Can the heat exchanger have a coolant leak? - BMW M5 Forum and M6 Forums
post #1 of 29 Old 4th August 2010, 01:32 AM Thread Starter
M5LAY
I have my M5 at a shop right now because it was over heating this weekend. They are saying that it is leaking at the heat exchanger and need to order a new one. Well that part is over $500 dollars and wanted to check with the experts here if anyone has had this happen. My car has 166K miles to btw.
thanks ahead anyone.
M5LAY is offline
post #2 of 29 Old 4th August 2010, 03:23 AM
Vector57
Vector57's Avatar
Arrow Extremely unusual, at best.
I would want to see it to believe it. Using a coolant system tester, have them pressurize it to 30 PSI and
show you where the leakage is. This oil-coolant heat exchanger is quite robust and extremely well made.
More likely, the potential sources of leakage are the transfer tubes (o-rings) between the heat exchanger
and thermostat housing. There are other seals as well that may be the source, in particular, those between
the exchanger and the mating flange on the block.
I would definitely not be shelling out the cost for a new exchanger without them first demonstrating to
you the leakage with the system pressurized (per above, 30 PSI).
Alan
Vector57 is offline
The Following 3 Users Say Thank You to Vector57 For This Useful Post:
herrubermensch (6th August 2010), M5LAY (4th August 2010), vantaam5 (4th August 2010)
post #3 of 29 Old 4th August 2010, 03:41 AM
m5 deamon
m5 deamon's Avatar
aggred with the post above also there are two little hoses under the intake plenum on both sides of the inner v bank i would pull the pluenum and pressue test the cooling system
2003 M5 Carbon Black, Black sport interior.
Evolve Alpha N tune, headers,race cats,heads
Rakkiu modified throttle bodies
Schrick cams
e46 m3 oil cooler gulf oil filter housing
Kw v3 with ground control camber plates , Dinan rear sway bar, Beast power brakets
Stop tech st 40 and st22
UUC light weight flywheel 850csi clutch, Evo3 shifter and dssr
Gas mono balls
Rouge wheel studs aluminum lugs
Vorstiner front splitters
Exotics tuning finned diffuser
Euro headlights and taillights with rear fogs
Euro arm rest
40% Lock lsd
m5 deamon is offline
The Following User Says Thank You to m5 deamon For This Useful Post:
post #4 of 29 Old 4th August 2010, 04:33 AM
Hdhntr23
Hdhntr23's Avatar
Also check the coolant jacket.
Air Jordans for sale!! Size 13 << Click the link!!!
Current Interior Mods:
MKIV, Sirius Retrofit, BlueTooth Retro-Fit, E60 SSK, ACS Aluminum Pedals, 30% Window Tint, TEC CupHolder, 2X's Ultimate Cup Holders, Full LED upgrade (Thanks Timmay77), "M" Stitched Alcantara Shiftboot and E-Brake boot, CF Steering wheel trim (Thanks CGRM5), Euro-Dash (Thanks Raz and Timmay77), Hella TC-400 TPMS, Scosche BlueTooth 2.0 A2DP Adapter (Thanks btmlinedan) Euro "Safety kit" Fire Extinguisher and First Aid box (Thanks Slimmbones)
Current Exterior Mods:
"Always-On" DRL Predator ICE LED 6000K AE's (Thanks Timmay77 and NavCoder), C-Fiber Kidney Grills (Thanks Havasusteve03Beast), ACS C-Fiber Roof Spoiler, ACS Flipper style C-Fiber Front Splitters, C-Fiber OEM Trunk Spoiler, C-Fiber Eye-Lids (Thanks CGRM5), Custom "vented" C-Fiber Rear Diffuser (Thanks Timmay77, ATLANTAM5 and Diny), Euro Headlights, (Thanks CGRM5), C-Fiber 6 piece window sills, 7 Piece C-Fiber Blue/Grey Roundels, Stainless vented custom Fog-Light frames, Hamann style sideskirts w/ CFiber Inserts
Current Performance Mods:
Dinan Exhaust cans (Thanks Timmay77 and btmlinedan), Brake duct mod with "Black Chrome" custom rings (Thanks Timmay77 and Diny), Dinan RSB with BeastPower brackets (Thanks Firehire, MFreakin5 and btmlinedan), Stoptech slotted rotors with StopTech Street Performance Brake Pads (Thanks Zeckhausen Racing Timmay77 and Lunker325)
Hdhntr23 is offline
The Following User Says Thank You to Hdhntr23 For This Useful Post:
post #5 of 29 Old 4th August 2010, 02:22 PM Thread Starter
M5LAY
I had them pressurize it yesterday and it is leaking but it is hard to see exactly where its leaking from behind that heat exchanger. I also will have them check those two small hoses that everyone say break over time. I just find it odd that a lot of people haven't had the the heat exchanger go bad on them. Thanks again for the responses. I will try to keep yall updated.
