DIY: Fan clutch replacement *PICS* - BMW M5 Forum and M6 Forums
 3Likes
post #1 of 29 Old 26th July 2010, 08:13 AM Thread Starter
Torquey5
For those with paranoia panicking or on the verge of nervous breakdown over their time ticking fan clutch, no worries. No worries. This DIY is a very simple process that will help almost anyone swap out their fan clutch with absolute ease.
I too was once a paranoia beast owner thinking that the upcoming heat season would for sure kill my fan clutch. I did some research on the ways to test your fan clutch such as poking/trying to stop at the fan with the end of a 11ft broom stick while the car is running. I didn't find that method too useful for me so I said what the hell and just ordered a new fan clutch, and also because I don't know if the previous owner had it replaced or not.
Getting down to business:
Ordering the new fan clutch:
BMW E39 M5 Fan Clutch (11527502804)
This is by far the cheapest place that I've found, even my local BMW dealership was charging around $200, and that's with employee discount. Plus they don't have it in stock and you'd have to wait for it to come in.
Tools needed:
- 1 1/4" open end wrench. This is a rather large size and you can easily find it at any local car parts/tool store.
- Allen key or hex/star key. It's actually allen but I didn't have the right size but hex/star key set worked just as well. Unfortunately I don't remember the T size, but it's one of the smaller/medium ones.
IMPORTANT: The fan clutch nut has reverse thread so you have to unbolt it spinning it to the right.
A few pictures before the swap:
Brand new fan clutch:
1 1/4" wrench:
Step 1:
Using the 1 1/4" wrench, fit it over the old fan clutch nut and give it a quick hard yank to the right. The trick here is to do it fast and it will knock it loose, after that you simply unscrew it until the whole thing comes off. Carefully navigate the fan up and out of the engine bay. This is what my fan/fan clutch looked like:
As you can see it was VERY dirty, but the fan clutch seemed to be in good condition. Here are 2 up close pictures of the fan clutch:
Step 2:
Unbolt the 3 allen screws using one of the earlier mentioned tools. These are pretty easy to remove, shouldn't take more than 2-3 minutes. After I removed the fan clutch I decided to give the fan a good cleaning using car wash soap. I also decided to clean the dirty fan clutch as I'm keeping it simply because it looked okay and I may need it for whatever reason in the future.
After everything was cleaned, screw on the new fan clutch onto the fan.
Make sure you put the fan on the correct way as the original position:
Step 3:
I knew the re-bolting of the fan clutch would be a PITA because I knew there is very limited space where the fan bolts up. It's an awkward position so take your time. The trick here is to use spin the fan blades to hook the thread and when it finally grabs it's all gravy from there. Use your 1 1/4" wrench and give a quick yank to the left to tighten the nut.
*pops open beer*
Special thanks to Cal @ JLeviSW for providing assistance
2003 Carbon Black ///M5
2003 Titanium Silver ///M5
Torquey5 is offline
The Following 9 Users Say Thank You to Torquey5 For This Useful Post:
///M5souraya102 (26th July 2010), 5PEEDY (26th July 2010), Bryan@Jlevi SW (26th July 2010), Clayton Usher (7th May 2012), desmotesta (7th May 2012), KevinM (26th July 2010), M55555 (26th July 2010), RoundelM5 (26th July 2010), Summit (26th July 2010)
post #2 of 29 Old 26th July 2010, 08:48 AM
M55555
M55555's Avatar
Thanks for sharing the write-up, Dan! How long would you say the whole process took?
2001 Carbon Black ///M5
ESS VT1-560 Supercharger System 92mm Pulley
Supersprint 4-1 Headers
Magnaflow 10416 Resonators
Timmay77 Signature Muffler Delete V1
Bilstein PSS9 Coilovers + Ground Control Camber Plates
BBS CH 19x8.5F, 19x10.0R
Michelin Pilot Super Sport 245/35F, 275/35R
Wheel Stud-Conversion Kit F/R
15mm Front + 5mm Rear Spacers
OEM Mud Flaps
E60 545i SSK + UUC DSSR + ZHP Knob
SLIMM C63 AMG Style Diffuser
SLIMM Front Lip Spoiler
SLIMM OEM Euro Armrest
Audiovox Mediabridge BT Integration
M55555 is offline
The Following User Says Thank You to M55555 For This Useful Post:
Torquey5 (26th July 2010)
post #3 of 29 Old 26th July 2010, 09:49 AM
reds2
reds2's Avatar
reds2 is offline
The Following User Says Thank You to reds2 For This Useful Post:
post #4 of 29 Old 26th July 2010, 09:56 AM
reds2
reds2's Avatar
reds2 is offline
post #5 of 29 Old 26th July 2010, 04:05 PM
100%Cocoa
100%Cocoa's Avatar
Regarding the 'quick hard yank to the right', has anyone else had success with this, or got any other suggestions than using the 'correct' tool that holds the saller bolt heads?
