'Check Engine Oil Level' message - Page 2 - BMW M5 Forum and M6 Forums
Like Tree4Likes
Old 10th June 2010, 21:32   #11
malexgcab
malexgcab's Avatar
Garage: M5 CB
I got home yesterday and pulled the dipstick and the oil level seems to be slightly higher than max limit on the dipstick. I drained some of the oil so that the level is somewhere in the middle of the gauge.
This morning on my way to work I noticed my oil temp on 300 . I pulled over and pulled the dipstick and level was normal. Waited for about 2-3 minutes and restarted the engine. Oil temp gauge was back down below 210.
I'm guessing it is the oil temperature sensor. Any thoughts?
malexgcab is offline   Reply With Quote
Old 11th June 2010, 01:02   #12
Wisky
Wisky's Avatar
Garage: 2003 Porsche 911 C4S
Wow thats frightening! It sounds like it might be the sensor. It would probably take a bit of effort to really get the oil to 300F.
Porsche 996 C4S
Mercedes Benz W210 E55 AMG
Wisky is offline   Reply With Quote
Old 11th June 2010, 21:41   #13
malexgcab
malexgcab's Avatar
Garage: M5 CB
I was not too concerned since I checked the oil level before leaving the house. I suspected it is oil temp sensor.
Old 11th June 2010, 21:58   #14
Wisky
Wisky's Avatar
What's the part number for the oil temp sensor? I have to order it. How difficult was it to replace?
Glenn
Hey Glenn. I dont have PM access yet as I do not have 75 posts under my belt.
I have never replaced this part myself - but im pretty sure this is the correct part - if in fact oil temperature and oil level are the same sensor.
12-61-7-508-003-M44
Pelican Parts - Product Information: 12-61-7-508-003-M44
The only BMW shop in our area that I would recommend is Bimmerclinic in Elizabeth NJ if you don't want to tackle the job yourself. (I'm sure there are others but I have not had experience with other shops)
Good luck!
-Dave
Old 16th June 2010, 15:07   #15
malexgcab
malexgcab's Avatar
Garage: M5 CB
Does anyone know if I need to remove the lower oil pan to replace the oil level sensor?
Old 16th June 2010, 15:09   #16
vantaam5
vantaam5's Avatar
Garage: 2003 M5 matte black
No need to remove the lower oil pan.
Drain oil and then all you need is a 10mm socket to remove the bolts of the sensor,disconnect it,new one in,connect it,oil in,fine
The sensor is attached to the oil pan with three bolts(sse pic on the left side)
-rebuild in winter 2011/2012
"submarine edition",a bit boost and some M5 parts...
vantaam5 is offline   Reply With Quote
The Following 2 Users Say Thank You to vantaam5 For This Useful Post:
D-RodM5 (27th July 2011), tmlesko (6th January 2012)
Old 16th June 2010, 17:02   #17
malexgcab
malexgcab's Avatar
Garage: M5 CB
^^^ Thank you
Old 1st October 2012, 22:29   #18
SidekickChuck
SidekickChuck's Avatar
Garage: 2001 M5
Sales Feedback: (4)
Yup, this started happening with me over the weekend. Total thread revival here since there has not been a post in here since 2010, but I would assume if its happening to me, it may start happening with others soon.
I guess I will have to order the sensor part since checking the oil do not indicate oil levels are low at all.
2001 BMW e39 M5
Eisenmann Race Exhaust
SS X-Pipe resonator delete
Powerchip Tune
CNS Racing Clutch
KW Variant 3 Coilover Suspension
RDSport 19" RD2
Latest Photos
SidekickChuck is online now   Reply With Quote
Old 2nd October 2012, 00:26   #19
herrubermensch
herrubermensch's Avatar
Garage: LeMans Blue 2001 BMW M5 with black and blue extended leather and brushed aluminum trim
Sales Feedback: (4)
Originally Posted by jclyman View Post
Sorry, but I just don't trust "sensors" to check my oil (they fail sometimes, right? your's did, right? luckly it didn't fail to light, when you did have low oil). I am not so lazy that I don't have time to pull the dipstick and use the sensors God gave me . The "sensor" you are trusting doesn't even check the oil level ... it checks for a change in temperature (you can read that where I did, in the BMW E39 M5 TIS explanation of how it works).
A lack of a dipstick is the only reason I didn't buy an E60 ... well, the other reason, truth be told, is that they are buttt ugly.
Just had to repost this from John Clyman, may he rest in peace. For the newer folks on the board, John was a stalwart, extremely erudite, and a thorough BMW enthusiast. In addition, he was a truly fine fellow who continues to be missed very much. Finally, as the above quotation shows, he was a bit of a pistol and held an opinion of the aesthetics of the E60 M5 with which I thoroughly agree.
We miss you, John.
--Peter
The Beast
2001 E39 M5 LeMans Blue with Black/Blue Sport Interior and Titanium Trim with some great mods and a blown, balanced and blueprinted S62
herrubermensch is offline   Reply With Quote
Tags
oil, sensor
How often do you get the 'Check Engine Oil Lvl' message? NJ.M5 E39 M5 and E52 Z8 Discussion 24 29th August 2009 04:05
[New] E39 M5 2000. Check Coolant Level and Check Oil Level sajStars E39 M5 and E52 Z8 Discussion 9 5th August 2008 15:11
Check engine oil level... openroad E39 M5 and E52 Z8 Discussion 12 4th May 2006 19:13
A Better Way To Check The Engine Oil Level?!?! Anita E39 M5 and E52 Z8 Discussion 1 6th April 2005 00:26
Check oil level message Noka E39 M5 and E52 Z8 Discussion 5 5th April 2002 17:10
