So I finally made a little time to install Peter's (Herrubermensch) fog lights. This came with a shorter plastic cover - you can see my intake air filter right behind the bumper. I hope Timmay does his vent for the wheelwell and I will put that in too.
The other thing I did recently was have a custom shroud made for the Zionsville radiator. We put in a Spal low profile fan. I think that we may have to do a little more to keep it cool. The fan is only about 1800 CFM and I think I need more like 2500 CFM. I am also thinking about doing a remote oil cooler and heat exchanger blockoff a la Dinan S3.
***For Sale*** 2000 M5 - Titanium Silver / Napa Black / Aluminum Trim -UFMotorsport IATS kit - Alutec Strut Tower Brace -16:9 Nav Screen upgrade - MKIV DVD Nav - Beastpower rear swaybar brackets
2001 M5 - DA Twin - The Blue Beast 800HP former PhillyM5 car
The Following User Says Thank You to mamsterla For This Useful Post:
Yeah the standard shroud left no room for a fan with the SC setup.
I know the ESS guys have run into this problem, so they had to reposition the SPAL fan on the shroud. I spoke with Zionsville who said they could move the circular cutout for the fan anywhere on the shroud. Is that what you had done??
I assume it was the fan motor that was contacting the pulley?? What was changed on the shroud?? Is it just the low profile fan that was changed?? I have not found a thinner fan that can pull 2500+ CFM, what is your plan for a better fan??
Please elaborate. Excuse my tone, but you started a thread for this so please share some details..
I began fabrication on Steve's vent, so far it isn't going exactly as I had it planned in my head. I sent a few embarrassing photos to Steve of it, but will more than likely scrap that unit and go a different route.
Radiator looks great btw. SO CLEAN......
Originally Posted by Hdhntr23
I like strippers.
2001 Jet Black/Executive Black///M5 ("M CINCO") current mods and accessories: Complete Alpine/Memphis aftermarket stereo system w/ Navi-Bluetooth-Ipod-DVD-HD Radio-Rear Camera (Thanks Jun) ~ E60 SSK ~ Illuminated ZHP Shift Knob (Thanks Starscream) ~ Ebay Ebrake Handle ~ Euro Headlights (Thanks Raza) ~ Angel iBright V.3 ~ French Fogs ~ DRL Angel Eyes ~ Silverstar turn signals ~ Full LED interior light upgrade ~ Muffler delete with custom made Timmay77's "Signature" ///M5 - MCINCO etched staggered tips ~ OEM 18x9.5" rear wheels at all 4 corners (Thanks Surge709) with 3mm Ebay spacers on the front, 10mm spacers on the rear, all 4 wrapped with Dunlop SP Sport 9000's 275/35/18 (Thanks killer diller) ~ Stoptech slotted rotors and Centric Posi Quiet Pads (Thanks Dave at Zeckhausen Racing ) ~ B&G Suspension lowering springs ~ Powerflex thrust arm bushings (Thanks Bimmerzone.com) ~ Hardwired Valentine 1 (Thanks hdhntr23) ~ CF OEM trunk spoiler ~ CF wrapped diffuser ~ CF window spoiler
Tim ~ mobile: 614-595-0641 ~ email: t.hallman at ymail . com ~ bbm: 3227AFD5
What exactly would the heat exchanger block off do? I saw that in Peter's thread but I wasn't quite sure what it's advantage was.
The heat exchanger block off kit removed the under-plenum oil heat exchanger, which removes the heat from under the plenum that the heat exchanger generates. You then need an external oil cooler, which one could use the "Gulf" oil filter housing to install or you can simply tap the lines from the existing housing. Most of us who have done this (MikeOski, Havausteve) have used the Gulf oil filter housing then mounted the external oil cooler behind the kidney grills. Works very well to keep oil temps down as well, though it's principal advantage is to remove under-plenum heat, which heats up the plenum, which heats up intake air, which decreases its density and with it, engine performance. (How's THAT for a run-on sentence!)
--Peter
__________________ The Beast
2001 E39 M5 LeMans Blue with Black/Blue Sport Interior and Titanium Trim, ESS Supercharger, RMS In-Plenum Intercooler, RMS Plenum Plates and Custom-Bored 52mm Diameter "Shorty" Velocity Stacks, Dinan TBs and Headers, CNS Catback Exhaust, Evosport High-Flow Cats, Stoptech Trophy Sport Brakes (6-Pot Front/4-Pot Rear; 355 mm Rotors All Around), Dinan 3.45 Differential, Rogue Stage 3 280mm Clutch with Custom 850 CSI Slave Cylinder and JB Racing LTW Flywheel, Dinan Differential Subframe Reinforcement, GC Coilovers (550 7" Front/325 10" Rear), Dinan Front and Rear Swaybars, TC Designs Rear Sway Bar Brackets, Dinan Monoballs, Dinan Rear Wheels (18 x 9.5) All Around With 10mm Spacers and 90mm Wheel Studs, Michelin PS2s 275 35 18s All Around, UUC EVO3 SSK with DSSR, Voltphreaks VPR-S40P Endurance Battery (14 lbs.), Setrab 16-Row Oil Cooler, Dinan Under-Plenum Heat Exchanger Removal Kit, Vorsteiner Double-Sided CF Hood with Open Vents, CA CSL-Style CF Trunk Lid, TC Designs Roll Bar, Zionsville Super Duty Cooling System, Aquamist HFS-6 Meth Injection with Custom CF/Aluminum Trunk-Mounted Fuel Cell Designed by Howerton Engineering, XRP HS-79 Hosing, OKD Plasma Ignition Coils and Plug Boots, Kenne Bell Boost-A-Pump, Smoked Hella Tailights, Clear-Corner Hella Euro Headlights, CA ACS-Style CF Front Splitters, Clarion DRZ9255 Head Unit (Custom Installed by Timmay77), Two Alpine PDX-5 Amps, HAT L1 Pro Tweets, HAT L3 Mids in Custom A-Pillars, Illusion Audio ND-8 Mid-Basses in Custom Door Panels, and Two Dynaudio MW190 Subs Running IB in Rear Deck, PLX Digital Gauge, V1/S1 Mounted in UGDO Location, Recaro Sportster CS Seats, EAS Competition Steering Wheel, Leather Eurodash, Schroth 4-Pt Street Harnesses, Dinan Foglight Delete Kit, and Various Other Bits and Pieces
Coming Soon!
Hankook R-S3 285 35 18s All Around, Full Leather Doorcards, Stoptech Carbon Ceramic Rotors, Quad Head Laser Interceptor, Balanced and Blueprinted S62 Built by Bavarian Solutions
For an FI car, you want to keep the incoming charge as cold as possible, so putting heat there under the plenum goes against what you are doing with the intercooler. Plus our FI motors run hotter, so the oil will cool better externally via the external core. My main problem is where to put it since my kidney space is taken up with the radiator and intercooler - space is tight in there.
Hi Mike - I have a modest oil heat exchanger in front of the large water intercooler, and still managed to squeeze in the nitrous fogger, although the later is not positioned as optimally as yours. You might consider re-positioning the fogger to accommodate a flat oil heat exchanger, as heat seems more a pressing problem in SoCal than a perfect but discretionary fogger system. A heat exchanger in front of a heat exchanger is obviously not perfect either, but I think it works ok (as evidenced by significantly lowered after-cooler air temp.) Abdulla had the oil heat exchanger installed to help deal with 100+F heat in Bahrain.
An ideal set up might be the S3 oil cooler down below, but I don't know about the geometry/space requirements vis-a-vis our set up.
