New Hood - Page 21 - BMW M5 Forum and M6 Forums
Like Tree1Likes
Old 4th August 2010, 11:16   #201
Gradus Futura
Gradus Futura's Avatar
Garage: BMW
Originally Posted by ATLZHP6M View Post
Count me in,
1) Russap5 (2/3)
2) firehire (2/3)
3) jimmythefish (2/3)
4) ATLZHP6M (2) FRP with CF vents.
5)
We will be getting the OEM hood we are going to use for the plug to the mold next week hopefully. One more person to choose 2/3 would make this hood.
Atlzhp6m Im not sure we will be able to do FG. The price should be pretty decent for just CF. Im guessing everyone else is shooting for CF
I would also like to mention that we only use a resin that is made and patented by only one company in the world. It is not only completely UV resistant but it will with-stand temperatures of up to 400 degrees. This means it will not yellow. The hood as well as most of our products are produced under vacuum, so the part will be as strong and light as possible. We also compensate for shrinkage on our plugs so that the mold doesn't make a part(hood) that is smaller than OEM. Which in turn will have OEM like fitment.
Most lower quality hoods have gaps because they don't compensate for the shrinkage involved in the composite product making process. Mostly all resins in the composite have a tenancy to shrink a little bit after it cures. So if you make a copy of a OEM hood say and that composite mold will shrink just little bit after its done. Then when you make a composite part in that slightly shrunken mold(where talking like a 10th on an inch) it will shrink also on top of that, which is why the gaps at so large on cheap products. Simple lack of expertise.
Chris
Gradus Futura
"Where Form Meets Function"
Gradus Futura is offline   Reply With Quote
Old 4th August 2010, 18:28   #202
russap5
russap5's Avatar
Garage: 2001 M5 Jet Black
Chris,
Can you describe a little bit about how you would produce the vents? How we should expect them to look? Are they produced separately and then somehow added to the hood? Will they look essentially just like the Vorsteiner vents (not in overall shape but in the style of the slats)?
I would probably want some CF vent covers if you decide to make them and offer them in addition to the hood. Only for that super rainy day or if my car was for God's sake ever parked outside for an extended period of time.
Thanks,
Drew
2001 ///M5 Jet Black on Caramel / Alcantara
Dinan
CAI, Dinan Rear Sway Bar, Dinan Front Strut Bar, Dinan Exhaust, Dinan
Brembo GT BBK 355mm Front - 345mm Rear, Evolve Alpha-N Tuning, Walbro 255HP fuel pump,
Ground Control Coilovers, Evolve "Medusa" headers, Magnaflow Cats, SuperSprint X-pipe, Magnaflow 10416 resonators, Beastpower Rear Sway Brackets, Gulf Oil Filter Housing w/ Fluidyne Cooler,
Custom Fluidyne Power Steering Cooler,
Linea Corse Z2S 19" wheels w/ Continental DW tires, EVO U/D Pulleys, Reinforced Rear Subframe, Diff Viton O-rings,
RaceSkids Metal Underbody Panels, Custom Leather/Alcantara steering wheel door panels and front seats, 35% window tint, Valentine One Hardwired, ACS style splitters,
E60 SSK and ZHP Knob, "Shorty" clutch stop w/ start sensor mod, Carbon Fiber Wrapped Interior, BSW subwoofer kit, Competition 6.5" front speakers in custom baffles,
DICE/Intravee II iPod adapter, TEC Cupholder, E90 radio knobs, AC and USB powered plugs installed in center console, Full LED overhaul in cabin/footwells/trunk
DIY Accelerator Pedal Removal
My Custom covered steering wheel
My plug-n-play LED light upgrade
DIY adding AC and USB power outlets
DIY fix squeaking steering wheel adjustments
Shadow Chrome: A closer look
$6 DIY headrest in-car camera mount
M5 DIY for Dummies
russap5 is offline   Reply With Quote
Old 4th August 2010, 18:55   #203
lanza360
lanza360's Avatar
Garage: 03 M5 Jet Black
New Hood
Chris,
would you guys consider making a Hood with just the power dome if you get enough people?
Fernando
lanza360 is online now   Reply With Quote
Old 4th August 2010, 19:10   #204
SidekickChuck
SidekickChuck's Avatar
Garage: 2001 M5
Sales Feedback: (4)
I agree with just the powerdome, looks the best, nice and subtle.
SidekickChuck is offline   Reply With Quote
Old 4th August 2010, 20:24   #205
Gradus Futura
Garage: BMW
Originally Posted by russap5 View Post
Chris,
Thanks,
Drew
Drew,
Thats a great question. We disgust about making some carbon fiber tunneling on the inside of the hood that will not only channel the air to the 2 intakes behind the headlights but also having a rain water/wash water run off. A water catch so to speak, that basically is a little wall that will have space above it so that the high flowing air can pass over the top of it while the heavier water coming in the tunneling will be caught by the wall and be redirected somewhere safe in the motor compartment. We also discovered that this type of system would be about an inch to and inch and a half think and would not have any clearance issues with the plenum cover and long as the vents were on the sides like in the renderings.
