Tire Pressure? - BMW M5 Forum and M6 Forums
 4Likes
post #1 of 70 Old 9th June 2010, 06:38 PM Thread Starter
hisport
hisport's Avatar
Tire Pressure?
What tire pressures work best for everyday normal driving?
- The door jamb sticker has everything; from 34 F and 38 R to 44 F and 48 R
- The owners manual says nothing (but takes 5 pages doing it)
- Related threads on this forum are mostly tire brand opinions (and alot of 'em)
- I have stock wheels and Bridgestone Pole Position RE960AS tires (if it matters) 245 40 18 front and 275 35 18 rear
hisport is offline
The Following User Says Thank You to hisport For This Useful Post:
"S62" (26th January 2011)
post #2 of 70 Old 9th June 2010, 06:56 PM
xplodee
xplodee's Avatar
I've been doing 33/36 front/rear when cold which comes out to about 38/41 front/rear when hot.
-Tim
2013 M5 silverstone/black
2001 M5 carbon/caramel
xplodee is offline
The Following User Says Thank You to xplodee For This Useful Post:
hisport (9th June 2010)
post #3 of 70 Old 9th June 2010, 07:37 PM
bwilly
bwilly's Avatar
My '01 has door jamb cold pressures of 39-F, 46-R.
Does anybody know why would different M5 cars of the same family would have different pressures listed?
bwilly is offline
post #4 of 70 Old 9th June 2010, 07:50 PM
chowdah
Super Moderator
Door specs provide a range based on vehicle load. Front vs rear PSI bias can depend on your wheel setup, driving style, suspension setup. Different tire makes have varying stiffnesses, which beg for different PSI. Some drivers prefer to trade tire longevity for traction/comfort, and shade PSI lower.
The best answer is to get a tire depth gauge, monitor your tires for center and outer wear over time, and adjust PSI accordingly. This presumes you are also monitoring balance and alignment, since both can skew your tire wear observations.
chowdah is offline
The Following 4 Users Say Thank You to chowdah For This Useful Post:
5PEEDY (10th June 2010), gsfent (10th June 2010), Hdhntr23 (9th June 2010), jclyman (9th June 2010)
post #5 of 70 Old 9th June 2010, 08:37 PM
bwilly
bwilly's Avatar
Yeah, I understand why people would use different pressures. I just don't understand why the factory would apparently put different PSI numbers on cars that were essentially identical?
bwilly is offline
post #6 of 70 Old 9th June 2010, 09:41 PM
wentouch
The Owner's Manual does appear to provide the recommended tire pressure. The recommended tire pressure is shown on Page 23 of the online 03 manual. The variation is for load (standard size), minimum for four passengers with maximum for either five passengers/four passengers plus luggage.
Based on the info provided in the manual, it appears you have the wrong sticker on your door jam. The suggested pressure of 39/46 is as indicated for the 245/45/17 tires on the standard 5.
wentouch is offline
The Following User Says Thank You to wentouch For This Useful Post:
post #7 of 70 Old 9th June 2010, 10:49 PM
INDIVIDUAL 5er
INDIVIDUAL 5er's Avatar
I believe door jamb sticker lists MAX allowable pressure.
I usually do 34F/36R.
Factory Optioned:
* INDIVIDUAL Agaischblau/Aegean Blue-Metallic exterior (code 336)
* INDIVIDUAL Extended leather Nappa "Champagne" upholstery (Incl. selector lever gaiter) w/ plastic parts of seats in black
* INDIVIDUAL Bicolor Champagne/Black Napa M-leather steering wheel w/ black quilting yarn stitch
* INDIVIDUAL Natural Poplar Wood trim w/ "Heritage Interior" handbrake lever
* INDIVIDUAL Chrome Line Interior speaker covers
* INDIVIDUAL Silver speedometer cluster cauge rings
* M-Executive Package (Sports Package II/M-Tech Package/Premium Package)
* European trunk storage bin/floor net/bag holder/tool kit (complete) w/ warning triangle & passenger parcel net
* UGDO
M5 Transplants:
* Complete brake system (incl. backing plates & parking brake) w/ Euro floating rotors & Goodrich stainless steel brake lines
* Front (coming) & rear sway bars (Incl. bushings) w/ Beastpower TC Design Rear Swaybar Brackets
* M5 carpeted trunk mat
760Li Transplants:
* 20" Staggered BMW Style 101M rims (custom bored out to 74.1mm)
- Polished/Clearcoated lips (coming)
- Pirelli P-Zero Nero 245/30/20(F) & 285/25/20(R) tires
Dinan Mods:
* Front strut tower brace (mounting brackets painted Aegean Blue to match engine compartment)
Audio Mods:
* Sirius receiver (BMW Part #65120416377) w/ Antenna (BMW Part #65200034887) hidden w/in center brake light
* Aux Input Kit (BMW Part #82110149390) hidden w/in center console storage cubby
* BSW d112.e39 Subwoofer System
Foreign Love:
* ACS rear roof spoiler (coming)
* Angel iBright V3.0 angel eye upgrade
* Zionsville Rad w/ Super Duty Cooling Kit (+ 2 speed fan kit)
* Hoen Xenonmatch Titanium H7 high beam bulbs (70W/4300K) & Xenonmatch 9006 fog light bulbs (4000K)
* EAC Tuning Lemforder thrust arms w/ HD bushings
* NGK Iridium IX Spark Plugs (BKR6EIX)
INDIVIDUAL 5er is offline
post #8 of 70 Old 9th June 2010, 11:22 PM
REKIII
REKIII's Avatar
The max allowable pressure is listed on the tire itself.
Because of the drastic camber on the rear of these vehicles, checking inner to outer wear is sorta pointless.
I was once told that you go by the door pressure and they a 1-2 psi for every inch larger wheel you go, so if you have 19's your would ad 1-2 psi to the 34/38 or whatever.
Anyone else heard this?
2001 Jet Black M5
2012 Black Ford Raptor
2014 Black Jeep Grand Cherokee Summit
2008 Raven R1 - Being disassembled and sold
REKIII is offline
post #9 of 70 Old 10th June 2010, 05:43 AM
josiahg52
josiahg52's Avatar
Running a square setup, I opt for 35-36# cold which is right around 40# when hot.
josiahg52 is offline
post #10 of 70 Old 10th June 2010, 06:27 AM
nyyfinsphan72
nyyfinsphan72 is offline
Tire Pressure stanm E39 M5 and E52 Z8 Discussion 9 3rd December 2012 09:39 PM
What is your Tire Pressure? ajcut7 E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 27 25th August 2007 04:12 PM
Tire pressure question: Summer pressure vs. Winter pressure tripleD E39 M5 and E52 Z8 Discussion 3 13th June 2007 01:29 AM
Tire Pressure RAREM5 E39 M5 and E52 Z8 Discussion 13 27th March 2002 06:04 PM
