s....
Even tho I give him sh1t about his wheels I fully understand why he uses them.
bmwMcrzy is offline   Reply With Quote
Old 13th June 2012, 18:42   #224
bimmerule
bimmerule's Avatar
Garage: Carbon Black E39 M5
Sales Feedback: (8)
Oh snap, "Pinks All Out!"
Old 14th June 2012, 03:41   #225
bf
bf's Avatar
Garage: Sterling Gray
That is one ugly beast
bf is offline   Reply With Quote
Old 5th July 2012, 00:21   #226
mknighten
mknighten's Avatar
Garage: silver 528i
hey rao i was wondering who did the flash on the gauge cluster and if it required a vin to get the flash right ,but im looking to this on my 528i but thats my only problem so any help would be great ,and would it be possible to run the original computer and just jump crertain wires like the starter speedo and the temp sensor ,and then run the stand alone harness for the motor and trans ,i was also wondering what you used for the trans mount ?but all in all it is a great swap and very well done
mknighten is offline   Reply With Quote
Old 22nd July 2012, 00:15   #227
mknighten
mknighten's Avatar
Garage: silver 528i
rao if you could contact me through email ,i could really use some help on my swap .the gauges have me stumped ,my email is knighten070402@yahoo.com,thanks
Old 22nd July 2012, 02:30   #228
mattmartindrift
Garage: 540i
I believe he did his own cluster coding.
You'll need NCSexpert and the proper hardware cable/interface.
Old 22nd July 2012, 02:47   #229
rao
Garage: Silver 540i
Mine was done in a totally different way then I would do it now, and I wasn't the one who did it on my car.
I have posted this several times - the instrument cluster needs to be coded for a analog tach signal and analog coolant temp signal. That is pretty easy to do now with the software that is available. Then you have to run the additional wires that go with that coding, which is a no-brainer.
Old 22nd July 2012, 03:07   #230
mknighten
mknighten's Avatar
Garage: silver 528i
you obviously have alot of expierence with canbus its just a new area for me so all the coding stuff throws me off ,so would any performance shop be able to do the recode on the speedometer and temp signals ,im not trying to beat a horse to death id just rather get the right info from the person who has done it ,sorry if i sparked a flame,but thanks for the help.
Should I swap for a E39 M5 2002 firebladegriff M5 E39 and E60 tips & tricks 8 21st July 2011 23:25
Engine Swap On E39? :) E39 M5 and E52 Z8 Discussion 8 25th September 2009 04:38
LS1 engine on a BMW E36 BRN64666 GTBoard.com: General Sportscars 1 24th January 2005 04:29