Originally Posted by lanza360 View Post
Chris,
Fernando
Right now we have 4 people who want vents(2/3). They I believe after they see the mock-up(plug) are all paying up front because its the only way we can start a project this big. When the fifth person steps in its done. We almost have our OEM hood to start the mock-up so things are progress indefinitely.
You have to understand that 5 people would have to step up and agree to the same thing to get just a power dome. If the two of you can do that also then you guys would just need 3 others. I believe there were a couple other people then ourselves that wanted that in the beginning so if you look through the thread you could ask them and maybe we could do both designs.
Chris
Old 4th August 2010, 20:39   #206
russap5
russap5's Avatar
Originally Posted by Gradus Futura View Post
Drew,
I don't want any tunneling to air intakes. I want my vents to be vents, not intakes. I thought we dealt with this issue earlier in the thread. Let's keep the hood simple like all the other examples on the market and just have vents.
Old 4th August 2010, 20:53   #207
Hdhntr23
Hdhntr23's Avatar
Garage: 2002 TiAg E39 M5
Sales Feedback: (13)
Is he talking about the air or tunneling the water from rain?
Air Jordans for sale!! Size 13 << Click the link!!!
Current Interior Mods:
MKIV, Sirius Retrofit, BlueTooth Retro-Fit, E60 SSK, ACS Aluminum Pedals, 30% Window Tint, TEC CupHolder, 2X's Ultimate Cup Holders, Full LED upgrade (Thanks Timmay77), "M" Stitched Alcantara Shiftboot and E-Brake boot, CF Steering wheel trim (Thanks CGRM5), Euro-Dash (Thanks Raz and Timmay77), Hella TC-400 TPMS, Scosche BlueTooth 2.0 A2DP Adapter (Thanks btmlinedan) Euro "Safety kit" Fire Extinguisher and First Aid box (Thanks Slimmbones)
Current Exterior Mods:
"Always-On" DRL Predator ICE LED 6000K AE's (Thanks Timmay77 and NavCoder), C-Fiber Kidney Grills (Thanks Havasusteve03Beast), ACS C-Fiber Roof Spoiler, ACS Flipper style C-Fiber Front Splitters, C-Fiber OEM Trunk Spoiler, C-Fiber Eye-Lids (Thanks CGRM5), Custom "vented" C-Fiber Rear Diffuser (Thanks Timmay77, ATLANTAM5 and Diny), Euro Headlights, (Thanks CGRM5), C-Fiber 6 piece window sills, 7 Piece C-Fiber Blue/Grey Roundels, Stainless vented custom Fog-Light frames, Hamann style sideskirts w/ CFiber Inserts
Current Performance Mods:
Dinan Exhaust cans (Thanks Timmay77 and btmlinedan), Brake duct mod with "Black Chrome" custom rings (Thanks Timmay77 and Diny), Dinan RSB with BeastPower brackets (Thanks Firehire, MFreakin5 and btmlinedan), Stoptech slotted rotors with StopTech Street Performance Brake Pads (Thanks Zeckhausen Racing Timmay77 and Lunker325)
Hdhntr23 is offline   Reply With Quote
Old 4th August 2010, 20:53   #208
lanza360
lanza360's Avatar
New Hood
Chris,
I think there more than enough people that just want the power dome, I think is all about knowing how much it will cost inCF or FG.
Old 4th August 2010, 22:28   #209
Gradus Futura
Garage: BMW
Channeling the rain water or wash water makes it to where you don't have to touch or do anything and keeps the cost lower because we don't have make another plug and mold for a smaller part.
Chris
Old 4th August 2010, 22:35   #210
Torquey5
Garage: 2003 ///M5
Sales Feedback: (3)
Man that AW beast with the custom hood is absolutely gorgeous. It mystifies me to no end why BMW didn't incorporate that into our hoods. I mean cmon, at least give it to us 2003 models
2003 Titanium Silver ///M5
Torquey5 is offline   Reply With Quote
Anyone ever seen this hood before?? russap5 E39 M5 and E52 Z8 Discussion 9 5th September 2009 01:33
what kind of hood spring hinges to use with a CF hood? agreenrhino E39 M5 and E52 Z8 Discussion 6 27th June 2009 16:44
GTR hood owner, how do you wash your car and its hood ? FAST 5 E39 M5 and E52 Z8 Discussion 2 27th August 2007 22:08
GTR Hood owners, What did you pay to have the hood prepped, painted & installed ? FAST 5 E39 M5 and E52 Z8 Discussion 19 24th July 2007 14:29
You want a CF hood....seems like one is done TriflowM5+M3 E39 M5 and E52 Z8 Discussion 10 20th February 2004 03:11
