The Complete DIY for Twisted Seat Repair! - Page 3 - BMW M5 Forum and M6 Forums
Like Tree4Likes
LinkBack Thread Tools Rating: Thread Rating: 1 votes, 4.00 average. Display Modes
Old 27th September 2010, 21:08   #21
primeral
Garage: 02 M5, Alpine White
Don't leave out Steps 8 and 9 as they are ultra critical
(\__/) (\ /)
(")_(") c('')('')
Save the Manuals!
primeral is offline   Reply With Quote
Old 24th November 2010, 17:59   #22
duhfool
Garage: Titanium Silver/Black 2003 M5
I'm attempting to do this today. So far, I had to also bend a bracket to get to the bolt and I had the luck to have the height adjustment on the seatbelt side fail, so I can't remove the seatbelt bolt.
My question is what are the torque settings for the seat bolts? When I took them out, they were definitely on super tight. I don't think it was the loctite that I was up against.
I'm probably going to try two other styles of fix.
1. use a torch to pull the cable while leaving the metal tip installer.
2. cut the middle of the sheathe, remove piece, then tape it together.
Barring that, I'm probably just going to leave the height adjustment unfixed, since getting to that one looks like it will be too painful.
It was the seat recline that was painful to live with.
Thanks for all the pioneers that provide me with all the DIY information. Saves me a lot of time.
duhfool is offline   Reply With Quote
Old 24th November 2010, 21:41   #23
jceg
Garage: 2011 335d
TIS has the seat to floor plate bolt torque as 42nm.
Can you access the failed cable with the seat in the car? If so, pull the cable and use a power drill to spin it until you have enough clearance to take out the seatbelt bolt.
jceg is offline   Reply With Quote
The Following User Says Thank You to jceg For This Useful Post:
duhfool (25th November 2010)
Old 25th November 2010, 00:56   #24
duhfool
Thanks for the spec.
As for the height cable, I might be able to access it.
I'm just a bit leary about using the butane torch that close to the seat to soften the cable enough to pull it out.
As it stands, the recline has been restored, so that's good enough for Thanksgiving traveling.
Next project... fuel breather valve.
Old 25th November 2010, 01:27   #25
jceg
Garage: 2011 335d
When I initially tried to fix my seat twist I attempted to do the whole job with the seat in the car. This went poorly due to the lack of clearance, light, and leverage. However, I did manage to get the cable out of its socket quite easily by using a butane stick lighter to heat up the cable socket. The flame on the lighter was very short, and I stuck a few layers of aluminum foil behind it to act as a heat shield. It worked fine. Just tossing it out as an option for the next time you take a look at it. I know how annoying the seat twist thing is, it happened on both of my seats within the last year.
Old 31st March 2011, 02:27   #26
peckbmw
peckbmw's Avatar
Garage: 2002 M5, Le Mans Blue
Wow, what a life saver! Great DIY. I did the "Slice in the middle" technique. My first impression was the cable was like a speedo, rotating core, steel casing, rubber insulator. It was a little confusing on how to cut trough the casing. No worries tho, the casing is solid rubber!
My bad cable was the left side recline, unreachable with the seat in the car. Shoot, as i write this, i realize that to access the cable, I had to unhook some of the leather, and forgot to re-hook it, oh well, back to the seats.
Ken
peckbmw is offline   Reply With Quote
Old 31st March 2011, 02:36   #27
m5rosemont83
m5rosemont83's Avatar
Garage: 2002 M5 Chiaretto Red
Was looking at this last night.. what a coincidence..
Will be doing both sides tonight! I got the car with my seats leeeeanin.. lol
m5rosemont83 is online now   Reply With Quote
Old 31st March 2011, 06:00   #28
Terabass
Terabass's Avatar
Garage: M5 Matte Black
I will have a video DIY on this in couple days.
Terabass is online now   Reply With Quote
The Following User Says Thank You to Terabass For This Useful Post:
agentZERO (1st April 2011)
Old 31st March 2011, 10:38   #29
Kevin The Clean 1
Kevin The Clean 1's Avatar
Garage: 2002 BMW M5 (Sterling Gray)
Sales Feedback: (10)
doc$holliday,
Thank you so much for this great DIY article. I have stumbled upon & read past this thread tons of times. I never really knew what it was about/referring to until tonight while I was vacuuming my car. I think my drivers seat has this same issue & now I need to fix it... !
Kevin The Clean 1 is offline   Reply With Quote
Old 31st March 2011, 23:57   #30
djazz
Garage: Jet Black E39 M5
My wife, Cindy, thanks you all for this thread.
"I look upon an increase in the power of the State with the greatest fear, because, though apparently doing good by minimizing exploitation, it does the greatest harm to mankind by destroying individuality, which lies at the root of all progress." — Mahatma Gandhi
djazz is online now   Reply With Quote
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
Twisted Drivers Seat - anyone experienced this? LEENA1 E39 M5 and E52 Z8 Discussion 35 28th May 2012 05:33
Seat Belt Twisted M5Prospect E39 M5 and E52 Z8 Discussion 15 20th April 2011 18:20
twisted seat if lookz kill E39 M5 and E52 Z8 Discussion 10 23rd September 2010 17:00
02 e39 M5 seat is all twisted up RJScotti E39 M5 and E52 Z8 Discussion 11 20th August 2009 05:52
DIY - Is replacing a rear seat belt recepticle DIY? M5VRICK E39 M5 and E52 Z8 Discussion 4 4th August 2009 17:55
