DIY: DIY: Fuel pressure regulator to throttle body vacuum line replacement - BMW M5 Forum and M6 Forums
 5Likes
post #1 of 24 Old 18th July 2010, 08:36 PM Thread Starter
Mike S.
Mike S.'s Avatar
I thought I would try and beat Raikku to the punch on a DIY, so here's my attempt.
This vacuum line, as we've seen discussed in several threads, can get brittle with heat and stop providing accurate vacuum signal to the fuel pressure regulator located near the fuel filter. Part no. 13-53-1-407-717 (Vacuum pipe). It had to be special ordered from BMW in Germany, so it took a while to get. Cost: US$9.40.
To access this vacuum line, you have to remove the plenum. Then you need to locate the vacuum line, remove it from the connector at the throttle bodies on bank 2, and the connector underneath the cabin filter on the US driver's side.
This project took me two hours, total, including a test drive at the end. It was my second time to have the plenum off, and that helped speed things along, so if you've never had the plenum off, plan on three hours. If you also want to change out that pesky fuel evap canister that gives the E8 code, it's right next to the vacuum line. Add another 45 minutes and some foul language, and you can knock that out at the same time.
Step 1: The beginning. Note: Anytime you remove the plenum, it's a great idea to use a magnetic tray (blue item on right) to hold the nuts and bolts. Also, have a magnetic pickup tool as well for the nuts or bolts you drop. And you will drop some.
Step 2: Plenum cover off
Step 3: Velocity stacks off (Note the accumulation of nuts and bolts in the tray). You may also note the presence of my cordless drill at the bottom of the image. I used that for nut and bolt removal (not installation) and it makes the job go by lots faster.
Step 4: Plenum almost ready for removal. Still need to get the oil separators, air intake hoses, and a couple of hoses off the bottom.
Step 5: After getting the intake hoses off and out of the way, you will see these two hoses under the plenum that need disconnecting. The large one is already disconnected and the smaller one behind it is yet to be. Both are easy to get to by slightly lifting the plenum.
Step 6: Plenum off, baby. To remove the oil separators, unbolt the funnels from the plenum and pull them straight out.
Step 7: Old vacuum line removed. To access the line, look under the bank 2 fuel rail for a rubber line that connects to an elbow connector and then runs towards the back of the engine. The line runs behind the cylinder head, resting in a clip, and up to it's other end, located underneath the cabin air filter on the U.S. driver's side. Remove the cabin filter for much easier access.
As you can see, my line appears to be okay, but it's unclear whether the elbow could be cracked or the line deteriorated in some way.
Here is a closeup of the connector under the cabin filter. I've removed the cabin filter for access. The connector is to the lower right of the brass fitting. The hose has been removed at this point.
Step 8: New hose in place. Now, you can probably see the connector better.
Step 9: This is the other end, at the throttle body. You can see the connector, viewed from U.S. passenger side towards U.S. driver's side (Bank 2).
New hose in place. You can see the elbow connection here as well.
At this point, you can button everything up and you are done. When reattaching the plenum, it's a good idea to follow the TIS instructions for installation, which essentially say tighten everything from the inside to the outside, using a two-step tightening process. First, tighten everything to 5Nm, then to 10Nm.
Hope this helps someone, as I've been helped so many times by the people on the board.
Cheers,
Rolling Heroin - 2003 M5 TiAg / Tuning by Evolve / Exhaust by Timmay77 / ECM by Valentine / Fast by Nature - "She's fast enough for you old man." Nickname courtesy of Mike Miller (yes, that one.)
What I do in my spare time: Aura Caelestis, Metal Band From Texas. Check us out! Comments welcomed!
Mike S. is offline
The Following 12 Users Say Thank You to Mike S. For This Useful Post:
5PEEDY (18th July 2010), CapeCodM5 (18th July 2010), Chadderz2010 (19th July 2010), chowdah (18th July 2010), CSBM5 (8th December 2010), DARK6mt (19th July 2010), herrubermensch (19th July 2010), joe78577 (22nd August 2011), M5 London (18th July 2010), vantaam5 (18th July 2010), Vector57 (19th April 2011), Wurger (17th May 2011)
post #2 of 24 Old 18th July 2010, 08:55 PM
vantaam5
You saved me some work,my friend!
How did the short piece of rubber hose look that attaches to the throttle bodies?
vantaam5 is offline
post #3 of 24 Old 18th July 2010, 09:20 PM
TMcNasty
TMcNasty's Avatar
Nice DIY sir. Couple questions.
What happens if this line fails? Is the car undriveable or does it just have weird symptoms like hard starting or an SES light?
Also, while certainly cheap enough was it necessary to be special ordered? Looks like standard vacuum line that could be bought anywhere. And are brass elbows not also a possibilty locally? Seems a shame to toss another plastic one in there knowing they're weak.
DIY - Oil Pan Thread Repair
http://www.m5board.com/vbulletin/e39...rain-plug.html
DIY - O2 sensor change
http://www.m5board.com/vbulletin/e39...or-change.html
DIY - Replace worn and 'creaking' door seals
http://www.m5board.com/vbulletin/e39...ml#post2163106
DIY - Replace OEM battery with Bosch 49-850B
http://www.m5board.com/vbulletin/e39...h-49-850b.html
TMcNasty is offline
post #4 of 24 Old 18th July 2010, 10:12 PM Thread Starter
Mike S.
Mike S.'s Avatar
I'll have a better look at it this afternoon and see. It's possible that it was loose at the connection point, due to wear.
