Bogging with initial throttle tip in - The Unofficial BMW M5 Messageboard (m5board.com)
Old 17th August 2010, 20:44   #1
getbent
Garage: 2003 M5 Carbon Black
Car started showing some weird symptoms this am. ANY acceleration with even moderate accelerator pressure results in a split second hesitation and then way more throttle than anticipated. It happens with the sport mode on and off. The best way to describe it is (if you've ever tried this at home) would be say you start accelerating with the sport mode off, then switch it on while holding the gas steady. If you've ever tried that you can feel the engine switch over to the sport mode throttle mapping and get a little punch of acceleration. Problem is this was happening all the time. Almost like a mini-turbo lag, but made it nearly impossible to drive smoothly.
There are no codes displayed. Recent maintenance;
- New plugs over the weekend (doubt this is the issue as the old plugs didn't look too bad - will post pictures tonight- and if anything the idle is marginally smoother plus no mis-fire codes)
- Fuel filter, air filters & oil/filter change 1,000 miles ago
- New pre-cat O2 sensors 500 miles ago (had a b2 & b3 codes, but gone now)
- Thermostat 1,000 miles
Any thoughts on what else to check? Only other random code I've had past month was E8 for the evap valve, but hasn't come back since cleared.
getbent is offline   Reply With Quote
Old 17th August 2010, 21:04   #2
OC e39r
OC e39r's Avatar
Garage: M5 Alpine White
Sales Feedback: (4)
If you are not used to using the sports mode on all the time then I can say you are not pressing firmly on the gas pedal or you are pressing too soon before the clutch is fully engaged. Meaning your foot is hesitant,not the car. Turn off the sports mode and serif it gets better
Running strong
Hüper Optik 40%
E60 545 shifter
E53 X5 front control arm bushings
E9x radio knobs
E46 m3 alcantara steering wheel
Eibach rear sway bar
Koni yellows
CNS 10.5 clutch disc with a lightened dual mass flywheel
Carbotech 1521 pads and SS lines
Intravee II and Alpine kca 420i
Cupholders delete
IATS relocation
OC e39r is offline   Reply With Quote
Old 17th August 2010, 21:08   #3
getbent
Sorry, that's not it
I happens in both sport mode and normal mode. It also happens while cruising - say tooling around at 35 and press on the gas, initial hesitation and then bam accelerates. I've owned the car since new (has 55k on it) and never had something like this before.
Forgot to mention, but did the MAF test and was getting readings of around 138-141 just shy of redline.
Old 17th August 2010, 21:09   #4
OC e39r
OC e39r's Avatar
Sales Feedback: (4)
Maybe bad gas?
Old 17th August 2010, 21:56   #5
getbent
Well I did eat Thai for lunch
Sorry, you set that up too well. I'm down to 1/2 tank and will try a different station once get down a little more.
Old 17th August 2010, 22:00   #6
OC e39r
OC e39r's Avatar
Sales Feedback: (4)
Add some injector cleaner When you fill her up and let's know what happened.
Old 18th August 2010, 01:23   #7
M5 London
M5 London's Avatar
Garage: M5 E39 Supercharged
Just a hunch, but check all the wiring on the coils you recently removed and refitted.
I believe one or more coils can misbehave slightly without triggering a cylinder misfire code.
I could be totally wrong of course too.
E39 M5 - ESS Supercharger VT570, Van Manen Race Manifolds, Van Manen DeCats, Aeromotive Stealth 340 F/Pump, Aquamist HFS-3, Custom CCV, Bilstein Sprint Dampers, Intrax Springs, Dinan Adjustable Rear ARB, Stoptech ST40 Big Brake Kit, EBC Yellows, 550i SSK
www.WhatAboutCars.com
M5 London is offline   Reply With Quote
Old 18th August 2010, 02:54   #8
g9s8r
g9s8r's Avatar
Garage: blue acura integra
Maybe recheck the gapping?
02 Bluewater
g9s8r is offline   Reply With Quote
Old 18th August 2010, 03:59   #9
DouglasABaker
DouglasABaker's Avatar
Garage: 2002 Chiaretto Red M5
You might try disconnecting the battery (which will reset the DME). You've changed enough of the sensors, but not all of them, that the DME may need to adapt to the new inputs. Or you could just go ahead and change all the rest of the sensors
DouglasABaker is offline   Reply With Quote
Old 18th August 2010, 05:18   #10
absolutepressure
absolutepressure's Avatar
Garage: 2000 M5 - Anthracite
Hmm. It sounds like a sensor response issue. After the car accelerates does it do so smoothly? If so, I'd say either the throttle pedal potentiometer and/or the tps sensors are not accurately relaying their true position. Could be a dead spot at low throttle positions in either. I don't know how often/if the potentiometer goes bad, but I know that the tps's are replaced by many people. One other question, did this issue happen right after doing any other work on the car, or some drastic weather change? When you replaced your sensors, maybe one was only half clicked in.
Later!
absolutepressure is offline   Reply With Quote
Bogging normal with traction control on? Qs06M5 E60 M5 and E61 M5 Touring Discussion 3 14th September 2007 17:42
Bogging engine after installing K&N cones...? kirbanana E39 M5 and E52 Z8 Discussion 21 28th May 2007 00:44
My car bogging with ses on kirbanana E39 M5 and E52 Z8 Discussion 6 20th May 2007 04:19
Q: M5 cold start bogging. emiliowu E39 M5 and E52 Z8 Discussion 15 22nd February 2006 18:02
8 Throttle bodies vs Dual Throttle bodies, Dinan Myth? MIB E39 M5 and E52 Z8 Discussion 6 26th December 2003 16:33
