2nd September 2010, 20:56
#2
2003 M5 Titanium Silver
Thank you for this post. My Nav System is on the blink and this just may be the ticket. Much appreciated....
Modifications:
Engine Tuning: ESS Tuning VT550 Supercharger w/91.44mm pulley, Aquamist HFS-3 Water Methanol Injection System w/Howerton Engineering custom trunk tanks.
Exhaust: Supersprint headers, Supersprint high flow cats, Supersprint X-pipe, Meisterschaft GT2 Racing Performance exhaust w/matte black 83mm tips
Powertrain: Koala Motorsport 3.45 differential w/30/60 asymmetrical ramps w/40% limited slip, UUC V12 Segmented Kevlar Clutch, UUC Ultimate V8 Flywheel, UUC Clutch Stop, UUC SSK, UUC DSSR, ZHP weighted/illuminated shifter
Suspension: H&R sway bars (front and rear), Beastpower rear sway bar brackets, Strong Strut strut brace, Koni shocks, H&R springs, Dinan monoball thrust arm bushings, Powerflex upper/lower control arm bushings, Ground Control adjustable camber plates
Wheels: 19" VMR V710 w/custom matte black finish
Brakes: Brembo Gran Turismo BBK: 8-piston front calipers w/380 mm cross-drilled rotors, 4-piston rear calipers w/340 mm cross-drilled rotors, Active Autowerke CAI front brake ram air cooling
Miscellaneous: radar-mirror.com AEM boost gauge & AEM wideband AFR gauge, Alcantara-lined custom mounted Aquamist gauge in center console, Rogue Engineering Power Pulleys, 16" electric fan w/temp control switch
Aesthetics: Slimm's custom CF Splitters, Vorsteiner CF vented hood, Vorsteiner CF diffuser, CF kidney grills, CF side view mirrors, CF rear spoiler, CF BMW roundels, matte black M5 badge, Ultimate Pedals aluminum race pedals & footrest, BMW foot-well mounted umbrella
Horns: Relayed Stebel Compact Truck Horn (300 Hz at 118 dB at 3M) & Stebel Compact Tuning Horn (480 & 630 Hz at 118 dB at 3M)
Fuzz Busters: Beltronics STi Driver Radar Detector, Blinder M47 laser jammer
Euro-spec Accessories: BMW front seat mounted Fire Extinguisher, BMW front seat mounted First Aid Kit, BMW Emergency Triangle
