The Complete DIY for Twisted Seat Repair! - Page 5 - BMW M5 Forum and M6 Forums
Like Tree4Likes
LinkBack Thread Tools Rating: Thread Rating: 1 votes, 4.00 average. Display Modes
Old 13th July 2011, 06:41   #41
Kevin The Clean 1
Kevin The Clean 1's Avatar
Garage: 2002 BMW M5 (Sterling Gray)
Sales Feedback: (10)
Originally Posted by agentZERO View Post
in for the vids
That would be great if someone created a video on this...
Kevin The Clean 1 is offline   Reply With Quote
Old 13th July 2011, 07:57   #42
Kevin The Clean 1
The back of my seat & the vertical height adjustment seam to be fine. However, the forward motion (moving the drivers seat towards the steering wheel) seam to be off. The right side of my lumbar support is closer to the dash then the left side of my lumbar support.
In other words it seams that my right knee when driving is now closer to the dash then my left knee is. Do you fellas understand what I'm saying & can I fix this motor issue with this cable fix... ? I'm assuming not since this type of adjustment (simply moving the seat closer & farther to the dash) requires the seat to move a long the big steel rails the 2 front seat are attached to...
Old 15th July 2011, 06:06   #43
duhfool
Garage: Titanium Silver/Black 2003 M5
I never looked into the horizontal motion controls, since my issue was the height and recline adjustment, but if it's like the other motors, you could try to just unplug one of the cables and adjust it until looks straight to you.
Any idea on how it could have been out of alignment, outside of someone messing with it?
duhfool is offline   Reply With Quote
Old 16th August 2011, 03:26   #44
agentZERO
agentZERO's Avatar
Garage: 02 M5 - Carbon black
still hoping that someone who has done this repair will record a DIY vid for posterity
2002 M5 Carbon Black/Caramel
Delimited,
H&R Springs, Hamann-style Front Lip,
V1 Hardwired,
Black/Gray ///M badges and roundels
XM radio, DICE iPod, BMW.Bluetooth
JL Audio speakers/subwoofer/amps
6000k lowbeam HID upgrade
AIB 3.0 White Angel Eyes
Umnitza 8000k HID foglights
other than that stocker than stock...
agentZERO is offline   Reply With Quote
Old 24th August 2011, 21:07   #45
sportmodeON
Garage: 2002 M5 LeMans Blue
Used Doc$'s method to repair my seat today. However, since I had good access to the drive cable in question, I was able to complete the repair without removing the seat. Heat gun proved very handy for this job. Thanks again for the DIY post.
sportmodeON is offline   Reply With Quote
Old 21st March 2012, 00:28   #46
Kevin The Clean 1
How hard was it to do & how long did it take you?? Mine just broke today in the fully reclined position. Only the left side of the back seat raises forward & the right side of the seat does not. It's twists the back frame like a mofo... ;-(
Old 21st March 2012, 00:34   #47
Kevin The Clean 1
RealOEM.com * BMW E39 M5 BMW SPORTS SEAT FRAME ELECTRICAL
Would it make it easier to just purchase part #16... ?
Old 21st March 2012, 00:40   #48
jfoj
Garage: 2003 M5 Sterling Gray & 2006 330cic (Vert) Silver Gray
My suggestion is remove the seat from the car, but be careful for airbag light issues when you take it out.
Once the seat is out, it is pretty easy to do. Heat up the cable end, pull it off, cut about 3/8" or 7/16" of the tube, heat and reinstall the end piece. Getting the seat back aligned is the tough part.
I recall I took a few male spade terminals on some jumper wires and used my jumper box so I could easily power the seat while I had it out of the car to make adjustments and check the alighnment?
jfoj is online now   Reply With Quote
Old 21st March 2012, 08:59   #49
Kevin The Clean 1
I'm going to begin the process now. Thanks for all the info here everyone...
Old 2nd April 2012, 03:59   #50
edwzrm5
Today I just fixed the passenger seat recline and rear height. Right side was frozen in both cases. The rear height was all the way down but fortunately I could raise the front height all the way. Removing the (4) torx bolts lets the seat tilt back for better access, and the (2) motors and cables are close to the front of the seat. I was able to leave the seat in the car with seat belt, power connector, and tensioner wire left intact. The right side problem case is easier with the seat in the car as the cables are much more accessable than those that drive the left side of the seat.
I used the "middle of the cable" sheath cut method (cut out approx. 0.5 in.) and used heatshrink tubing (3/8) to cover the cut and keep the sections joined. Many thanks to Doc$ and all those who provided details for this awesome thread.
edwzrm5 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
seanjohntx
Twisted Drivers Seat - anyone experienced this? LEENA1 E39 M5 and E52 Z8 Discussion 35 28th May 2012 05:33
Seat Belt Twisted M5Prospect E39 M5 and E52 Z8 Discussion 15 20th April 2011 18:20
twisted seat if lookz kill E39 M5 and E52 Z8 Discussion 10 23rd September 2010 17:00
02 e39 M5 seat is all twisted up RJScotti E39 M5 and E52 Z8 Discussion 11 20th August 2009 05:52
DIY - Is replacing a rear seat belt recepticle DIY? M5VRICK E39 M5 and E52 Z8 Discussion 4 4th August 2009 17:55
