The Complete DIY for Twisted Seat Repair! - Page 6 - BMW M5 Forum and M6 Forums
Like Tree4Likes
LinkBack Thread Tools Rating: Thread Rating: 1 votes, 4.00 average. Display Modes
Old 2nd April 2012, 16:25   #51
doc$holliday
doc$holliday's Avatar
Garage: 2003 M5 Le Mans Blue
Nice - glad you got it fixed!
For anyone in this thread waiting for a video, be sure to check out this newly posted thread by Terabass:
VIDEO: Twisted seat repair/fix - super easy
SP
Sean Paul
2003 M5 LeMans Blue, blue/black
Dinan Stage 1 suspension, Rogue trans mounts, short shift, E46 ZHP shift knob, Magnaflows, Stoptech Slotted Rotors, Stainless brake lines and Street pads in Front, Beastpower titanium pedals, white LED interior lights.
doc$holliday is offline   Reply With Quote
The Following User Says Thank You to doc$holliday For This Useful Post:
Terabass (2nd April 2012)
Old 24th July 2012, 06:49   #52
sor118
sor118's Avatar
Garage: 2002 Carbonic Blackalicious M5
Sales Feedback: (4)
Thanks to this DIY I got through fixing my twisted drivers seat and passengers seat. Terabass' video made it look so easy when it wasn't so easy for me at first.
Let's just say I almost had a bit of a panic attack when my drivers seat was completely twisted and wouldn't even sit level on the floor of the car(I removed only the front bolts) after cutting the first 1cm of rubber around one of the cables. It turned out I cut around the wrong one lol and made it twist even more. I thought I actually bent the seat rails lol. At that point I left it as is last night to try again today with a fresh start and positive thinking.
I found that after cutting the rubber surrounds, the key is to pull the cable out to disengage, get the seat lined up and actually sit in it to see if it feels right and then push the cable back in to feed the cable to the motor and test the movement and you will be good to go.
I completed fixing 2 cables on my drivers seat and also one on my passenger (didn't know about until I tested it today) and man it felt good to get it back to normal. I did the passenger side with the seat in place without removing any bolts and did it in under 10 minutes. Easy as pie after you get the idea behind it all.
2002 Carbon Black BMW ///M5 (Black Extended Leather, Anthracite Alcantara, Titanium Trim, M-Audio with Enhanced Bass, PDC)
Conforti Shark Injected with M5Board Tune, CMS Custom Muffler Delete with OE Tips, AFE Pro Dry S air Filters, ACS rep CF Front Splitters, Flat Black Kidneys, Open brake ducts with Flat Black Brake Duct Rings, StopTech Stainless Steel Braided Lines, Shorty Clutch Stop, Lighted ZHP Knob, Custom Pure White Angel Eyes (Predator Ice housing and Rebel Tri-Star LED's driven by PowerPucks), Umnitza V4 ION License Plate Lights, Fogs color matched to HID's, Oil Pan Pad Heater for winter, 3M Clear bra on hood, Flat Black Style 65's on Nitto NT555's, Style 66's on Conti Extreme WinterContact's for the other 6 months, Interstate MTP-H9 Battery, Sybesmas remaned rearview mirror, Boomerang Espion Alert LoJack, MKIV Nav with 2010 maps.
http://www.cardomain.com/ride/2964057/1
http://www.bmwmregistry.com/detail.php?id=7570
sor118 is offline   Reply With Quote
The Following User Says Thank You to sor118 For This Useful Post:
chowdah (24th July 2012)
Old 4th August 2012, 21:45   #53
BimGoBlue
BimGoBlue's Avatar
Garage: 2002 M5 - Carbon Black
Has anyone had to work on the thigh support? My passenger side thigh support extends but does not retract. It seems to be a bar that extends rather than a cable, but I don't want to start tearing out the seat if it's a simpler fix.
BimGoBlue is offline   Reply With Quote
Old 5th August 2012, 06:52   #54
champaign777
Garage: 2003 BMW 530i
i just did right side of my passenger seat
i used this video
BMW Seat Twist Repair.$0 cost.ACTUAL REPAIR of twisted seat!!! e39,e34 - YouTube
took me 2H , the most difficult part was to remove the seat , this thing is heavy !
My suggestion is to remove the seat from the car , once the seat is out you can do it right and easy on both sides
And NO this job is not 10 min work or you want to redo again and again
GL
champaign777 is offline   Reply With Quote
Old 5th August 2012, 08:14   #55
sor118
sor118's Avatar
Sales Feedback: (4)
i used this video
GL
Glad you got through it but you didn't have to remove the seat and you didn't need to disconnect the wire from the motor as in the video! All you had to do was find the correct cable and cut out 1 cm or so of the plastic/hard rubber jacket around the wire, level out the seat by pulling out the cable and re-feed the cable to the motor and tape it up. So, yes, it could have taken you 10 minutes.
It took me longer on my drivers side seat as I had to take care of 2 cables after I first cut the wrong one and twisted my seat further, but it took me less than 10 minutes to fix my passenger side tilt after I knew what I was doing.
Old 5th August 2012, 18:05   #56
champaign777
what is T50 bolt torque for seats ?
Twisted Drivers Seat - anyone experienced this? LEENA1 E39 M5 and E52 Z8 Discussion 35 28th May 2012 05:33
Seat Belt Twisted M5Prospect E39 M5 and E52 Z8 Discussion 15 20th April 2011 18:20
twisted seat if lookz kill E39 M5 and E52 Z8 Discussion 10 23rd September 2010 17:00
02 e39 M5 seat is all twisted up RJScotti E39 M5 and E52 Z8 Discussion 11 20th August 2009 05:52
DIY - Is replacing a rear seat belt recepticle DIY? M5VRICK E39 M5 and E52 Z8 Discussion 4 4th August 2009 17:55