100%Cocoa is offline
The Following User Says Thank You to 100%Cocoa For This Useful Post:
post #6 of 29 Old 26th July 2010, 04:29 PM
CSBM5
CSBM5's Avatar
You should probably replace the fan at the same time. It is subjected to continuous and substantial mechanical and thermal stress cycling and is potentially subject to eventual failure as a result...especially if it has ever been nicked, etc. (especially since it is only ~$50 from Tischer).
Current stable:
Dinan: springs, Konis, rear sway bar, monoball bushings;
Ground Control camber plates, Brake ducts opened, Evolve tune,
OE 9.5" rear wheels all around & 275/35-18 Pilot Super Sport
2011.5 M3 sedan 6MT Silverstone, slicktop
Dinan front swaybar, Eibach rear swaybar, pins-out-max-camber-up-front, BFG Rivals autox/Michelin PSS street/Nitto NT-01 time trials
2007 328i wagon Silver/gray
2006 330i E90 ZSP 6MT Electric Red/Black
1975 CanAm 125MX2
CSBM5 is offline
The Following User Says Thank You to CSBM5 For This Useful Post:
post #7 of 29 Old 26th July 2010, 04:47 PM
Frye
Mine was on too tight so I had to find the tool. You can see a picture of it and P/N here: http://i26.photobucket.com/albums/c1...n/twinhole.jpg
I just took measurements, and drilled/grinded a piece of steel like so: http://i26.photobucket.com/albums/c1...n/IMAG0083.jpg
Frye is offline
The Following 4 Users Say Thank You to Frye For This Useful Post:
100%Cocoa (27th July 2010), ard (27th July 2010), Torquey5 (26th July 2010), zed.inc (22nd April 2013)
post #8 of 29 Old 26th July 2010, 06:38 PM
gzig5
You'll get a good idea if your old clutch has been replaced by the date code on the data plate. Your new one was made Jan 22, 2010.
Many of the parts have a date code on the sticker or stenciled on the part. I just found out that the lower oil pan on my MY 2000 was made in November of 2003. Don't know yet if that is from an engine change or it was replaced because of a stripped oil pan plug, which is why I had it out. Also found I've got a 2007 radiator. Need to clean the tag on the fan clutch and see what I can see. Greg
_____________
2000 M5 Carbon Black
Dinan 3.45 Differential
Evolve Tune
Dinan Springs w/ Koni Yellow Sport shocks
Dinan Rear Sway Bar
E60 545 SSK
275 PSS on OEM 9.5" all around
Home-built Muffler Delete
gzig5 is offline
The Following User Says Thank You to gzig5 For This Useful Post:
post #9 of 29 Old 26th July 2010, 07:13 PM Thread Starter
Torquey5
I know you're a busy guy and all, I'd say around 30 min including washing/cleaning the stock fan
Originally Posted by reds2 View Post
Are you sure that's the right number? I get 11527830486 for the M5.
Pretty sure that's the correct link:
BMW Fan Clutch
OEM Reference 11527502804
This will fit the following models
  • 530i 1993-1995
  • 530it 1993-1995
  • 540i 1993-2003
  • 540it 1992-2001
  • 740iL 1992-2001
  • 750iL 1987-1998
  • 840ci 1994-1997
  • 850ci 1994-1997
  • 850csi 1994-1995
  • 850i 1990-1992
  • M5 2000-2003
Or you can take something and give it a swift knock to the wrench. If you have the wrench on there and just tried to turn it that won't work, the pulley/belt will flex along with it so you have to smack the wrench really quick to the right to loosen the nut.
I thought about it, but got conflicting answers. I gave my fan a good look after washing and it appeared to be in great condition with no chips/cracks, etc.
Torquey5 is offline
The Following User Says Thank You to Torquey5 For This Useful Post:
M55555 (27th July 2010)
post #10 of 29 Old 27th July 2010, 02:16 AM
Vector57
Vector57's Avatar
Arrow Replace your fan
The resultant "Grenade-Effect", with shrapnel from the fan wreaking havoc all
over the engine bay and hood is due to severely degraded plastic fans. The
fan clutch locking up only preceded the event by generating higher loading of
a hardened, brittle fan. Buy a new fan, then compare it's soft, flexible blades
to those on the old one and you will be quite surprised.
Really is cheap insurance.
Alan
Vector57 is offline
The Following User Says Thank You to Vector57 For This Useful Post:
Torquey5 (27th July 2010)
Clutch change DIY with pics vantaam5 E39 M5 and E52 Z8 Discussion 110 15th September 2016 11:40 PM
Clutch line replacement DIY vantaam5 E39 M5 and E52 Z8 Discussion 30 25th April 2015 07:46 PM
Auxillary Fan Replacement? ccm241 E39 M5 and E52 Z8 Discussion 7 16th June 2012 02:54 PM
For Sale Free M5/Z8 Fan & Fan Clutch Ben Carufel Parts / Other For Sale or Wanted 6 22nd February 2009 07:45 AM
DIY Sparkplug Replacement BMWM5Driver M5 E39 and E60 tips & tricks 0 21st January 2007 02:10 AM
