How do you distinguish between a worn thrust arm bushing and a worn control arm bushing? - BMW M5 Forum and M6 Forums
Old 21st July 2010, 23:10   #1
varmint007
varmint007's Avatar
Garage: '02 Lemans / Caramel
I seem to have symptoms similar to the OP in this thread:
slight shudder when braking, occasional front-end instability while cornering moderately hard at speed
Replaced Lower Control Arm - check yours
But figured you guys may know of a definitive test to know which bushings should be replaced.
Or maybe I should just do them all?
Leaning toward powerflex, I could definitely tolerate some more NVH.
thanks!
varmint007 is offline   Reply With Quote
Old 22nd July 2010, 02:20   #2
Suro
Suro's Avatar
Garage: 2003 Carbon Black/Caramel/DD:1999 LS400
Look at them, cracks are a give away. Thrust arm wears quicker than control arm and its usually the thrust arm that causes the vibration when braking.
E39 M5: still the car by which all others are judged.
Suro is offline   Reply With Quote
Old 22nd July 2010, 05:06   #3
timmay77
timmay77's Avatar
Garage: 2001 M5 (M CINCO), 2001 525i Touring (FAM WAG)
Sales Feedback: (17)
+1 Suro. Check for cracks. While you are in there, might as well do them both depending on mileage. Both sets of bushings are rather inexpensive........
I have the Powerflex TAB's and love them btw.
2001 Jet Black/Executive Black
M5 ("M CINCO") current mods and accessories:
~ RMS Stage 2 SC Kit with a Fabtech-Performance Heat Exchanger
~ Complete aftermarket stereo system w/Alpine INA-W910/PXA-H800, Rear Camera,
Hybrid Audio Technologies L831 speakers
~ UUC V12 clutch kit with segmented kevlar clutch disc
~ Custom crank case ventilation system
~ Cutsom dual electric radiator fan set up
~ BIP headers and decat pipes
~ Muffler delete with ///M5 - MCINCO etched "Timmay Tips" LOL
~ Dinan 3.45 rear differential
~ Remote oil thermostat/Setrab oil cooler
~ (4) Dinan 18x9.5" wheels
~ Stoptech slotted rotors and Centric Posi Quiet Pads
BC Racing coil overs (10k/8k) ~ Powerflex thrust arm & inner track arm bushings ~ Dinan RSB ~ Beastpower RSB brackets
Slimmbones finned rear diffuser, XL fog light covers, trunk spoiler, and front lip spoiler.
Tim ~ email: t.hallman77 @ yahoo (dot) com
timmay77 is online now   Reply With Quote
Old 24th July 2010, 14:44   #4
milemuncher
Garage: E39 M5 Carbon Black
Mirror the above, may aswell do them both. The tie rod ends and centre drag link will be next so might be worth attacking the whole lot in one hit. Its what I did with my car and followed by a proper alignment you can feel the difference.
milemuncher is offline   Reply With Quote
The Following User Says Thank You to milemuncher For This Useful Post:
varmint007 (25th July 2010)
Old 24th July 2010, 16:03   #5
carlgrz
carlgrz's Avatar
As said above, probably your thrust arm bushes giving the wobble. The control arms are a breeze to get off compared to the thrust arms anyway so it would be silly not to do those too. When you take the thrust arms off check the state of the ball joints. One of mine was completely knackered but I changed both arms anyway.
carlgrz is offline   Reply With Quote
The Following User Says Thank You to carlgrz For This Useful Post:
Old 25th July 2010, 03:44   #6
tristan
tristan's Avatar
Garage: M5 carbonblack
For the Ball joints: check for wear or looseness.
For the bushing- if you don't see any wear,cracks, or fluid leaks in the bushings grab the arm and give it a firm tug/push you shouldn't see movement of the arm at the bushing. if you're feeling it when you drive you should see which arms are due to be replaced.
Dinan Headers
Tubi Regular
ESSTuning
Ground Control
Dinan rear sway bar
TCDesign rear sway brackets
Stop Tech front BBK
Intravee II ipod interface and Alpine KCA-420i ai-net
V1/S1
tristan is offline   Reply With Quote
The Following User Says Thank You to tristan For This Useful Post:
Old 25th July 2010, 22:55   #7
varmint007
varmint007's Avatar
thanks everyone for the replies
I'm waiting for a day where the heat index drops under 100 before climbing around under the beast.
Old 26th July 2010, 18:45   #8
darknight
Garage: 03' M5 - Carbon Black
thanks!
If your worried about the nvh, don't be. I've got PF blacks for all my bushings plus a significantly stiffer suspension than most and I hardly notice anything.
darknight is offline   Reply With Quote
Thrust Arm Bushing Time! M5inAtlanta E39 M5 and E52 Z8 Discussion 75 16th September 2009 16:02
Thrust arm / bushing question Bluerumble E39 M5 and E52 Z8 Discussion 9 1st March 2009 22:01
150 mile trip on a worn out thrust arm bushing... kirbanana E39 M5 and E52 Z8 Discussion 4 29th February 2008 20:31
Thrust arm bushing replacement question Qship5 E39 M5 and E52 Z8 Discussion 7 29th April 2007 00:29
Hybrid Thrust Arm Bushing chivas E39 M5 and E52 Z8 Discussion 1 18th May 2006 02:27