The car is not un-driveable, but if the fuel pressure regulator doesn't get the correct vacuum signal, it seems to affect the idle more than anything. Also, no SES light.
Whether or not this fixes my idle hunting issue (which is why I changed it out) will be decided over the next couple of days worth of driving.
As for the special order aspect, I didn't know it was back-ordered, so I figured it would be like any other part. A brass elbow is an interesting idea that I hadn't really considered. I guess, more than anything, I just wanted an exact fit that I didn't have to build myself. So I went with the OEM part.
Mike S. is offline
post #5 of 24 Old 19th July 2010, 07:11 PM
xr4tic
xr4tic's Avatar
If the line fails, two things will happen, you will have a vacuum leak that can lead to other issues, and the fuel pressure regulator will not reduce fuel pressure under vacuum conditions, causing a rich condition.
I'd pull the line off, find a brass fitting of the appropriate diameter, and then use some silicone vacuum tubing to replace the rubber, then you wont have to worry about the heat cracking the plastic or rubber any more.
John Baas
2001 Anthracite Metallic M5
2003 Silverado SS
Interior
Euro Dash, Slimmbones Euro Armrest, Slimmbones Shifter/Ebrake Boots, F10 M5 Illuminated Shift Knob, UUC EVO3 Shifter, UUC DSSR, UUC Clutch Stop, Autolumination Interior LEDS, JBL MS-8, Alpine MRX-V70, Kicker Subwoofers, Polk/Boston Acoustic Speakers
Exterior
Vorsteiner Power Dome CF Hood, Euro Clear Corner Headlights w/Lamin-X, Umnitza Predator Ice V3, Umnitza 6K Headlight + Fog Light Upgrade, Umnitza V4 Side/Turn/License LEDs, CF Roundels, Black Kidney Grills, Slimmbones BigMouth Lower Grill
Drivetrain
Evolve Alpha-N Tuning, Supersprint Headers/Cats/X-pipe + Eisenmann Race Mufflers, VSL Aluminum Radiator, UUC Twin Disk Clutch, Rogue Engineering Trans Mounts
Suspension
Ground Control Coilovers, Dinan Monoballs, Dinan Rear Sway Bar w/Beastpower Brackets, Dinan Front and Rear Strut Bars, BMW Performance Front Brake Kit, StopTech SS Brake Lines, Black Stock Rims Square Setup
Coming Soon
Custom Oil Catch Cans, Zionsville Radiator Shroud, Supercharger!
xr4tic is offline
The Following User Says Thank You to xr4tic For This Useful Post:
Mike S. (19th July 2010)
post #6 of 24 Old 17th April 2011, 01:09 PM
Gustav
Administrator
Gustav's Avatar
Gustav is offline
post #7 of 24 Old 22nd August 2011, 03:33 AM
joe78577
joe78577's Avatar
Cheers,
could I get a picture of where this line is located ?
joe78577 is offline
post #8 of 24 Old 22nd August 2011, 10:43 AM
feeblebob
feeblebob's Avatar
Mike, any chance of reposting these pics?
2001 E39 M5 : Silverstone Blue, 19" Breyton Spirits (horribly rashed...Genuine BBS LM's to go on), Philips Silverline Indicator Bulbs, Intravee II and Alpine KCA-420i (in a box in the house) and 160GB iPod Classic , Evolve headers and race cats to go on, otherwise standard at the mo...
"I look at it like this. Owning an M5 is kind of like dating a slamming hot big-t...ed blonde, who is a pain in the *****, drains your cash, but screws like there's no tomorrow. Owning a Honda Civic or the like, is akin to dating a girl who is fat, ugly, smells a bit where she shouldn't, is a cheap date and doesn't screw at all (you don't mind). So yeah, I'll take the blonde." (Courtsey of Jetpilot718)
The thread of my car and it's progression to mechanical perfection... : http://www.m5board.com/vbulletin/e39...ry-thread.html if I ever get around to anything...
Cabin Filters 6/3/11, Bosch wipers 21/5/11, OEM air filters 24/5/11 (110,920), Oil Change, Oil Seperators and Thermostat 07/08/11 (112,699), Final Stage Resistor, Coolant Temp Sensor, Silvered Indicator Bulbs 21/08/11 (114,110), Private Plate 23/10/11, Came home from storage 13/02/13
feeblebob is offline
post #9 of 24 Old 22nd August 2011, 04:47 PM Thread Starter
Mike S.
Mike S.'s Avatar
Yes, I will repost them, if I still have them. Not sure where they went to be honest. Let me see what I can do.
Mike S. is offline
post #10 of 24 Old 22nd August 2011, 05:04 PM
feeblebob
feeblebob's Avatar
No probs, grateful for any effort. I hadn't noticed this for some reason and would be interested in seeing the results of your efforts.
ECS Adjustable Fuel Pressure Regulator herrubermensch E39 M5 and E52 Z8 Discussion 38 19th July 2010 08:02 PM
fuel pressure regulator Ruppy E34 M5 Discussion 4 5th January 2009 11:15 PM
adjustable fuel pressure regulator stilov E39 M5 and E52 Z8 Discussion 2 12th September 2007 04:46 AM
Fuel pressure 4.6 bar - is it filter, regulator or pump? DavidS E39 M5 and E52 Z8 Discussion 0 28th July 2005 03:50 PM
Broken Fuel Pressure Regulator steveB E39 M5 and E52 Z8 Discussion 9 22nd December 2001 04:12 PM
