The Complete DIY for Twisted Seat Repair! - Page 4 - BMW M5 Forum and M6 Forums
Like Tree4Likes
LinkBack Thread Tools Rating: Thread Rating: 1 votes, 4.00 average. Display Modes
Old 1st April 2011, 10:52   #31
m5rosemont83
m5rosemont83's Avatar
Garage: 2002 M5 Chiaretto Red
Great success..
just did this for both chairs.. recline and height as well
did it without removing the seatbelt or pin
just the 4 screws from the floor
m5rosemont83 is offline   Reply With Quote
Old 2nd April 2011, 02:40   #32
agentZERO
agentZERO's Avatar
Garage: 02 M5 - Carbon black
in for the vids
2002 M5 Carbon Black/Caramel
Delimited,
H&R Springs, Hamann-style Front Lip,
V1 Hardwired,
Black/Gray ///M badges and roundels
XM radio, DICE iPod, BMW.Bluetooth
JL Audio speakers/subwoofer/amps
6000k lowbeam HID upgrade
AIB 3.0 White Angel Eyes
Umnitza 8000k HID foglights
other than that stocker than stock...
agentZERO is offline   Reply With Quote
Old 25th April 2011, 20:55   #33
ehs
ehs's Avatar
Garage: 2003 M5 LMB
Sales Feedback: (3)
Thanks for a great DIY thread! I was able to fix the passenger seat recline (outer side was not moving) without removing the seat using the method of removing insulation in the middle of the cable and splicing the insulation with electrical tape. I was somewhat forced to go this route as it appeared that the seat anchor bolts are a Torx bigger than T-45 (the largest I had on hand). I read the OP advice that the bolts might be a 13mm, but on my car (2003), they are Torx. Don't know if that is what others found, but it might be good to add to the supplies list. If any other cable had required surgery, I would have had to do it once I had the right Torx bit.
ehs is offline   Reply With Quote
Old 26th April 2011, 04:56   #34
doc$holliday
doc$holliday's Avatar
Garage: 2003 M5 Le Mans Blue
Glad this thread is still doing a good job paying dividends to fellow members in need! A big thanks to everyone who continues to contribute to it as well. Waiting on the Terabass vids! lol.
Sean Paul
Sean Paul
2003 M5 LeMans Blue, blue/black
Dinan Stage 1 suspension, Rogue trans mounts, short shift, E46 ZHP shift knob, Magnaflows, Stoptech Slotted Rotors, Stainless brake lines and Street pads in Front, Beastpower titanium pedals, white LED interior lights.
doc$holliday is offline   Reply With Quote
Old 26th April 2011, 11:16   #35
Kevin The Clean 1
Kevin The Clean 1's Avatar
Garage: 2002 BMW M5 (Sterling Gray)
Sales Feedback: (10)
My two front seats were each secured down with T-45 Torx bits too...
Kevin The Clean 1 is offline   Reply With Quote
Old 10th July 2011, 22:49   #36
RideM5
Garage: 2003 CB M5 / Tahoe LTZ
Can someone post a picture of under the seat with the motors labeled, identifying which seat part each cable is for(ie outside passenger recline, inside passenger rear vertical)? I unbolted my seat and took a look under and tried to feel the cables while operating the seat, but I'm still not confident which ones I should be cutting. Thanks
RideM5 is offline   Reply With Quote
Old 10th July 2011, 23:48   #37
zaapa
Garage: 2002 M5 white
Thanks for the great DIY - and I thought I was the only one with twisted seats!!!
zaapa is offline   Reply With Quote
Old 11th July 2011, 00:11   #38
jfoj
Garage: 2003 M5 Sterling Gray & 2006 330cic (Vert) Silver Gray
Standard 5 series option only for the lucky few!
Ask me how I know?
jfoj is offline   Reply With Quote
Old 12th July 2011, 11:30   #39
duhfool
Garage: Titanium Silver/Black 2003 M5
You can look up your car and check the seat diagram on RealOEM.com * Online BMW Parts Catalog.
That's what I did to check out which motor is what.
I still have to do the height repair, but since I don't use it, it wasn't a priority before I went on a road trip.
duhfool is offline   Reply With Quote
Old 12th July 2011, 13:08   #40
RideM5
I ended up using the diagram yesterday, and just assumed that the cord going to the side of the seat that isn't moving is the broken one. I fixed the back recline and the rear vertical raise, didn't take too long. They are the two motors in the front of the seat, pretty easy to access the corresponding cables. Unfortunately, I couldn't undo the seatbelt bolt because that side was locked in the down position. I ended up taking the seat out of the car with the seatbelt attached, laying it on the ground close enough for the seatbelt to stretch. I would definitely recommend using 14 gauge wire stripper, make your two cuts (mine were 1/2" apart), then pull the wire completely out and slide the small cut section off the wire. Then you just slide the wire back into its sleeve towards the motor, and tape it up. I used electrical tape, but wish I used a shrink wrap for a tighter seal.
Twisted Drivers Seat - anyone experienced this? LEENA1 E39 M5 and E52 Z8 Discussion 35 28th May 2012 05:33
Seat Belt Twisted M5Prospect E39 M5 and E52 Z8 Discussion 15 20th April 2011 18:20
twisted seat if lookz kill E39 M5 and E52 Z8 Discussion 10 23rd September 2010 17:00
02 e39 M5 seat is all twisted up RJScotti E39 M5 and E52 Z8 Discussion 11 20th August 2009 05:52
DIY - Is replacing a rear seat belt recepticle DIY? M5VRICK E39 M5 and E52 Z8 Discussion 4 4th August 2009 17:55