M5LAY is offline
post #6 of 29 Old 5th August 2010, 10:20 PM Thread Starter
M5LAY
So I get a call from the shop today and they say that part is not available in all off the USA and Canada and is not back order from Germany. Does anyone know if there is an aftermarket option for the heat exchanger 11 441 406 695? Or else I will have to wait three weeks.
M5LAY is offline
post #7 of 29 Old 6th August 2010, 06:36 AM
herrubermensch
m5board.com Site Sponsors
herrubermensch's Avatar
Yes, there is an alternative. You can delete the heat exchanger altogether with a kit from Dinan and replace it with an external oil cooler. Check out the "oil cooler potential group buy" thread, which toward the end has the part numbers for the Dinan kit and the "Gulf" oil filter housing that has outs for an external oil cooler. You will also need the oil cooler itself and hoses and connectors. The Dinan kit, the oil filter housing, oil cooler and hoses altogether will run you around $1500, so if you are cost-averse, don't go this route.
--Peter
Managing Member of
Partee Racing, LLC , The S62 Shop, LLC, and The S54 Shop, LLC
herrubermensch is offline
The Following 3 Users Say Thank You to herrubermensch For This Useful Post:
Hdhntr23 (6th August 2010), josiahg52 (6th August 2010), pjfox23 (6th August 2010)
post #8 of 29 Old 6th August 2010, 05:18 PM Thread Starter
M5LAY
Wow that does sound like a great alternative but unfortunately for me cost is an option right now. Thanks again for the advice but I got a few weeks to think about it. I will check it out though.
M5LAY is offline
post #9 of 29 Old 6th August 2010, 06:59 PM
CSBM5
CSBM5's Avatar
I would pull out the heat exchanger and ensure that is actually the culprit (i.e. corroded connection, etc) in the leak. It does not sound like there is certainty on that part (and this will be the first I can recall hearing about on the board). Pull it out and take it to a good radiator shop to be tested (and possibly repaired if it is a minor issue?). To me this sounds like a mechanic who is not certain that is the leaking part, knows that it will be some major labor to pull it all apart and might just be playing it safe (not to mention the extra dough to be made selling that part).
If you're going to pay the labor to pull it out anyway, yank it now, carefully to ensure it is not damaged in the process, check out the exchanger and have it evaluated properly...just 2 cents worth of blather on my part.
Current stable:
Dinan: springs, Konis, rear sway bar;
Ground Control camber plates, Brake ducts opened, Evolve tune
2011.5 M3 sedan 6MT Silverstone, slicktop
Dinan front swaybar, Eibach rear swaybar, pins-out-max-camber-up-front, Michelin PSS street/Nitto NT-01 time trials
2007 328i wagon Silver/gray
2006 330i E90 ZSP 6MT Electric Red/Black
1975 CanAm 125MX2
CSBM5 is online now
The Following User Says Thank You to CSBM5 For This Useful Post:
M5LAY (6th August 2010)
post #10 of 29 Old 6th August 2010, 07:11 PM Thread Starter
M5LAY
M5LAY is offline
Removal of OEM Under Plenum Oil Heat Exchanger herrubermensch E39 M5 and E52 Z8 Discussion 8 12th August 2010 05:11 AM
Coolant Leak shamus_mcd E39 M5 and E52 Z8 Discussion 39 6th July 2010 10:51 PM
Oil Heat Exchanger Pic? Thermostat reinstall help. exproject E39 M5 and E52 Z8 Discussion 24 13th May 2010 07:07 AM
Coolant Leak kurt44 E34 M5 Discussion 5 11th May 2008 03:54 PM
Coolant Leak Brock250 E34 M5 Discussion 4 17th October 2006 04:35 AM
